> MazdaSpeed 6 - How-To's
Like Tree31Likes
 Old 08-14-2014, 01:14 PM   #81
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
Right, but what units is the distance in? Because both 65,77 x 1 and 296 x 0.22222 is the same "slope" so which is more "right"?
mrQQ is offline   Reply With Quote
 Old 08-14-2014, 01:30 PM   #82
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
If you do the math you will never have a scalar B = 1. So IMO that's always the wrong value.. x = voltage , y = boost in Kpa
Logically if a 1 was acceptable the engineers at Mazda would have just eliminated an unnecessary variable from the code..
 Old 08-14-2014, 02:51 PM   #83
mrQQ's Avatar
well, ax+b=0 fits any given linear expression. So there is only one multiplier in that, and you can define any slope you want with it.
a = slope
b = offset
so what is one more doing in there? esp since judging by everything they are simply being multiplied with each other.
The Following User Says Thank You to mrQQ For This Useful Post:
SSinstaller (08-14-2014)
 Old 08-14-2014, 02:59 PM   #84
Groans: 60
I honestly have no idea what the ECM is doing with Scalar B, but from personal experience and everything I've seen on here--regardless of which MAP sensor you're running it's more accurate when scalar b ≠ 1.
 Old 08-14-2014, 03:02 PM   #85
mrQQ's Avatar
So what is more accurate:
43.85 and 1.5
6.577 and 10
131.54 and 0.5
3288.5 and 0.02
because in the end they all describe exactly the same "slope".
 Old 08-14-2014, 03:26 PM   #86
Groans: 60
If your only worried about the slope they're all equivalent. But were not dealing with a line extending to infinity in both directions...
If I had to guess as to the actual purpose of Scalar B it would to place limits on the sensor range.
 Old 08-14-2014, 03:30 PM   #87
mrQQ's Avatar
That's exactly why I asked what is B used for.. till we know, we're just guessing.. has anyone ever proven that it matters? Till not, 1 is as good as anything else..
 Old 08-14-2014, 03:35 PM   #88
Groans: 60
I know in my car my AEM sensor was not accurate using 1 for scalar b.
I also remember people having issues with their sensors not reading the full vacuum range when using a value of 1, but that may have been a sensor limitation.
IMO, there are enough people running these things now that there should be a consensus on the right way to do this...
 Old 08-15-2014, 01:41 AM   #89
mrQQ's Avatar
Well I might agree that it would make sense to keep B as close to stock as possible and only recalculate A using that. Just to not throw ECU off much if it uses B in some way.
 Old 08-15-2014, 08:06 PM   #90
Groans: 60
From what I've seen whenever scalar b is calculated using the slope/distance method the results are very close to the OEM value..
 Old 08-16-2014, 01:10 AM   #91
mrQQ's Avatar
I still don't understand what you mean by that.
 Old 08-16-2014, 02:20 PM   #92
Groans: 60
The sensor spec sheet usually has the full accurate sensor range shown.. The lowest accurate output and the highest accurate output is used. Scalar b can be calculated by taking the slope of the line determined by your datapoints divided by the distance between them..
 Old 08-16-2014, 02:46 PM   #93
mrQQ's Avatar
well, yes, but that's just one scalar.
For example, 845 sensor lists 11kPa at 0.25v and 307kPa at 4.75v. Voltage range 4,5v (4,75-0,25), pressure range is 296 (307-11), so its 65,78 kPa per 1v. So that's your scalar A. What is B?
 Old 08-16-2014, 06:30 PM   #94
My thoughts on how to convert the Bosch data to ATR from this data:
p2-p1 / slope of linear formula = offset
For the 3 bar sensor (#845)...
P1 -> 11 kPa at 0.25V
P2 -> 307 kPa at 4.75V
y = 65.778x - 5.4444
component A: 296 (307 kpa - 11 kpa)
component B: .22 aka 65.778 / 296
offset : 5.444
Tuning for 3.5Bar Map sensor with cobb ap
TiGraySpeed6 likes this.
btstarcher (08-16-2014), MD1032 (05-11-2015), mituc (08-17-2014), TiGraySpeed6 (08-16-2014)
 Old 08-17-2014, 12:46 AM   #95
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
offset : 5.444
@Steve@VersaTune - you need to see this, we can't go higher than 250 on A. We do load based tuning with VT most of the time, but still...
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
rfinkle2 (08-17-2014)
 Old 08-17-2014, 02:06 AM   #96
mrQQ's Avatar
Now this make sense somewhat, because it would say what each voltage step is. That is its the same as 1/voltagerange. I guess ecu could make use of something like that.
 Old 08-17-2014, 12:19 PM   #97
It had better makes sense. The values are as calculated by Mazda for the 2.5 bar sensor.
I took the stock 2.5 bar data and worked with it in order to make sure the stage 0 values (ots cobb / mazda rom) matched and got a linear formula from:
point 1: 20 kpa @ .4v
point 2: 250 kpa @ 4.65v
This gives the formula: y = 54.118 - 1.6471
recall stage 0 map sensor settings (factory rom 2.5 bar)
component A: 230 =(aka p2-p1)=(aka 250 kpa - 20 kpa)
component B: .24 = (slope/ p2-p1) = 54.118/230
offset: 1.65 (negative y intercept)
Last edited by rfinkle2; 08-17-2014 at 12:20 PM. Reason: MSF Database - Automerged Doublepost
The Following 6 Users Say Thank You to rfinkle2 For This Useful Post:
btstarcher (08-17-2014), dale_gribble (08-17-2014), Mauro_Penguin (08-27-2014), MD1032 (05-11-2015), mrQQ (08-17-2014), TiGraySpeed6 (08-17-2014)
 Old 08-17-2014, 12:49 PM   #98
mrQQ's Avatar
Woot! @Steve@VersaTune; please increase the limit!
 Old 09-04-2014, 03:56 PM   #99
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Is there any source to get the 3BAR sensor harness? The bitsise-motorsports.com site seems to have some issues, any HTML file it has available is offered for download apparently because the content-disposition HTML header is set to "attachment".
It's Bitwise, and Edge has them.
We have them now, as well. And for much less!
Bosch MAP Sensor Plug 'n' Play Adapter Harness @ therpmstore.com
The Following 11 Users Say Thank You to RPM For This Useful Post:
Amnesiac (09-04-2014), btstarcher (09-04-2014), Cevaes_64 (09-04-2014), dale_gribble (09-04-2014), ItsNox (09-11-2014), Koke382 (09-04-2014), Mauro_Penguin (09-07-2014), MD1032 (05-11-2015), rfinkle2 (09-04-2014), The Nut (09-04-2014), We're All Thieves (10-24-2014)
 Old 10-31-2014, 03:38 AM   #100
Motocooney's Avatar
Posts: 175   (View Stats)
Motocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud ofMotocooney has much to be proud of
I'm using the Bosch "845" 3 bar sensor as used by the OP.
The scalar values listed dont work for me.
When I use:
Scalar A 65.78
Scalar B 1
Offset 6
I get a dashboard boost reading of ~14.21!?!
The values that work for me are:
Scalar A -65.78(negative)
Scalar B -1(negative)
Offset 6.5
This gives me a reading of zero and a proper reading at idle.
Are these original values supposed to be negative?
And if not, what could the problem be?
Thanks!
2009 MS3 GT - True Red
Fully Built Block//ATP GT3071r ported WG//TXS TBE//TXS FMIC//HKS SRI//CP-E TIP//TurboSmart Dual Port BPV//PTP HPFP//CP-E Injector Seals//CP-E motor mounts//AEM Truboost(running as 3 port)//AEM UEGO//Denso ITV24 plugs//ACT HDSS//ACT lightweight FW//Eibach Prokit//Drag DR-38 18x8 +35//Federal 595ss 235/40/18//RA Mudflaps
Self Tune in Progress
Motocooney is offline   Reply With Quote
 Old 10-31-2014, 03:48 AM   #101
Motocooney's Avatar
In ATR there is a box to check/uncheck under options
"Show standard units"
Should this be checked or unchecked?
Obviously, the scalar numbers in the OP work well enough for everyone else.
Why would mine be different?
 Old 10-31-2014, 04:34 AM   #102
Motocooney's Avatar
14.21 seems to be the barometric pressure
Why would my boost reading when logging with ATR show baro KOEO?
When I unchecked the show standard unit box, it shows .04psi.
 Old 10-31-2014, 11:15 AM   #103
btstarcher's Avatar
Posts: 4,852   (View Stats)
component A: 296
component B: .22
offset : 5.444
Show Standard Units should be checked.
SnailTune in progress
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
Mauro_Penguin (11-05-2014), TiGraySpeed6 (10-31-2014)
 Old 10-31-2014, 03:11 PM   #104
Motocooney's Avatar
component A: 296
component B: .22
offset : 5.444
Thanks, buddy
Not sure how I got owned by something so simple but
It seems to be working now with the OP values and an offset of 6.5.
Thank you for replying, dude.
Happy Halloween!
 Old 10-31-2014, 03:31 PM   #105
btstarcher's Avatar
I honestly never even checked to see if it worked; Fob proved the relationship mathematically, and I trust math. And Finkle.
Mauro_Penguin (11-05-2014), rfinkle2 (10-31-2014)
 Old 10-31-2014, 03:35 PM   #106
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Yeah, that's from @rfinkle2; math there, and it works a treat- I've been using those settings for a while now all over the country and have had consistent results.
I've been meaning to add them to the OP forever - should probably go do that .....
340hp / 371tq
btstarcher (10-31-2014), Mauro_Penguin (11-05-2014), rfinkle2 (10-31-2014)
 Old 11-05-2014, 10:05 AM   #107
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Anyone done any math for a 4 bar? How much different will the values be? Would the offset just change?
2013 CWP and Stock
 Old 12-23-2014, 07:57 PM   #108
smckenzie04's Avatar
Posts: 24   (View Stats)
smckenzie04 is just really nicesmckenzie04 is just really nicesmckenzie04 is just really nicesmckenzie04 is just really nicesmckenzie04 is just really nice
I have tried the values in the AP help file and the ones posted here but I never get any better than -12.XX PSI with key on engine off. Also my BAT's are 130-138 when the car is ice cold and outside temps are in the 50's. Any suggestions?
smckenzie04 is offline   Reply With Quote
 Old 12-23-2014, 08:10 PM   #109
aromig's Avatar
Posts: 289   (View Stats)
Check your adapter harness wiring, the one I bought had two wires flipped and caused that problem. I changed them around and was golden. Pic of harness with crappy drawing to illustrate how wires were reversed is attached. Ignore scribbles for proper alignment.
Mauro_Penguin (12-24-2014)
 Old 12-23-2014, 08:52 PM   #110
So orange goes on the outside and red next to blue? I'll try to get a peak at it (such a PITA to get to) later tonight.
My new problem is I'm getting 0 pressure from the HPFP and the car won't start. I'm on the stock HPFP internals(only have intake and cat back for now) but fuel pressure has always been fantastic. Any suggestions?
The Following User Says Thank You to smckenzie04 For This Useful Post:
 Old 12-23-2014, 09:41 PM   #111
This is what my 3 bar map sensor harness from Edge looks like and I have no idea how I would change that.
 Old 12-24-2014, 12:16 AM   #112
After some digging I found out fuel pressure comes back when I unplug the map sensor. I am baffled how one could effect the other but I'm going to try and swap the original sensor back in tomorrow in the hopes of getting it back on the road. I don't need the 3 bar for a few months anyway.
 Old 12-24-2014, 01:14 AM   #113
aromig's Avatar
I don't think those wire colors should cross. Basically, the shape of the the plug is different, but the pins should stay the same. I used a pair of needle nose pliers to swap the pins on one end. Original pic from vendor attached.
Second pic just for shits 'n giggles.
 Old 05-05-2016, 08:48 PM   #114
FSRRM's Avatar
Posts: 44   (View Stats)
FSRRM is just really niceFSRRM is just really niceFSRRM is just really niceFSRRM is just really nice
I know this is a thread that I am bringing up from the dead, but it still is very useful and relevant.
I want to double check if those magic numbers work OK for the Bosch 0 281 002 845
Cobb recommend this:
Range: 3 bar
Component A: 65.78
Component B: 1.00
Offset: -5.41
Your magic numbers are this:
Component A: 296
Component B: 0.22
Offset: 5.444
I have a BNR S4, Bosch 845 3 Bar, HTP 3.5, GrimmSpeed EBCS etc etc
FSRRM is offline   Reply With Quote
 Old 05-06-2016, 05:38 AM   #115
For the Bosch 845 3 BAR, the 296/0.22/5.444 numbers are a safe choice.
Feel free to try both- they're both fine for most elevations. Your goal is to get close to 0 with the key on, engine off (KOEO) in the boost reading on your AP or in ATR dashboard. The original post includes instructions using the Cobb numbers to move up or down as needed if your elevation is substantially off of sea level.
340hp / 371tq
FSRRM (05-06-2016)
 Old 05-06-2016, 04:57 PM   #116
FSRRM's Avatar
Excellent I'll I've that a go today, I've got a S3 to tune today so this all makes perfect sense.
 Old 05-10-2016, 01:24 AM   #117
FSRRM's Avatar
Awesome.
Component A: 296
Component B: 0.22
Offset: 5.444
Worked a charm! Thank You
The Following User Says Thank You to FSRRM For This Useful Post:
TiGraySpeed6 (05-10-2016)
 Old 08-24-2016, 05:38 AM   #118
stonecold0469's Avatar
Posts: 34   (View Stats)
stonecold0469 will become famous soon enough
So how bout for a 4 bar map sensor???
stonecold0469 is offline   Reply With Quote
 Old 07-16-2018, 07:38 AM   #119
tastyratz's Avatar
Posts: 58   (View Stats)
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
I know, necro bump... but I wanted to update this old thread with some relevant info to help others.
I noticed a mention of offset changes before the rfinkle numbers were posted but nobody posting their experience after. Maybe my post will save the next guy a few flashes?
I loaded the rfinkle scalars and 5.44 offset showed KOEO bouncing between -0.37 and -0.44
I changed the offset to 4 and result was -0.23
(1.44 reduction resulted in a change of 0.17)
I changed offset to 3.60 and got to -0.16
(0.4 reduction resulted in a change of 0.07)
I then Changed offset to 2.75 and got to -0.01, nice
(0.85 reduction resulted in a change of 0.15)
Each change did not translate evenly so the offset does not appear to be completely linear. While rfinkle's numbers are regarded as great, I might still recommend people still take the time to tweak their offset. I was almost 1/2psi off so the extra accuracy is welcome.
tastyratz is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-painless-3-bar-map-sensor-upgrade-128850/
VersaTune - View topic - bosch 3 bar MAP sensor This thread Refback 06-05-2015 02:50 PM
COBB AccessPort V3 - Seite 16 This thread Refback 05-12-2015 04:07 AM
VersaTune ? View topic - bosch 3 bar MAP sensor This thread Refback 08-24-2014 04:05 AM
AZ520 Budget turbo madness!! Build - Page 18 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-07-2014 01:35 PM
3 Bar MAF & MAP Sensors - Page 3 This thread Refback 06-23-2013 01:53 AM
Stock Fitment 3 Bar Map Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - ECU Computer Tuning 529 02-23-2017 05:15 PM
Fuel Rail High Pressure Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 234 10-25-2014 01:54 AM
3.5 Bar Map Sensor Upgrade help Nitr0EngiE MazdaSpeed 3/6 - ECU Computer Tuning 9 12-05-2012 11:11 AM
Fuel Rail High Pressure Sensor Upgrade JumpingJackson MSF KB - Mazdaspeed 3/6 - Fuel 234 09-19-2012 01:53 PM
Page generated in 0.56108 seconds with 34 queries
