Like Tree3Likes
  • 1 Post By jm211
  • 1 Post By drknyte
  • 1 Post By littleloogy
 Old 10-17-2013, 01:29 PM   #1
Qual1ty's Avatar
Posts: 56   (View Stats)
Qual1ty will become famous soon enough
Groaned at 5 Times in 2 Posts
Default VTA experiment
So im postin this because i cant seem to find the answers I am looking for 100% ..new to this forum but not nee to cars. Ive heard and read about these cars throwing codes and running richer then usual when going from recirc to vta (without proper tune) and surging at idle and/or stalling.
I have a Forge bpv on the car, set up to recirc..I didn an experiment fueled by curiousity as to what it sounded like venting to atmos. and of course it sounds better but i became curious. I got no check engine light, stalled twice initially, then i let it idle a bit, surged only a bit from time to time..took it for a test drive. Slight throttle seemed a bit touchier if that makes sense. I didnt mind the backfire because it didnt happen often enough. So i drove it home to see if it would "relearn" this new setup and adjust accordingly. Got to a point where backfire happened not so often, surge/maybe stall only happened until operating temp was reached. I switch it back to recirc the next day but my main question is, after that long explanation, what kind of tune would need to be achieved to have the car run normally with a VTA setup?
Its not just a love for mazda, or things awd turbo, but a love for all things automotive. Build it right, respect.
Qual1ty is offline   Reply With Quote
The Following 4 Users Say NO Thank You to Qual1ty For This Un-useful Post:
El_Diablo (10-23-2013), himurax13 (10-17-2013), KusteLokal (10-23-2013), Raider (10-23-2013)
 Old 10-17-2013, 01:31 PM   #2
Zpuhalla's Avatar
Posts: 244   (View Stats)
Zpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the world
Groaned at 32 Times in 14 Posts
This guy,
Guardian Angel Overboost Protection [GUARDIAN_ANGEL (0100-0003.3)] - $199.00CAD : Stratified Automotive Controls
ATP GTX3067R, ATP Catted DP, HTP 3" Intake, UR FMIC, Stratified GA, Stratified EBCS, Bilstein B8's, Cobb Springs, JBR RSB, JBR Mudflaps, JBR OCC, GFB 50/50 BPV, Autotech Internals, JBR Shifter Bushing, Cobb RMM, Cobb AP
Zpuhalla is offline   Reply With Quote
The Following 5 Users Say Thank You to Zpuhalla For This Useful Post:
El_Diablo (10-23-2013), Lex (10-17-2013), Mike@Stratified (10-17-2013), Qual1ty (10-17-2013), trancehead (10-18-2013)
 Old 10-17-2013, 01:48 PM   #3
jm211's Avatar
Posts: 943   (View Stats)
But why all the stalling and shit running? Thats like shooting your leg cause you like the color red.
The Following 3 Users Say Thank You to jm211 For This Useful Post:
Pointless (10-17-2013), Raider (10-23-2013), rfinkle2 (10-18-2013)
 Old 10-17-2013, 01:50 PM   #4
Qual1ty's Avatar
? its running fine now..i put it back to its normal recirculation mode because i didnt want to have all the issues.
 Old 10-17-2013, 01:53 PM   #5
This is correct. The Forge will stay open at idle unless you have a Guardian Angel regardless of tune. The air you will lose at idle will trigger a rich condition and a CEL. The GA will control the valve operation so that you can have your swoosh and not stall at idle or run rich.
El_Diablo (10-23-2013), himurax13 (10-17-2013), Qual1ty (10-17-2013), WetzMS3 (10-17-2013), Zpuhalla (10-17-2013)
 Old 10-17-2013, 01:56 PM   #6
Seriously man, I'm starting to think you're trolling us.
The answers to your questions are on here. If you are serious about a BOV and tuning for it, contact a tuner, pay them for a tune. If you're just asking questions because you don't want to read, then just stop.
Read every thread you can find about BPV's and BOV's on here, and you'll have a better idea of what your issues are. The search button is your friend.
 Old 10-17-2013, 01:59 PM   #7
Qual1ty's Avatar
Couldnt find answers to all the questions I had so I posted it all here. Sorry to keep bothering you.
The Following User Says Thank You to Qual1ty For This Useful Post:
 Old 10-17-2013, 05:03 PM   #8
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
This is a forum..... what the fuck did you expect..... to get answers to your questions.!?!
o wait...
Qual1ty likes this.
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
The Following 4 Users Say Thank You to drknyte For This Useful Post:
CWP_MS3 (10-23-2013), El_Diablo (10-23-2013), jm211 (10-17-2013), Raider (10-23-2013)
 Old 10-18-2013, 07:08 AM   #9
littleloogy's Avatar
Posts: 4,005   (View Stats)
I run vent to cabin. Every time I let off the gas the pshhhh sound is very loud, ear piercing loud!
Qual1ty likes this.
Raider (10-23-2013), Turbo_Steve (10-23-2013)
 Old 10-18-2013, 08:49 AM   #10
Qual1ty's Avatar
hahahaha one could only imagine
 Old 10-23-2013, 05:38 AM   #11
Mistersix's Avatar
Posts: 2,585   (View Stats)
As lex said the valve will sit open during idle. It's very difficult to tune for this as there really is no fix for what is effectively a hole in the intercooler piping. You could tighten the spring on the bov but then it will flutter at everything other than high throttle shifting.
The GA from stratified is really the only thing that makes it liveable. The sound changes slightly because the GA will pull the valve closed very quickly but this is necessary.
I have the GA and love my rice served with a side of rice, but shifting still isn't as smooth as when fully recirc'd. The benefit of the GA's overboost protection is good to, so it's a great device to have in general.
The Following User Says Thank You to Mistersix For This Useful Post:
Lex (10-23-2013)
 Old 10-23-2013, 08:05 AM   #12
Qual1ty's Avatar
After talking to a tuner, he suggested trying a stiffer spring, i knew what to expect if it wasnt going to work with the fluttering and such but I tried every spring and shim setting just to see how things would act. I have the stiffest spring and both shims and didnt get the flutter, idle is good, no stalling, no flutter, backfires occasionally but no check eng. light. So i left it be, if i started to get any of the symptoms above i could just swap it back but so far its been giving me zero issues (knock on wood)
 Old 10-23-2013, 08:18 AM   #13
Bludypoo's Avatar
Posts: 287   (View Stats)
Bludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the world
Also, these cars will always suffer from minor problems even when tuned for VTA. The problem is you can't 100% completely pull the fuel between shifts. A buddy on here was tuned for VTA and recently switched to OEM just for the dyno day and could notice a difference in drivability and response.
Sure it will sound better, but it won't ever run as good.
Bludypoo is offline   Reply With Quote
 Old 10-23-2013, 08:22 AM   #14
Qual1ty's Avatar
yea the shifts arent AS smooth as recirc and driving at a low rpm in traffic I can notivce a light difference.
 Old 10-23-2013, 09:57 AM   #15
A stiff spring will also slow down the valve response since a larger pressure differential is needed to open it.
 Old 10-23-2013, 10:42 AM   #16
Coats's Avatar
Posts: 580   (View Stats)
Coats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the world
Dude I told you weeks ago how to use google to search for your answers and how you could avoid making an ass of yourself on here.
Where is your sig at???
Show up to the meet this weekend and we will help you or GTFO.
2013 Dodge Ram Laramie
GONE 2009 335i xdrive coupe COBB AP V3 CPe DCI
SOLD 2009 FREEKED Mazdaspeed3 GT
Coats is offline   Reply With Quote
The Following User Says Thank You to Coats For This Useful Post:
btstarcher (10-23-2013)
 Old 10-23-2013, 12:34 PM   #17
Qual1ty's Avatar
Dude I work 2 jobs and a kid, no desktop or laptop readily available to use..weekends im working 9a-230a at both jobs and with my kid..searching for answers via google on my phone is not the easiest, i searched here, still had questions so i posted it here. like i said before sorry to bother people with questions i couldnt seem to find answers to. Might as well get off this forum since i cant make the meets like ya'll want me to.
 Old 10-23-2013, 12:37 PM   #18
btstarcher's Avatar
Posts: 4,852   (View Stats)
I can't search from my phone at all. Well not from MSF; I guess I could search from Google and save it as a bookmark....just an idea...
SnailTune in progress
 Old 10-23-2013, 03:57 PM   #19
Mistersix's Avatar
You've got some help here.
Monitor afr's while driving. My would slowly lean out while cruising iirc, and would do the same while idling. The GA pretty much fixed that. The valve just wants to open when there's not a lot of vacuum in the lines.
Qual1ty (10-23-2013)
How-To: MS3 Dual Radiator Fan Experiment Novej MazdaSpeed 3 - How-To's 47 06-04-2016 10:50 AM
TPMS experiment sdiegel5 MazdaSpeed 3/6 - Wheels & Tires 10 08-08-2015 12:40 PM
First logs - stage 1 S-OTS 'experiment' Yatta 2010 MS3 - ECU Computer Tuning 18 04-02-2013 08:27 PM
My failed LED experiment Daddy Exterior 10 01-14-2010 05:58 PM
Did an experiment.. got 32mpg gsrtype1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 24 10-24-2008 03:35 PM
Page generated in 0.40192 seconds with 30 queries
