  • 1 Post By manelscout4life
 Old 05-12-2011, 11:53 AM   #1
02stang951's Avatar
Posts: 250   (View Stats)
02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future
Default yet another turbosmart bov question
so i have searched and read countless pages on how to get rid of the flutter with a turbosmart duel port, i have it set full rec with the spring almost as lose as it will go and still get flutter inless i give it a good amount of gas or hit over 6-7 psi, my main question is is the flutter under low boost or even vacuum bad, some say its not other say it is, so i figure id ask some experts on here. i know its not compressor surge but no one seems to answer that question, im hoping once it breaks it some of the flutter will go away.
thanks in advance for all your wisdom
08.5 true red gt, 35/20% tint, resonators deleted, Tenzo R type M's,Cobb SRI, Hypertech tuned, MSD Dashhawk, SU test pipe, AWR RMM, BC coilovers, Turbosmart duel port bov
02stang951 is offline   Reply With Quote
 Old 05-12-2011, 11:55 AM   #2
boostislove's Avatar
Posts: 128   (View Stats)
boostislove is a splendid one to beholdboostislove is a splendid one to beholdboostislove is a splendid one to beholdboostislove is a splendid one to beholdboostislove is a splendid one to beholdboostislove is a splendid one to beholdboostislove is a splendid one to beholdboostislove is a splendid one to behold
Groaned at 74 Times in 15 Posts
at low psi i do not believe its bad, however when i had a turbosmart dual port in full recir it still ran like shit. if you continue to have problems i would just say get a Forge BPV
2010 ms3 celestial blue!
RIP Jake Guzewicz miss u bro
boostislove is offline   Reply With Quote
 Old 05-12-2011, 11:55 AM   #3
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
take it apart and oil it
I'm running it 50/50 and don't flutter nor backfire
The Following User Says Thank You to manelscout4life For This Useful Post:
rfinkle2 (05-14-2011)
 Old 05-12-2011, 11:56 AM   #4
02stang951's Avatar
should i need to oil it being as its brand new?
 Old 05-12-2011, 11:58 AM   #5
Groans: 661
Mine began fluttering when I got the tip, I adjusted it numerous times and couldn't figure it out. I decided to oil it and it never fluttered again.
 Old 05-12-2011, 12:01 PM   #6
02stang951's Avatar
ok thanks def worth i try i guess, i kinda like the sound but would much rather not fuck something up
 Old 05-12-2011, 12:33 PM   #7
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
BlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the world
Groaned at 32 Times in 11 Posts
or you could just buy a forge like posted above or the HKS SSQV3 bov with recirc kit! i have the HKS and it runs so much better than the Turbosmart Dual port that i had
RichTuned
Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG
11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected
4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected
BlueDmnSpeed is offline   Reply With Quote
 Old 05-12-2011, 12:54 PM   #8
02stang951's Avatar
[QUOTE=BlueDmnSpeed;849350]or you could just buy a forge like posted above or the HKS SSQV3 bov with recirc kit! i have the HKS and it runs so much better than the Turbosmart Dual port that i had[/QUOTE
well i got it for a good price and hate the way the forge sounds ill give it a lil time before i get rid of it as long as i know the flutter is not goin to harm the turbo or anything
 Old 05-12-2011, 01:19 PM   #9
yeah my TS one did the same thing. never had any problems with it. but i have noticed that the HKS holds the boost a lot better than the TS
RichTuned
 Old 05-12-2011, 02:20 PM   #10
Groans: 661
After oiling it up just tighten it all the way and loosen it 2 full turns. That's how I've had mine set from when I was running just an intake to now being fully bolted and I am holding boost no problem.
 Old 05-12-2011, 06:59 PM   #11
02stang951's Avatar
thanks for the advise, i took it apart it looked oiled but i put a little air tool oil on there and put it two turns from loose haven't gotten a chance to drive it, ill let you know how it goes
The Following User Says Thank You to 02stang951 For This Useful Post:
manelscout4life (05-12-2011)
 Old 05-12-2011, 07:02 PM   #12
Groans: 661
Well i tighten it all the way and loosen it too turns, I'm not sure if that's what you meant
 Old 05-14-2011, 02:42 AM   #13
Nikon187's Avatar
Posts: 39   (View Stats)
Nikon187 is a splendid one to beholdNikon187 is a splendid one to beholdNikon187 is a splendid one to beholdNikon187 is a splendid one to beholdNikon187 is a splendid one to beholdNikon187 is a splendid one to beholdNikon187 is a splendid one to behold
The forge version 2 does not make the ping sound. sounds like a regular bpv
2007 CWP mazdaspeed 3 GT, Cobb access port stage 1 sf , Cobb SRI, Cobb turbo inlet, Forge bypass valve V2, One step colder plugs, Sure RMM, Corksport CBE, JBR ssp stage 2, kmd internals version 2 , Spin on oil coversion with sandwich plate, H & R coilovers, 18 x 8 Enkie fujin black, lamin x fog light covers, 35% front 20% rear tint, more to come...
Nikon187 is offline   Reply With Quote
Turbosmart BPV question shpankey MazdaSpeed 3 - Engine, Transmission & Driveline 12 07-15-2010 07:22 PM
Turbosmart 50/50 bpv GFish MazdaSpeed 3/6 - Turbo Induction 5 08-19-2008 04:00 PM
Page generated in 0.31300 seconds with 24 queries
