![]() | | #41 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score fast forward to last weekend... @SpeedEngineer; and i did his valves using this method. here are my notes to help others: 1) use the gun mentioned in the OP vs the other media blaster gun available at HF that is a suction feed. it is useless. 2) we used a 15 gal compressor this time. it worked just fine. it's only a 1.5 hp motor, though, so it took a little time to fill up between valves. we also ran at about 95-100psi operating pressure. 3) we soaked 6 of the 8 valves. we used the vacuum and compressed air to drain them before blasting. 4) we did not soak the last set of valves, and they came out as clean as the soaked valves. i would contend you do not need to soak if you're using a media blaster. but, again, we used it at a pretty high pressure. 5) all valves required a little scraping to get 100% clean. this is the gun i bought originally (last year with my small compressor and then again this year) this gun is terrible! don't use it. it won't work. this gun is what we used with success. we did, however, tape the lid closed because that lid is just about useless. edit/ and smelson, too. he showed up and helped. /edit
__________________ it's fun to do bad things Last edited by jack_hammer; 07-16-2013 at 10:31 AM. |
| The Following 4 Users Say Thank You to jack_hammer For This Useful Post: |
![]() | | #42 | ![]() |
![]() Join Date: Jan 2013 Location: Arlington Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,474
| Not Ranked : 0 score I concur Sent from LOL
__________________ 2010 MS3 GenPu Blue Mica ![]() ETS TMIC | ATP 3" Downpipe | OBX Catback | HTP 3" Intake | 3 Bar MAP Senosor | Cobb Accessport | CorkSport Battery Box | JBR Shift weight| JBR 88 duro RMM | JBR 88 duro TMM | JBR 80 duro PMM | JBR IM and TB TIGS | JBR Boost Tubes | Forge V1 | SSP Full EGR Delete | Balance Shaft Delete | Iridium one step colder sparkplugs | Autotech internals | Koni Yellow Shocks and Struts | Swift Springs | Defi Boost Guage | DDM 6000k 55W Headlights | 5000k 35W Fogs 4 GAL E85 CORN BY THE FREEK Blue 2011 Triumph Daytona 675 Triple |
![]() | | #43 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 253
(Thread Starter) | Not Ranked : 0 score @jack_hammer; @SpeedEngineer; So basically you are saying to just follow the instructions lol (well, plus a little scraping)Glad you got cleaned! |
| The Following User Says Thank You to mczimer For This Useful Post: | TiGraySpeed6 (07-16-2013) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score lmao yea these instructions are great
![]() | | #45 | ![]() |
Groans: 549
__________________ it's fun to do bad things | |
![]() | | #46 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score The b12 does work great....the soaking is not needed though. The B12 came in an aersol bottle. Spray some on there, use the gun cleaning kit, soak up shit with papertowel, air dry with compressor, then blast. 5 minutes per valve this way.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #47 | ![]() |
![]() Join Date: Nov 2011 Location: Garden Grove, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 209
| Not Ranked : 0 score Waiting for b12 and gun cleaning kit to come in. If the 3 gal compressor doesn't cut it then manual it is. Great instructions. thanks
__________________ FYHN except Odyssey's. Ody's are bad-ass 1996 Acura Integra HB Sold 1998 Acura Integra GSR Sedan Sold 2008 Honda Pilot Sold 2006 Honda Accord Sold 2008 Honda Odyssey 2007 MS3 Silver Sport Cobb AP SRI TIP // CNT DP // JBR SSP Bushings Knob RSB // CPE TMM // SU TMIC // AT INTERNALS // MD OCC RMM // NGK // Bilstein B8 // Swift Springs // Evo 9 wheels // SPC camber arms Freek tuned 91 and 3 gal E85 [SIGPIC][/SIGPIC] |
![]() | | #48 | ![]() |
| Not Ranked : 0 score valves clean as much as Icould with gun cleaning kit. definitely need way bigger than 3 gal compressor. gotta be careful removing vacuum actuator arm. I broke the white plastic piece so ended up deleting vtcs. great instructions
![]() | | #49 | ![]() |
| Banned ![]() Join Date: Jun 2012 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
Groaned at 6 Times in 4 Posts
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score I do not see the point in removing the VTCS plumber, you have access to bolts without a problem, and it is one less thing to worry about breaking. |
![]() | | #51 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
Sent via blown passenger side speakers.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() | | #52 | ![]() |
| Not Ranked : 0 score absolutely right. That's all you need to do. I was following jbarone's TIG instructions that mentioned using a flat head screwdriver to remove the actuator arm from the ball. Don't do it, you will break the stupid molded plastic arm. And i just using a little masking tape to tape the spacer to the IM on bolt 8 and just pulled the tape once the bolt was threaded. I did something else differently that i am blanking on too
![]() | | #53 | ![]() |
![]() Join Date: May 2009
| Not Ranked : 0 score Did you guys use course or fine walnut media? Search results for: 'walnut media' Nice pic showing different walnut media sizes: http://www.kramerindustriesonline.co...comparison.htm 2 gaskets yes? EGR to block and intake manifold to block. Last edited by Lex2007; 09-11-2013 at 01:14 PM. |
![]() | | #54 | ![]() |
| Not Ranked : 0 score I used HF-fine media. As for gaskets - installed 1/8" teflon one for intake manifold and EGR was deleted with JBR kit. |
![]() | | #55 | ![]() |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score I did mine last weekend with an identical gun to the one in the OP using my 11gal compressor, which worked excellently; I could blast two valves for about 20 seconds each before the pump cut in. I cleaned up some hard spots using a screwdriver, wooden skewer and a 12gauge wire brush in my drill. Honestly, the brush/drill did a better job than the walnut after soaking it for a few minutes, but couldn't reach everywhere. I got my walnut media at a pet store; it's sold as reptile bedding. For solvent, I tried denatured alcohol, then seafoam, then methanol; none of it did very much... so I tried some stuff from work - LPS "CFC Free" solvent. Shit is amazing, and completely cut through the carbon in minutes. LPS is a common brand so if you can find this shit, try it out.
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
![]() | | #56 | ![]() |
| Not Ranked : 0 score Looks great! Does LPS solvent evaporate on its own? What was the hardest part of the job? Removing the manifold? EGR removal? Did ya reuse those 2 gaskets? I need to prep for the same job...which is why I ask. Figure I will clean the EGR ad PCV while I am at it. |
![]() | | #57 | ![]() |
Groans: 56
| Not Ranked : 0 score Yeah it evaporates just as quick (if not quicker) than methanol, so if someone was planning on letting it soak for a while they'd have to tape over the port or something. I only let it sit for about 10 minutes so it wasn't an issue. Nothing about the job was difficult; just time consuming. Download the instructions for the JBR gasket and follow those and you'll be fine. My EGR was gone a month after I got the car so that wasn't an issue. Not sure which gaskets you're referring to... I have the insulating gaskets for the manifold and throttle body, which I reused. Like I said, my EGR is blocked off so there is no gasket to worry about there. Actually, my old EGR gasket is currently the gasket on my oil return line from the turbo lol. I should also add that after cleaning the valves I installed a ported manifold and sealed a crack in my intercooler. I have no idea what did it, but I'm seeing a very large increase in fuel economy now.
![]() | | #58 | ![]() |
| Not Ranked : 0 score [QUOTE=BigRedSpecial;2251056]Yeah it evaporates just as quick (if not quicker) than methanol, so if someone was planning on letting it soak for a while they'd have to tape over the port or something. I only let it sit for about 10 minutes so it wasn't an issue. Nothing about the job was difficult; just time consuming. Download the instructions for the JBR gasket and follow those and you'll be fine. My EGR was gone a month after I got the car so that wasn't an issue. Not sure which gaskets you're referring to... I have the insulating gaskets for the manifold and throttle body, which I reused. Like I said, my EGR is blocked off so there is no gasket to worry about there.QUOTE] I refer to the gaskets you mention above. EGR and intake manifold. Doesnt apply since youre using Barone racing gaskets. |
![]() | | #59 | ![]() |
Groans: 56
| Not Ranked : 0 score I'd definitely disable your EGR if I were you. That's a big source of the crap on the valves. If you're in an emissions state, you can simply unplug the actuator. Just plug it back in before testing time.
![]() | | #60 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score Yeah unplug and take the codes out with the AP. EGRs are a nasty source of crap in the intake runners. If you are going to get some thermal insulator gaskets, then also get the EGR delete kit because I know when I installed my 1/8" gaskets, they made it near impossible to hook up the hard pipe from the EGR to the IM.
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
![]() | | #61 | ![]() |
![]() Join Date: Jul 2009 Location: Baltimore, MD
Rep Power: 253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 157
| Not Ranked : 0 score Anyone in Baltimore Maryland area who would be willing to provide this service for a fee?
__________________ 2009 MazdaSpeed3 | True Red 35% Tint CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC |
![]() | | #62 | ![]() |
![]() Join Date: Nov 2012 Location: North East
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
Groaned at 29 Times in 14 Posts
| Not Ranked : 0 score Just done did it. Went from this: To this: To this: Highly recommend using a wire brush to scrape off anything on the valve edge and valve seat in the head, as well as that gunk on the top of the valve stem as the last part of the process. You'll have to bend the brush as in the above pic to get to the edges that are close to you, but it comes out great. If any brush bristles get into the cylinder, you can blow them out with compressed air through the spark plug hole. Lesson for the kids - don't run VTA BOV's - that engine only had 15k on it, w/3k being run as VTA. It gunks shit up. OCC and EGR disconnect should help stay clean for another 70-90K, as it's not a fun weekend doing this stuff. Also, found a potential EGR blockoff plate: ![]()
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ Last edited by BAT-man; 10-22-2013 at 05:55 PM. |
![]() | | #63 | ![]() |
| Not Ranked : 0 score If you want one of those block off screw in plates I have a spare one. Send me a PM.
![]() | | #64 | ![]() |
Groans: 255
| Not Ranked : 0 score Meh, those valves were fairly clean to begin with. Now mine had chicken pox blisters growing all over the valves, haha.
![]() | | #65 | ![]() |
| Not Ranked : 0 score Lol, but this is only after 15k! Imagine the poor shmucks running VTA for like 20kmiles. Its prolly no longer a valve, just a cylinder shaped disgusting crusty monolith going in and out of that runner. no pun.
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ |
![]() | | #66 | ![]() |
Groans: 255
I have cleaned some valves at 60k, 70k, and 85k with no EGR delete or OCC attached that were in similar shape.
![]() | | #67 | ![]() |
| Not Ranked : 0 score So, I'll bite. What's your logic path that leads you to conclude running VTA causes carbon build up on the valve stems? Simply saying "Ive got carbon, and I ran VTA, therefore running VTA causes carbon build up" is false logic. Not washing fuel over the valves, or a constant meth bath, is what allows the carbon build up. It's a well know trait of all DI engines, turbo or not.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | phate (10-22-2013) |
![]() | | #68 | ![]() |
It's hard to completely tune out the effects of running your BOV VTA or even partial VTA. With DI engines, the main effect is that you constantly run extra rich between shifts and the soot accumulates on the valves much faster than during non VTA operation, especially if you don't disable EGR, which recirculates that extra sooty exhaust into the intake and doubles up on the grime. Hence the above comment that some 60K engines were as dirty as this 15k one. Point being that the lack of an OCC alone should not have had this kind of effect on the valves at 15k. On regular FI cars the washing over the valves with fuel will remediate the situation, but it's still a possible issue, probably more with exhaust valves, if you don't beat on the car and let the heat/pressure do some cleaning. that's the logic, take it or leave it.
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ | |
![]() | | #69 | ![]() |
| Not Ranked : 0 score Gosh, so running VTA is like a vacuum leak? Wow, who knew. SMH My point was that there isn't enough of a variance in the backflow to treble the amount of buildup, especially when there is so little overlap and so little time for it to have an effect- less than 1% of overall run time, perhaps 5% if you live in rush hour, stop n go traffic. During shift points there is enough of both overall air flow and turbulence to prevent the back flow from being able to settle enough for any significant impact. Things settle at idle speeds, but again the amount of time spent at idle is insignificant in terms of engine hours. So, is there an impact from VTA? Minor at best. Your build up is from other sources. Some build up more, some less. It varies on qulaity of fuel, driving style, mods, condition of turbo, OCC and, if installed, it's quality & effectiveness, EGR etc etc.
![]() | | #70 | ![]() |
| Not Ranked : 0 score To me, it seems that the EGR recirculating extremely rich VTA shift mixtures would do the trick. Why the backflow turbulence (I assume you mean EGR) would be any different during shift points as compared to any other time, in order to NOT affect extra rich mixture deposits settling, is not clear to me. All I can tell you is that I've looked at the valves with a boroscope as I was doing the FMIC install and they weren't dirty at all (car had 10k miles) and then at 14-15k, they are suddenly very dirty after having run VTA for 3k+ miles. Bear in mind that the intake was not changed (stock TIP/MAF/filter), the targeted AFR's for cruise and WOT were leaner (logged AFRs confirm this), and stock oil recirc was used (no OCC's). A car doesn't just start randomly building up gunk over 3-5k miles when no other variables other than the BOV venting change (the mere switch from TMIC to FMIC won't affect the condition of increased valve pollution). I guess you could disprove what I've observed by giving me an example of a similar situation where the outcome was different - clean valves w/no VTA and then 3-5k of VTA and still clean valves. That would make me reconsider my conclusion. For now, I guess we'll both stay where we are. I'll just say this - it's not in my interest to prevent folks from running VTA, ricer as it may be, I love the sound and would have kept it, but my valves being clean is more important to me. I run VTA on my race car for the simplicity of plumbing and my ability to tune out the rich-between-shifts condition (the one thing that the Haltech e6k can do that the AP somehow makes very complex). To each their own.
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ Last edited by BAT-man; 10-22-2013 at 05:54 PM. |
![]() | | #71 | ![]() |
| Not Ranked : 0 score I don't mean EGR- EGR only operates for a limited period of time anyway. Alas, when it runs it's like mainlining cancer right onto the valves. You were referring to the deposits building up in excess during the window when the intake valve is open, or the back flow of deposits from the cylinder back up onto the valve stem. Bear in mind that the accumulation of deposits on the stem is a geometric growth- the more there is, the faster it grows. Listen, you do present like an intelligent human, but I don't have any other source to back your theory at this point and between the geometric increases of carbon buildup and the small percentage of valve overlap I just don't see it. I do have an engine that's only seen the clean life - with an EGR delete, a MD OCC and good clean fuel in an e32 blend. It's only got 3K on it tho, so results won't be in till next year. Other folks will be quick to voice an opinion tho, could be I'm completely lost.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | BAT-man (10-22-2013) |
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score Am I the only one who noticed he scrubbed the valves with them OPEN? |
| The Following User Says Thank You to mczimer For This Useful Post: | jm211 (10-23-2013) |
![]() | | #73 | ![]() |
| Not Ranked : 0 score You soak/blast/mostly clean them while closed, but to get to the edges of the valve (as described in the post) and valve seats, you have to open them. There is only a small amount of debris that would go into the cylinder during this stage, and it can be blown out with the air hose/burned off easily. The purpose behind cleaning the valve edges and valve seats is to ensure a good seal which may be compromised by gunk deposits on those surfaces that you cannot remove when cleaning the valves while closed. You also cannot get to the gunk pictured at the top of the stem without the valve being open, as the gunk sits flush with the valve bore when the valve is closed. End results in the cylinder were checked with a boroscope as well, all was clean.
![]() | | #74 | ![]() |
![]() Join Date: May 2012 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Wear eye protection when using the B12!!!! I forgot to put the goggles on and even though I used a hand pump to get rid of the fluid, there is some you cant get. When you blow the air out, even with a towel over it, some fluid will come out. I didn't have my rag over the valve runner all the way and blew B12 and carbon all over my face and into my eyes. Everything went black and I thought I was blind. Worst pain in my life. 45 minutes of flushing with water and I could see again. My eyes hurt for a day or so. Needless to say, I wear eye protection whenever working with any kind of fluid now.
__________________ Fuck MSF |
| The Following User Says Thank You to avesfan101 For This Useful Post: | lilred (11-15-2013) |
![]() | | #75 | ![]() |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score Temporarily blindness and bloody nose in my case lol. B12 staing headlights is my constant reminder to not be stupid lol tapafuck
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
![]() | | #76 | ![]() |
Groans: 255
![]() I also reccomend removing the serpentine belt before cleaning because the walnut media will imbed itself into the grooves and will slowly tear apart the belt.
![]() | | #77 | ![]() |
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
![]() | | #78 | ![]() |
| Not Ranked : 0 score I have a boroscope and used it to peek into the cylinders to make sure nothing was left in there. I wouldn't be concerned with gunk in the cylinder, as I would be with any of the brush hairs. which is why perhaps using plastic brushes may be safer. I do believe that using copper should be ok as well, since it's softer than both the rings and the cylinder walls.
![]() | | #79 | ![]() |
| Not Ranked : 0 score Also a good spray of the air compressor into the cylinder could help to clear that up.
![]() | | #80 | ![]() |
![]() Join Date: Jul 2013 Location: Croatia/Split
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score Just done valve cleaning, along with IC, manifold and throttle body wash. For everyone who haven't clean his valve yet, look at almost free 40WHP gain, get the job done ASAP ![]() Mine 6s is 95.000miles
__________________ Cobb AP V3 Stratified tune Autotech HPFP internals M2 DP JBR PowerPath stg II Sure RMM Sure Rear Diff Mount TurboXS 50/50 Grimspeed EBCS NGK Iridium step colder Ebay OCC EGR delete 3BAR MAP w/ Harness 3" CBE w/ high flow mufflers Eibach -35mm 18x9 JapanRacing JR3 w/ 235/40/18 Kumho KU39 Last edited by jucca; 12-20-2013 at 03:25 AM. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-clean-your-valves-easy-cheap-120237/ | ||||
| Cleaning the MZR (DISI) of Carbon w/ Walnut Media Blaster - Some Questions : mazda | This thread | Refback | 10-31-2014 12:56 PM | |
| HOW TO: Clean your valves - easy & cheap | mczimer | MazdaSpeed 3 - How-To's | 56 | 05-11-2018 08:52 PM |
| HOW TO: Clean your valves - easy & cheap | mczimer | MazdaSpeed 3 - How-To's | 77 | 04-16-2016 04:57 PM |
| how to: clean your valves vol 2 | dooderek | MazdaSpeed 6 - How-To's | 36 | 09-12-2015 08:41 AM |
| how to clean your valves vol 2 | dooderek | MazdaSpeed 3 - How-To's | 41 | 03-16-2014 08:03 AM |
| HOW TO: Clean your valves - easy & cheap | mczimer | 2010 MS3 - How-To's | 28 | 01-24-2014 04:21 AM |
