![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
(Thread Starter) | Not Ranked : 0 score I think this will be a problem many people will start to have as they reach 100k. If you find a rod this is how you can repair the handle:New handle part # is D35062410B can be had for ~$30 + shipping or $36 shipped on ebay Parkmazdaoemparts.com has free ship on over $200 so even though part prices are a bit more if you can get free shipping it still costs less thru them. Remove trunk release handle:
* I repaired mine. You just need a rod with 4mm (5/32"=0.15625") OD that is about 100mm (4") long or m4 or 5/32 threaded rod see if you have a cheap screwdriver that has the right OD... IDK if 15 (part # B45558411) is just the spring or the spring and rod or what: 2006 Mazda 6 Parts - Discount factory (OEM) Mazda parts and accessories at Park Mazda OEM Parts This should work:
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB Last edited by aviator79; 10-20-2015 at 10:46 AM. |
| The Following 5 Users Say Thank You to aviator79 For This Useful Post: | dan7225 (10-23-2015), KingOfSpades007 (11-15-2015), Poohster (11-08-2015), rob ms6gt (10-20-2015), Vansquish (10-23-2015) |
![]() Join Date: Oct 2014 Location: Fairlawn , OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score Toooooooo much work, I fixed the problem by simply washing out the handle area, then spraying silicone lubricant up near the springs on either side, the working it in by rocking the handle back and fourth until it got smooth.. Did mine several months ago and still works as new now. Before the handle would not "return" after pulling it to unlatch the trunk.
__________________ -93 Miata Turbo Greddy manifold/turbo 18psi 15x8 6UL's Dunlop Direzza dz101 Kyb/FM suspension FM sway bars 949 racing adjustable endlinks Torsen swap -2007 MAZDASPEED6 GT Ti Gray 55k miles #10026 Cobb AP V3, Cobb SRI/TIP, SU TMIC, AWR RMM , Magnaflow CBE , Forge BPV , TWM Shifter , Denso ITV22, Jugg/Dread |
![]() Join Date: Oct 2008 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 603
| Not Ranked : 0 score Thanks for "how to do" Did mine today.
__________________ 06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP RPM: Sport Springs, Shark Fin, LED side markers CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount |
| The Following User Says Thank You to Poohster For This Useful Post: | aviator79 (11-13-2015) |
![]() Join Date: Apr 2017
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hi! Does D35062410B fit regular Mazda 6 (2006-2007) aswell or only Mazdaspeed? I'd say they're the same but I'm not expert. |
| Driver interior door handle cable broken - NEED PART NUMBER | BenWhitney | Mazdaspeed3/6 General Discussion | 10 | 08-28-2019 05:38 PM |
| Trunk latch stuck | Jsayre88 | Mazdaspeed3/6 General Discussion | 10 | 07-19-2014 07:39 AM |
| Fuel Cap Stuck/Broken | Deblaca | Mazdaspeed3/6 General Discussion | 11 | 06-02-2014 06:21 AM |
| Toyota to alert customers about trunk-release defect | Haltech | Automotive News | 0 | 12-12-2012 02:00 PM |
| 06 MS6 Sport...remote trunk release? | SpeedS1X | MazdaSpeed 3/6 - Car Audio & Electronics | 8 | 05-12-2010 04:02 PM |
