![]() Join Date: Aug 2017
Rep Power: 0 ![]() Thanks: 38
(Thread Starter) | Not Ranked : 0 score I can't get more than 10psi peak boost. It doesn't sound like I have an air leak but I am thinking that might be the problem. What do you guys think? I attached some logs from a couple short pulls. I went around and tightened up everything I could find but still can't get much boost. 2007 MS6 SRI - CorkSport with K&N filter TIP - CorkSport FMIC - unknown brand, probably ebay special Cobb AP V3 - Stage 1+IC map BPV - CorkSport RMM - CorkSport HPFP - Upgraded internals from Autotech Power Steering Cooler Upgrade - DamondMotorsport |
| Only 10psi | doctavus | Gen2 MS3 General Discussion | 7 | 07-04-2013 01:24 PM |
| only reading 10psi | 2006MS6 | Mazdaspeed3/6 General Discussion | 18 | 03-03-2012 04:24 AM |
| Installed CAI and now only have 10psi of boost | dbrier | MazdaSpeed 3/6 - Turbo Induction | 2 | 06-08-2009 01:57 PM |
| Only boosting 10PSI ?? | glocK23 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 05-18-2009 02:35 PM |
| took off mbc and only seeing 10psi | b-ron | MazdaSpeed 3/6 - Turbo Induction | 2 | 07-29-2008 11:01 PM |
