  • 1 Post By 09TrueRedGTX
  • 1 Post By Killer95GT302
 Old 05-04-2015, 06:49 PM   #1
Colepidd55's Avatar
Posts: 211   (View Stats)
Colepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond repute
Default Turbo replacement questions
Found out over the weekend that my K04 is toast and I'm replacing it with a rebuilt one. I just have a few questions about the install that I couldn't find.
1. I've bought new studs and nuts for the downpipe/mani to turbo connections, as well as a new exhaust mani gasket. I'm just wondering if I will be needing anything else other than those?
2. After the install, does the turbo need to be broken in?
I'm pretty mechanically inclined, but I've never done anything to this extent before. It seems to be pretty strait forward.plus, I can just look at how to's for other turbo installs and just reverse the removal of the K04.BUT, I thought I'd ask so I don't end up killing my new turbo.
any help would be great!
SOLD
2009 CWP Speed3
Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+
Colepidd55 is offline   Reply With Quote
 Old 05-04-2015, 07:20 PM   #2
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Don't forget the gasket for the oil return and you should replace the oil feed copper washers(2) and the coolant pipe washers (4) - Just take your time and be careful as you go otherwise.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 05-04-2015, 07:20 PM   #3
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
You will need new coolant drain, coolant feed, oil feed crush washers and an oil drain gasket.
Depending on the milage of your car you can probably get away with applying copper spray to the exhaust gaskets and reuse them.
 Old 05-04-2015, 07:34 PM   #4
Colepidd55's Avatar
Where's a good place to get those gaskets and washers?
SOLD
2009 CWP Speed3
 Old 05-04-2015, 07:37 PM   #5
You can get the gaskets from edge autosport - Probably best bet is mazda on the washers
Soon to come.
 Old 05-04-2015, 07:57 PM   #6
Colepidd55's Avatar
thanks for the info guys. I'm searching mazdapartonline and I'm not finding those washers..anyone got a part #?
SOLD
2009 CWP Speed3
 Old 05-05-2015, 08:02 AM   #7
Colepidd55's Avatar
no one?
SOLD
2009 CWP Speed3
 Old 05-05-2015, 10:13 AM   #8
jdmage_mx5's Avatar
1 qty Oil Drain (lower pipe) to Turbo Gasket - L3K914293
2 qty Oil Feed (upper pipe) Crush Washer - 995621200
4 qty Coolant inlet/outlet Crush Washer - 995621400
All parts can be found here: Link
The Following 6 Users Say Thank You to jdmage_mx5 For This Useful Post:
aackthpt (05-08-2015), Colepidd55 (05-05-2015), duappleganger (05-06-2015), HawkeyeGeoff (05-05-2015), lescano88 (06-09-2015), SparkySparks (06-01-2015)
 Old 05-05-2015, 10:49 AM   #9
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Look at this guy right here, being all helpful and stuff! Kudos!
Silver 2007 Speed3 GT
jdmage_mx5 (05-05-2015)
 Old 05-05-2015, 10:59 AM   #10
jdmage_mx5's Avatar
I just got done spoon feeding my 3 year old son who was acting helpless. I guess I was in the groove. LOL.
The Following 3 Users Say Thank You to jdmage_mx5 For This Useful Post:
Colepidd55 (05-05-2015), nojjy (05-08-2015), Raider (05-31-2015)
 Old 05-05-2015, 12:09 PM   #11
Colepidd55's Avatar
Thank you!
SOLD
2009 CWP Speed3
 Old 05-05-2015, 07:33 PM   #12
MSMS3's Avatar
Posts: 2,826   (View Stats)
No special break in. Just avoid full boost for the first 100 miles or so. It would be good to fill the turbo oil inlet pipe with oil to avoid it running dry the first few seconds after it starts until it gets oil from the pump. Some rebuilt turbos come with some temporary lube on the internal center shaft bearings.
I just had mine rebuilt by Work Turbochargers (turborepair.com) in North Alabama, and it came back with some temporary internal lube.
 Old 05-06-2015, 06:01 AM   #13
09TrueRedGTX's Avatar
Posts: 127   (View Stats)
09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute
You could also hold the gas pedal to the floor while cranking the engine. This will allow oil to flow into/out of the turbo, without actually starting then engine. Do that 3 times for 5 seconds each, and you should be good to go.
qkrthnu2 likes this.
09TrueRedGTX is offline   Reply With Quote
The Following 2 Users Say Thank You to 09TrueRedGTX For This Useful Post:
Colepidd55 (05-08-2015), MSMS3 (05-06-2015)
 Old 05-08-2015, 03:09 PM   #14
Killer95GT302's Avatar
Posts: 198   (View Stats)
Killer95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond repute
What he said - you'll know its pressurized when the oil light turns off.
The best tip I can give is take your time, especially if this isn't your primary car. Don't fall into the forum mechanic hours estimate trap. Make sure you clean up all mating surfaces real good. Last thing you want to do is rip it apart again to fix an exhaust leak.
2006 Mazdaspeed6 - Bone Stock!
1995 Mustang GT - Turbocharged / Motor work
Killer95GT302 is offline   Reply With Quote
The Following 3 Users Say Thank You to Killer95GT302 For This Useful Post:
09TrueRedGTX (05-08-2015), aackthpt (05-08-2015), Colepidd55 (05-08-2015)
 Old 05-08-2015, 03:34 PM   #15
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
Did you say exhaust manifold gasket? I recently did a bnrS3 swap and did not remove the exhaust manifold. I would recommend this approach.
Freeks BNR install
This way you don't need that gasket, and ideally the install will go faster.
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
The Following User Says Thank You to superman For This Useful Post:
 Old 05-08-2015, 06:48 PM   #16
Colepidd55's Avatar
yeah, I assumed it would just be easier to take off the manifold to get the turbo out. I guess all the how tos' i read said to do it. But, I'll try without taking out the manifold first.
It's my primary car, but I've been driving a buddies truck. I'm itching to get this done, but I'll make sure to take my time. I was talking to a friend who does a lot of work on VWs and he told me to do an oil change after 100 miles. I'm due for one anyways, but i was wondering maybe I should do it before I swap it? I have about 3k-4k on the oil right now.
SOLD
2009 CWP Speed3
 Old 05-08-2015, 06:58 PM   #17
CFI2008's Avatar
Posts: 259   (View Stats)
CFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the world
Don't bother taking off the exhaust manifold or even the turbo bracket. The bottom two bolts on the bracket would not break so I just took the one that held the turbo on off and removed the turbo to mani studs using the 2 but method m10 1.5 nuts. Skids right out drivers side.
CFI2008 is offline   Reply With Quote
The Following User Says Thank You to CFI2008 For This Useful Post:
cyclist20 (05-31-2015)
 Old 05-08-2015, 08:56 PM   #18
jdmage_mx5's Avatar
So yea the k04 does slip out the driver side but for as easy as it is to remove the manifold vs wiggling it around the egr and brake booster area I would go with removing the manifold if it were me. I've done about 5 swaps on various speeds and taking the manifold out is my preferred method.
On the nuts near the turbo for manifold to block just break loose and use a ratcheting wrench.
For this last swap I took out the windshield trim on the bottom and I immediately regretted not doing it on the other swaps. I would rather take more bolts off in a relaxed manner vs getting frustrated with lack of space to work in.
 Old 05-08-2015, 08:59 PM   #19
CFI2008's Avatar
I just did this swap with a bnr. You remove the break boost hose and remove the EGR and no issues taking it out. Very little wiggling required
 Old 05-30-2015, 03:07 PM   #20
qkrthnu2's Avatar
Posts: 131   (View Stats)
qkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond repute
Am I missing something? I didn't think there were any Mazdaspeed K04 turbos that could be rebuilt? Make sure you're not just being sold a used turbo, that would suck.
My install tips:
1. Remove your hood
2. Remove the cowl
Those two things will take ~15-20min and make the job SOOOOoooooo much easier.
_______________________________________________
Driver Mods - Mid Ohio Three Day Racing School
2006 Mazdaspeed 6 GT - 130k+ miles. Daily driver (Actually my Wife's car)
Shooting for a reliable 350 AWHP.
Surefire Remanufactured Engine Installed @ 135k.
Mods: BNR S3 Turbo \ Grimmspeed EBCS \ Guardian Angel \ Cobb AccessPort \ Bosch 3 Bar MAP sensor \ AWR RMM \ TurbineTech FMM \ Corksport HPFP \ cp-e Injector seals \ Autolite XP5263 plugs \ Ebay Circuit Werks DP \ Stock CBE \ HTP 3" Intake w/ DIY CAI \ cp-e TMIC \ DIY boost tubes \ Primary & Secondary EGR delete \ Bilstein Shocks \ 215/45ZR -18 Continental ExtremeContact DWS
PERM dual PVC plate and two Damond Motorsports catch cans. Full vacuum setup w/ VTA for over pressure.
PERM #1 -> DM OCC V1 -> DM PCV valve -> Check Valve -> Intake Manifold.
PERM #2 -> DM OCC V2 w/ VTA -> Check Valve -> Tee -> Valve Cover & TIP.
The others:
2009 BMW 135i - N54 - JB4 w/ backend flash \ SRI.
1998 VW GTI VR6 - 248k miles (stock clutch!) when wrecked (not my fault)
1995 Jeep XJ - 4.0 - AW4 \ Lift/Tires etc. 230k miles. Rust bucket / winter beater.
1995 Honda del sol VTEC - DIY hodge podge turbo setup \ self tuned w/ Neptune. 2550lbs ~270whp \ 150k+ miles on stock bottom end (4th clutch though) \ knock limited on 93 octane.
qkrthnu2 is offline   Reply With Quote
 Old 05-30-2015, 03:51 PM   #21
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
My install tips:
1. Remove your hood
2. Remove the cowl
Why would it not be able to be rebuilt? I rebuilt mine, and put a new stock wheel on it for ~$110, cheaper than buying a new one.
And neither of those things need to be removed to install the turbo. Jack up the car, remove the DP, unbolt it from from above, and take it out from below. Much easier than trying to get it from the side.
Have fun with the turbo bracket though, be prepared for many beers and curse words when trying to remove it.
 Old 05-30-2015, 04:13 PM   #22
qkrthnu2's Avatar
RE: Rebuilding the K04, I stand corrected. I have no idea how I got that idea stuck in my head. Maybe the idea of "not worth rebuilding" morphed into "can't be rebuilt" or something like that.
I forgot how easy you MS3 guys have it with all that room behind the engine. No way are you getting the turbo out the bottom on a MS6.
The others:
 Old 05-30-2015, 09:26 PM   #23
Colepidd55's Avatar
Well, I got it replaced today...Holy shit I'm never doing that again. took me 8 hrs strait to do it. First time I've ever taken my car apart that much. I'd say the most pain in the ass thing was that turbo bracket in the back and the coolant return line... Fucking coolant everywhere.
Turbo came out the intake side pretty easily though. I'm happy I didn't take the whole exhaust mani out.fuck that noise.
SOLD
2009 CWP Speed3
 Old 05-31-2015, 06:19 AM   #24
You could have clamped the coolant line with vise grips first.
Colepidd55 (05-31-2015), cyclist20 (05-31-2015)
 Old 05-31-2015, 10:12 AM   #25
Colepidd55's Avatar
Yeah, didn't think of that till after it was in my face..
SOLD
2009 CWP Speed3
 Old 05-31-2015, 10:15 AM   #26
That's what SHE SAID!
Zing.
breakfstincluded (09-11-2015), Colepidd55 (05-31-2015), cyclist20 (05-31-2015)
 Old 05-31-2015, 10:18 AM   #27
Colepidd55's Avatar
Zing.
ya got me.
SOLD
2009 CWP Speed3
 Old 09-11-2015, 05:50 PM   #28
paxtonschwendner's Avatar
Posts: 88   (View Stats)
paxtonschwendner is a name known to allpaxtonschwendner is a name known to allpaxtonschwendner is a name known to allpaxtonschwendner is a name known to allpaxtonschwendner is a name known to allpaxtonschwendner is a name known to all
hate to revive an old thread, but some searching brought me here. i'm going to replacing my K04 (after a rebuild) and was looking for a parts list of things that need, and should, be replaced. i have 140k on her so i don't mind replacing old parts!
paxtonschwendner is offline   Reply With Quote
 Old 09-15-2015, 04:21 PM   #29
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Did you read any of this thread?
 Old 09-15-2015, 04:28 PM   #30
I did, and did not see any how-to. So...
 Old 09-15-2015, 04:35 PM   #31
jdmage_mx5's Avatar
Seems like last time I did a turbo swap I got on here looking for a detailed parts list but did not see one (oil feed washers, oil drain gaskets, manifold to turbo gaskets, etc). If it's here then it is buried and should be brought from the dead so Google will display it.
 Old 09-15-2015, 07:50 PM   #32
yes, I read. the parts were for a gen2 ms3. I have a ms6. I don't think the parts are the same, but then again, I have no idea. that's why I asked.
 Old 09-15-2015, 08:02 PM   #33
Can you clarify Paxton?
Do you mean you are rebuilding a K04? Or buying another K04 entirely? Or replacing your K04 with a different turbo?
I'm compiling a parts list for replacing my dying K04 soon. I used the link above to view all washers and gaskets I can replace while I'm doing the turbo switch.
Besides what was listed above by jdmage, I'm also getting a new Turbo-Downpipe gasket and Manifold-turbo gasket which can also be found through the above link, many re-use them also.
If your purposes are similar to mine then I believe it's the same for MS6/genwon/genpu, I have a genwon. Unless someone can correct me, all involved parts, engine/manifold/k04 are the same.
Or are you looking for a list of parts to rebuild a K04 turbo itself?
jdmage_mx5 (09-15-2015)
 Old 09-15-2015, 09:30 PM   #34
jdmage_mx5's Avatar
Damn @breakfstincluded; is on it. I knew I posted them somewhere a while back but I have terrible memory and was not in a position to look.
Awesome work.
As stated the same gaskets are needed whether MS6 or MS3 unless you are doing something extremely unnecessary.
breakfstincluded (09-15-2015)
 Old 09-16-2015, 07:45 AM   #35
I was more or less looking for confirmation that the parts needed are, in fact, the same regardless of generation. I'm having my K04 rebuilt (or maybe BNR stage 1 ) so I was just looking for the gaskets, washers, etc. that should be replaced. it was a pain in the dick to get all that apart so I wanna get it right the first time!
 Old 09-16-2015, 04:07 PM   #36
Cool well, you got'em now. Just use Jdmage's post from earlier in the thread.
The turbo-manifold and turbo-downpipe gaskets are optional, either way I'd personally apply copper gasket as well.
paxtonschwendner (09-16-2015)
 Old 09-16-2015, 04:38 PM   #37
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Couple more links since I just did mine, most of which are contained within jdmage_mx5's link. Should be the same between the MS6 and Gen 1/Gen 2 MS3 (but confirm the part IDs just in case):
1. DP gasket:
2009 Mazda 3/M Parts - Online Mazda Parts
2. TC gasket to mani:
3. Water inlet & outlet gaskets (x4):
4. Lower oil pipe gasket, turbo side:
5. Upper oil pipe gaskets (x2 turbo side, x2 block side):
http://onlinemazdaparts.com/parts/20...0pipe%20gasket
6. Lower oil pipe gasket, block side (if removing lower pipe completely):
http://onlinemazdaparts.com/parts/20...&siteid=214264
Turbo removal/install directions:
http://www.corksport.com/support/ins...-6-777-WEB.pdf
^^Yes, they are for the Corksport turbo but the approach is exactly the same.
09 CWP MS3 GT
Ownership & Build Thread
The Following 2 Users Say Thank You to Design For This Useful Post:
Altenius (12-18-2018), paxtonschwendner (09-16-2015)
Oil Cooler Replacement Questions edmsmallcash MazdaSpeed 6 - Engine, Transmission & Driveline 47 03-15-2016 10:59 AM
DIY turbo replacement '07 CX-7 MFE CX-7 > Turbo Induction & ECU Tuning 14 12-19-2014 01:02 PM
Clutch Replacement Questions SiBuddy00 MazdaSpeed 6 - Engine, Transmission & Driveline 24 03-15-2014 05:03 PM
Rods and VVT replacement questions mazdas4me MazdaSpeed 3 - Engine, Transmission & Driveline 33 02-06-2014 05:02 PM
VVT replacement only questions airjeff MazdaSpeed 6 - Engine, Transmission & Driveline 16 09-25-2013 08:55 PM
Page generated in 0.55362 seconds with 35 queries
