  • 1 Post By dale_gribble
 Old 09-20-2013, 12:47 PM   #1
timjustindodd's Avatar
Posts: 45   (View Stats)
timjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the world
Default Unusually high BATs... WTF?
So... I've had an SU TMIC for about a month now. I'm working with stratified on my tune with my BNR S3 and Alex pointed out my BATs are rather high. Looking at your guys logs after doing a search, I realized, yeah, that is pretty high...
I have a good seal on the shroud, there's a nice dark black line all the way around the shroud where the rubber meets it... so I don't think it's that.
Is there anything else you could think of that would cause me to be seeing 140 after cruising on the highway and then doing a 4 th gear pull on a 65 degree day?
The only thing I can think of is I currently don't have that plastic shroud under neath the engine installed, didn't know if that would help create a vacuum and force more air through the intercooler?
Here's a pic...
2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV
timjustindodd is offline   Reply With Quote
 Old 09-20-2013, 12:53 PM   #2
Do you still have the weatherstripping near the windshield cowl?
 Old 09-20-2013, 12:53 PM   #3
pwdunmore's Avatar
Posts: 368   (View Stats)
Because TMIC... just the nature of the beast.
You either go TMIC with meth injection to keep BATs down or FMIC with optional meth injection for an upgraded turbo. I think you are just producing a crap load of heat (from the BNR) and the intercooler is in the perfect spot to soak it all up.
 Old 09-20-2013, 12:55 PM   #4
YUP! I haven't touched anything else on the car...
 Old 09-20-2013, 01:01 PM   #5
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
Do a coolant bypass, it should help a bit. But if you live somewhere that gets cold, remember to put the hose back on for winter. I have a log I can post up of the difference later today. But, I also have meth lol. Meth is pretty damn awesome, I suggest everyone do it lol. I was crusimg at 138f on the freeway. Got off and was at 170. Meth hit and I was at 80 in a matter of a second. This was in 110f weather earlier this week. I was cruising after doing the coolant bypass, and was at 100. then got off and idled at 115f. It was 90 outside then, but it for sure is helpful.
I should add I did the coolant bypass because I noticed my BATs sky rocket recently lol.
 Old 09-20-2013, 01:03 PM   #6
Remove the weatherstripping closest to the windshield and you'll drop 10-15*'s off of bat's.
If you note your iat vs bat now, vs. after doing so, you'll have evidence it does indeed work.
MS6 High Bats
Last edited by rfinkle2; 09-20-2013 at 01:05 PM. Reason: MSF Database - Automerged Doublepost
mr.speedy3 (09-20-2013), warlord (09-20-2013)
 Old 09-20-2013, 01:08 PM   #7
pwdunmore's Avatar
Any downside to this?
I might want to try this out for fun next summer. It's colder in canada now so my bats don't get high this time of year.
 Old 09-20-2013, 01:11 PM   #8
It is more effective on an ms6, and I guess it can be argued that airflow was considered by Mazda engineers when designing the Mazdaspeeds, but it is hard to argue with the great results on the ms6.
Every ms6 I've seen with bat problems has benefited and I've never heard of any detriments.
Also on gen2 here:
(courtesy of djuosnteisn. LOL)
How To: Engine Temps and Style Upgrade
LaraS (09-20-2013)
 Old 09-20-2013, 01:19 PM   #9
usgiorgi's Avatar
Posts: 649   (View Stats)
usgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the world
Groaned at 44 Times in 10 Posts
The only downside is that sometimes my windshield gets fogged up in rain.
I was worried about sucking in hot air into the AC, but it hasn't affected how cold the AC blows. Also, you can see a wave of heat coming out of the hood without it, so definitely dissipates heat.
EDIT**
You can also remove the rubber seam on the hood in the front. That will let a whole lot of air go through the enginebay and out the back if the cowl is removed as well. The downside may be that you'd be getting a lot more debris and water in there with the additional air.
2009 Nissan 370Z. Turbo and BOV sounds made by the driver via mouth.
SOLD: 2011 Speed3. Black mica w/tech package Cobb SRI, COBB AP, AT internals, OBX racepipe, Corksport RMM, LOUDASS STRAIGHTPIPE CPE TIP
usgiorgi is offline   Reply With Quote
The Following User Says Thank You to usgiorgi For This Useful Post:
rfinkle2 (09-20-2013)
 Old 09-20-2013, 01:21 PM   #10
dale_gribble's Avatar
Posts: 4,720   (View Stats)
If you are cruising down the highway on a 65F day and are seeing 140F BATs cruising, that is very strange. I have a SU TMIC and on a 65F day cruising down the highway staying mostly off the boost (<5psi), my BATs will be 95-100F consistently. On a 65F day with the K04 during a 4th gear WOT run, I would usually see the BATs drop to maybe 85F before getting up to 115F or so after a WOT run.
Is the cold air ducting in the hood still there? You sure the ducting isn't blocked? Was the car heat soaked badly before you got on the freeway to start with? Maybe post a log up and we can see if there is something obvious, though its likely Lex would have already reported on something odd.
TiGraySpeed6 likes this.
MINI H1 6.0 - CAR LED TAILS
rfinkle2 (09-20-2013), TiGraySpeed6 (09-20-2013)
 Old 09-21-2013, 07:53 AM   #11
Turbo_Steve's Avatar
Posts: 944   (View Stats)
My fmic gets me bats that are 20-30 degrees above ambient by the end of a pull... Time to go fmic or meth.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 09-21-2013, 08:03 AM   #12
Dead Ms3's Avatar
Posts: 206   (View Stats)
Dead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the world
I'm getting bats mid to high 20s cruising , at wot 18 and as low as 15.
Treadstone FTW !!!
But seriously fmic is the way to go.
2012 BLACK MS3 (SOLD)
-Cobb AP -CP-E stg 2 RMM -JBR Rear sway bar
-K&N SRI -UR TP -AT Internals -JBR TIP
-CX Racing fmic piping -TR8L core
2008 WHITE EVO X
-UR TP -UR Cat Back Single exit -Eibach springs
-UR UICP -TurboSmart dual port set fully recirculated
-Injen intake -3 port
...need moar money !
1995 Miata M Edition - DD
-The gay mobile
Dead Ms3 is offline   Reply With Quote
The Following User Says Thank You to Dead Ms3 For This Useful Post:
Camwilson (12-18-2018)
FMIC HIGH BATS tokoam MazdaSpeed 3/6 - Turbo Induction 21 10-02-2013 09:27 PM
MS6 High Bats snailD MazdaSpeed 3/6 - Turbo Induction 35 07-06-2012 12:38 PM
FMIC install but still high BATS KRheeder MazdaSpeed 3/6 - Turbo Induction 61 07-06-2012 12:33 PM
Car withstands unusually hot ignition timing on 93 pump gas fortressofcomfort 2010 MS3 - ECU Computer Tuning 52 06-02-2012 12:12 AM
My BATs.....High? MS6FL MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 02-28-2012 10:15 PM
Page generated in 0.36573 seconds with 27 queries
