![]() Join Date: Dec 2011 Location: Orland Park il
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 99
(Thread Starter) | Not Ranked : 0 score First off disconnect your battery IMG_4145.JPG then remove your battery and intake IMG_4146.JPG pop off the cables IMG_4149.JPG this is right by the turbo IMG_4150.JPG then you go inside and start removing the center console and radio 20131217_194813.jpg 20131217_194817.jpg if you need help in this part i can get pics on that too after that just pop off the cables same way you did before Next pull the carpet back so you got room to work with and unplug the box and there are three bolts holding it down one on the drivers side and two on passenger 20131217_185946.jpg you also gotta shift the plugs and the vents going to the rear so you can maneuver the plate out 20131217_170309.jpg if you want you can cut a patch out off the plate or attempt to move it aside your choice 20131217_192224.jpg 20131217_192235.jpg I couldn't get the pics of where the bolts are but if you get a descent sized 10mm wrench you could loosen the nuts and back them by hand barely and torque on them at this part you should probably have a friend help you here pushing the cables through find the way you do best and not crack the hvac case and have a huge hole lol (my mistake) IMG_4152.JPG after you get it out get yourself a beer the hard part is over and the easy part begins IMG_4153.JPG then just do everything in reverse order and done!
__________________ GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port |
| The Following 15 Users Say Thank You to ciezczak1 For This Useful Post: | 6Y MAZDA (02-13-2014), AzS13 (09-18-2016), Badlstar75 (08-06-2014), Bleupit80 (01-12-2014), Cheapspeed (12-22-2013), Code Monkey (12-22-2013), Enki (12-09-2015), Fail_6 (02-08-2014), jm211 (12-22-2013), Micha (02-11-2014), Nliiitend1 (12-22-2013), nybe0010 (12-11-2014), Playaj (12-21-2013), Raider (08-06-2014), WetzMS3 (12-27-2013) |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score Awesome, happy to see we can avoid gutting the interior. Much appreciated.
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
| The Following 2 Users Say Thank You to jm211 For This Useful Post: | Badlstar75 (08-06-2014), ciezczak1 (12-24-2013) |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score Are those stock shifter cables? I have a TWM full replacement and I'm wondering if I should pick up some shorter cables because right now it forces the stock cables down to the floor, so they're curved. I've heard about people having kinked cables because of this.
__________________ 3rd rebuild on the way...maybe... |
(Thread Starter) | Not Ranked : 0 score yeah they are stock not sure the speed6 has aftermarket cables for you swapping them should take the most 3 hours bc you got speed3
![]() Join Date: Aug 2012 Location: State College, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 987
| Not Ranked : 0 score I know I'm late on this one, but that's awesome that you did that without (like mentioned above) gutting the entire dash. How much did you get the new shifter cables for and where? If you don't mind. I've been needing some and I think I found the right part, but it's about $260. Just wanted to double check @ciezczak1;
__________________ 2006 Mazdaspeed 6 (Titanium Gray) : Built, gtx2867r Purple Drank tuned 12.07 @ 116 on 205 snow tires hunting for 11's on 245's |
| Not Ranked : 0 score Sounds about right for price, unless used. Also, for the dude above, @Cheapspeed; no aftermarket is available.
| The Following 3 Users Say Thank You to jm211 For This Useful Post: |
Sent from my SGH-T989 using Tapatalk 2
__________________ GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port | |
| The Following User Says Thank You to ciezczak1 For This Useful Post: | DVM17 (12-27-2013) |
Awesome, thanks guys.
__________________ 2006 Mazdaspeed 6 (Titanium Gray) : Built, gtx2867r Purple Drank tuned 12.07 @ 116 on 205 snow tires hunting for 11's on 245's Last edited by DVM17; 12-27-2013 at 09:06 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to DVM17 For This Useful Post: | jm211 (12-27-2013) |
![]() Join Date: Mar 2011 Location: Newport News/Yorktown, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
| Not Ranked : 0 score This is exactly how I changed mine about a year ago. I kept reading that you had to take the entire dash apart and I was determined that I wasn't going to do that. And I didn't.
__________________ 2006 Whitewater Pearl Mazdaspeed 6 GT #355 FJ BUILT LONG BLOCK BNR S4 JBR TRU 3" SURE BOOST TUBES JBR SSP JBR CHROME MOLLY RMM COBB AP AUTOTECH HPFP INTERNALS EBAY DP 3.5 BAR PURPLE DRANK TUNED![]() WAITING TO BE INSTALLED PROSPORT EVO BOOST GAUGE TR1035 w/ CXRACING PIPING JMF INTAKE AWR PASSENGER MOTOR MOUNT AWR TRANSMISSION MOUNT |
| Not Ranked : 0 score I actually rigged mine with zip ties and drove like that for about 3 months...lol. My cable wasn't snapped I just broke the plastic sleeve under the rubber boot by the end of the cable because I installed the JBR SSP and didn't put in the spacers that go under the bracket...lol.
| The Following User Says Thank You to Bleupit80 For This Useful Post: | 6Y MAZDA (01-19-2014) |
![]() Join Date: Jul 2012 Location: Aberdeen, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 313
| Not Ranked : 0 score Just did the shift cables over the weekend. A few notes that people doing this in the future might find handy:
Thanks to @ciezczak1; for answering the questions I had, including a particularly stupid one about a clip. Big thanks to @Ryguy; for coming by to help despite his desire to burn my car to the ground.
__________________ |
![]() Join Date: Nov 2010 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score i'm so glad this write up was done. i'll be attempting this soon. my zip ties are only holding a couple months at a time.
__________________ 07 MS6 Sport............. ![]() JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals * |
| The Following User Says Thank You to weakdog85 For This Useful Post: | ciezczak1 (02-08-2014) |
![]() Join Date: Jul 2011 Location: Danvers, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,418
| Not Ranked : 0 score Very good write up, indeed I did end up using your method. With a machine shop and 30 hands at your disposal, it really is quite easy. Only thing missing was pictures of the actual area you're working, the nuts and what not, which I have below. Start to finish, first pic is the actual plate on the cables held down by the 2 10 mm nuts, next a close up of the plate, next the nuts themselves, next sliding them out, next the opening left when they're out and finally using the pry bar to get the new ones in. Couple necessary tools, 10 mm racketing wrench, powerful magnet (for when you drop the nuts trying to put them back on lol), a pry bar to create space and a shit load of patience. Also, be careful with the airbag module (3 yellow plugs and gray box), and I opted to remove the metal clip on the rubber "holster" for the cables, it's easier sliding them in 1 at a time vs both thru the tiny ass opening. Working diligently, this can be accomplished in a little over 1 hr 30 mins, no dash removal necessary, only the center console. @ciezczak1; Thank you again for the blueprint!
__________________ 2006 Black Mica MS6 GT FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob Stock motor w/ GT2871r: 380 awhp, 375 awtq @ 24 psi (e85 only) ![]() - 13.1 @ 110, 2.1 60 ft |
![]() | Not Ranked : 0 score I'm changing mine out right now...good right up. |
| Not Ranked : 0 score Let us know how it goes an add any advice you may have "Tap tap tap it in"
| The Following User Says Thank You to weakdog85 For This Useful Post: | Fail_6 (02-14-2014) |
(Thread Starter) | Not Ranked : 0 score If you have any questions pm me and ill get back to asap Sent from my SGH-T989 using Tapatalk 2
![]() | Not Ranked : 0 score Well...I got the shift cables changed out with the help of a buddy of mine. ciezczak1 thanks for the how to. It helped me out greatly. |
![]() | | #19 | ![]() |
| Not Ranked : 0 score So about 4 hours or so? "Tap tap tap it in"
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Well that is very good to know "Tap tap tap it in"
![]() | | #22 | ![]() |
![]() Join Date: Sep 2011 Location: Lacey wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score Omfg I payed a shop to do this last year cost me an ass load of money. If I knew that I could have done it like this would have saved that money for go-fast shit. A+ Sr like u said long needed how-to.
![]() | | #23 | ![]() |
| Not Ranked : 0 score And Done!! Well that was not a fun job at all. Getting the cables out wasn't too bad. It was getting the plate back over the studs. then trying to get the nuts back on the studs that was the bitch. With the sharp plastic pieces hanging down i cut both hands all to shit. My only advice for this job would be when trying to get the nuts back on, use an extension magnet, have one person hold the nut over the stud with the magnet and the other screw the nut back on. another bit of advice, don't ever break one of the white pieces that go inside the ends of the cables that go over the ball. we spent another hour breaking out one off the old cables and shaving it down to fit in the new cables. The mechanism is pressed together and glued so there is no taking it apart easily. this how to definitely saved us a lot of time though not having to tear the dash apart.
![]() | | #24 | ![]() |
| Not Ranked : 0 score Doing this now.... have the center console and head unit off. Have the cables disconnected from the transmission and from the shifter as well as the rubber grommet by the turbo and I'm stuck on the stupid bracket. Can't even see it. Do you need to just put a wrench up there and hope it gets on the nut? Lol.
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Pretty much lol but you should see it if you found the plate Sent from my SGH-T999 using Tapatalk
| The Following User Says Thank You to ciezczak1 For This Useful Post: | DVM17 (03-04-2014) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score If you clear enough sound deadening and carpet you should be able to see the driver side nut easily. Passenger side is more of a feel around game "Tap tap tap it in"
| The Following User Says Thank You to weakdog85 For This Useful Post: | DVM17 (03-04-2014) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Thanks for the insight of this thread guys! Got it all buttoned up last night and I couldn't be happier. ALL of my previous issues that I assumed was the shifter cage, was actually the shifter cable. So now it's crisp and notchy. didn't take the dash out, just cut back a lot of the insulation as suggested and got the stupid bracket on the studs. (took forever) but now at least I have really good shifts. Coupled with my twm STS and jbr ssp, it's amazing. Thanks Again!
![]() | | #28 | ![]() |
![]() Join Date: Sep 2012 Location: Buffalo ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Thanks for this....I need this done asap and didn't want to remove the dash lol |
| The Following User Says Thank You to Stealthvr4 For This Useful Post: | ciezczak1 (05-10-2014) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score You are lucky to have this thread I need up paying for mine SENT FROM THE DEATH STAR
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'd help install it if close or bring it to my house Sent from my SGH-T999 using Tapatalk
![]() | | #31 | ![]() |
| Not Ranked : 0 score Ended* this was a year ago SENT FROM THE DEATH STAR
![]() | | #32 | ![]() |
| Not Ranked : 0 score My shifter cable broke in the same spot I used 4 zip ties to hold it together for a longterm quick fix lol feels great |
| The Following User Says Thank You to Stealthvr4 For This Useful Post: | Bleupit80 (05-16-2014) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score It's going to break theirs no long term fix for this other than just doing it SENT FROM THE DEATH STAR
![]() | | #34 | ![]() |
![]() Join Date: Mar 2013 Location: Va Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score i've had to this twice and i got it done rather quick with some help but i wanted to know if a lot of people are having problems with theirs. I blame the JBR SSP i had because i owned the car for over two years before i even put that thing on and never had issues. Still love JBR though. |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah my shifter cable broke bc of the jbr adjustable shift plate sent from the s5
![]() | | #36 | ![]() |
| Not Ranked : 0 score Mine broke because I DIDN'T install the two spacers that raise the brace with the JBR SSP. I swapped out my cable without taking the dash out and installed the spacers and haven't had a problem yet.
| The Following User Says Thank You to Bleupit80 For This Useful Post: | ciezczak1 (07-23-2014) |
![]() | | #37 | ![]() |
![]() Join Date: Aug 2014
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score Just ordered the cable today, hope it gets here quick. Cost was $325.00/w shipping. Local dealers wanted $374.00 plus tax. Hope replacing it isn't to difficult |
![]() | | #38 | ![]() |
| Not Ranked : 0 score Well it will be. Just take your time and cut away as much sound deadening as possible
![]() | | #39 | ![]() |
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I have ordered my cables today. So are you pushing the cables from inside the car through the hole or pushing the cables from the engine inside the cabin? |
![]() | | #40 | ![]() |
![]() Join Date: Sep 2013 Location: Valrico FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 475
Groans: 51
| Not Ranked : 0 score when removing the cables they come into the cabin. when installing, start in the cabin and push through. I highly recommend having at least a second set of hands under the hood to help guide the cables
__________________ 2006 TITANIUM GREY METALLIC MS6 SPORT Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs |
| The Following User Says Thank You to Hargarbl For This Useful Post: | Bleupit80 (01-10-2016) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-change-your-shifter-cable-161362/ | ||||
| MS6 shifter seized in neutral? - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 10-17-2015 05:29 PM | |
| MS6 shifter seized in neutral? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 10-16-2015 05:40 PM | |
| adjusting Shifter Cable's | Boo5ted | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 10-02-2013 01:56 PM |
| Help please. Broken shifter cable? | J'sSpeed3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 09-05-2012 05:34 PM |
