  • 1 Post By djern
 Old 03-31-2018, 05:42 PM   #1
Clay46's Avatar
Posts: 26   (View Stats)
Clay46 will become famous soon enough
Default What do I need to do to get my car running again with a bnr s3
I just had my stock turbo start to smoke. I wanted to go to a bnr s3 later down the road but I figured since the stock turbo is smoking now I might as well just get the s3 now. I wanted to know what I could do to get the bnr s3 on and running properly without having to upgrade much. Currently I have a fully stock speed 3. I plan on just keeping it around stock power as of now until I can get the money to upgrade more. So what all would I need to do to just get my car running again safely with the bnr s3 with minimal upgrades?
Clay46 is offline   Reply With Quote
 Old 03-31-2018, 07:58 PM   #2
Clay46's Avatar
Sorry, I forgot to mention I have a 2008 speed 3 if that is needed.
 Old 03-31-2018, 09:59 PM   #3
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
I'm going with CS instead.
You will need intake, ebcs, AP, and turbo, this is the bare minimum.
I guess you could technically run the turbo with stock everything and just get a AP + tune.
 Old 04-01-2018, 04:31 AM   #4
Clay46's Avatar
Why are you going with the cork sport over the s3? And through my research wouldn’t I need a coupler to adapt the stock intake to the larger inlet on the turbo? And would I need a new boost controller?
 Old 04-01-2018, 07:58 AM   #5
Police - Grammarhead
Vansquish's Avatar
EBCS = electronic boost control solenoid
AP = Accessport, controls boost via a tune that uses the electronic boost control solenoid.
Stock intake coupler will fit the S3.
To run the S3, you absolutely, 100% must have a custom tune. There is no way to run it without it. You also absolutely need upgraded HPFP (high pressure fuel pump) internals to run the turbo safely.
Clay46 (04-01-2018)
 Old 04-01-2018, 08:44 AM   #6
Clay46's Avatar
Is there a certain electronic boost control solenoid that you would recommend?
The Following User Says NO Thank You to Clay46 For This Un-useful Post:
Vansquish (04-01-2018)
 Old 04-01-2018, 12:45 PM   #7
flyhigh's Avatar
Posts: 218   (View Stats)
Stratified Automotive Controls - Mazdaspeed Forums
The Following User Says NO Thank You to flyhigh For This Un-useful Post:
Hoyoman (04-07-2018)
 Old 04-02-2018, 11:06 AM   #8
flapjack's Avatar
Posts: 121   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
You’ll need upgraded high pressure fuel pump (HPFP) internals as well.
2007 Sunlight Silver Mazdaspeed3
Engine:
\\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\
Tuning:
\\Cobb AP V3\\ Freektune Custom Tune \\
Suspension/Brakes:
\\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\
flapjack is offline   Reply With Quote
The Following User Says Thank You to flapjack For This Useful Post:
Vansquish (04-02-2018)
 Old 04-02-2018, 11:26 AM   #9
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
C'mon bud. This platform has been around for a very long time. All of your questions have been answered. Do some research and you will know what to do with a laser like focus.
I run Grimspeed. There you go. A big 'ol spoonful of info.
The Following 2 Users Say Thank You to Thor Hammer For This Useful Post:
Majin (04-02-2018), Vansquish (04-02-2018)
 Old 04-02-2018, 11:39 AM   #10
Clay46's Avatar
I’ve been researching this since I got the car but I could never find the bare minimum needed to get it to work. Everyone always talks about how they are going for big power right away and how they are going to upgrade everything they can.
The Following 2 Users Say NO Thank You to Clay46 For This Un-useful Post:
Hoyoman (04-07-2018), Vansquish (04-02-2018)
 Old 04-02-2018, 11:45 AM   #11
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
OP, tons of threads on this already. Just search.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 04-02-2018, 12:00 PM   #12
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Not sure about the S3, but the CS turbo works just fine with the stock EBCS.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
The Following 2 Users Say Thank You to Fstrnyou For This Useful Post:
stockms3 (04-02-2018), Vansquish (04-02-2018)
 Old 04-02-2018, 12:01 PM   #13
flyhigh's Avatar
LMGTFY
The Following 3 Users Say Thank You to flyhigh For This Useful Post:
JSmith (04-06-2018), Thor Hammer (04-02-2018), Vansquish (04-02-2018)
 Old 04-02-2018, 02:08 PM   #14
Groans: 211
How long have you had the car? Will you be installing everything yourself?
 Old 04-02-2018, 05:24 PM   #15
Vansquish's Avatar
Look son, if you spent even a few minutes searching, you could've found the "wikispeedia" link.
Try this sub-section: Build Paths and Stages - Mazdaspeed Forums Mazdaspeed 3/6 Wikispeedia
This link is also critical if you decide you're going to get your hands dirty with this vehicle.
ATR User Manual: Hybrid Tuning for Noobs to Early Advanced - Noddy's Guide
Majin (04-02-2018), Thor Hammer (04-02-2018)
 Old 04-02-2018, 06:23 PM   #16
djern's Avatar
Posts: 1,139   (View Stats)
Groans: 27
spoonfeeding people eh? we getting tame lol
Hoyoman likes this.
06 VRM Speed 6 W/Navi
05 Mazda Family Truckster
twitter.com/djern
instagram.com/djern
facebook.com/djern
The Following User Says Thank You to djern For This Useful Post:
 Old 04-06-2018, 08:06 AM   #17
Watchwolf's Avatar
Posts: 11   (View Stats)
Watchwolf is an unknown quantity at this point
You will have to change over less parts if you use the Corksport turbo. HPFP, AP, and tune are a must though, but on the plus side you will needs those for any other mods down the road. Just contact Corksport and they will let you know what you need.
2008 Mica black Mazdaspeed 3
Corksport TIP, K&N Typhoon SRI, JBR 70 Duro Trilogy, CPE TMIC, Autotech HPFP, UR Test pipe, hybrid BOV, DM catch can, NGK one step colder plugs, AP V3,FREEKtuned.
Watchwolf is offline   Reply With Quote
 Old 04-06-2018, 08:27 AM   #18
Fstrnyou's Avatar
Ditto. You can run a corksport turbo with stock everything. Only mods necessary are HPFP and a Tune via AP or VT.
Other rides:
History:
 Old 04-06-2018, 08:29 AM   #19
Clay46's Avatar
I’ve owned it since December and will mostly be doing this on my own.
Best way to tell if your MS6 is running right Braddles Mazdaspeed3/6 General Discussion 6 01-19-2014 06:56 PM
cant get it running matty MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 02-12-2012 03:10 PM
Here's what I'll be running MS3-a(sore)ASS-rex MazdaSpeed 3/6 - Big Turbo Builds 40 11-19-2010 01:53 PM
Running e85? Buildabong MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 29 06-07-2010 11:05 AM
Page generated in 0.38594 seconds with 29 queries
