Groans: 60
(Thread Starter) | Neutral : +1 score I used a dei 8616 relay, it's very small, and can be found for less than $10. Just about any 1~3 amp diode will work just fine.. Red Connects to green/black at the vacume solenoid(86) Black Connects to black/red at the vacume soleniod(85) Brown No connection(87) Orange Connects to a wire at the plunger(87a) Yellow Connects to a wire at the plunger (30) It's basically a starter kill relay with the triggers connected to the vacume soleniod and the contacts connected the to the plunger(the polarity doesn't matter here, just cut the plug off the pluger and wire it up). I used a DEI 8616 relay(because it's small), and a diode I had laying around. You could probably just go down to a stereo shop and buy a starter kill relay, the wire colors might be different, but it will still work.. Wire it up and you can completly remove the VTCS solenoid, vacume reservoir and the plunger, and you wont throw any codes. Just make sure to plug the extra vacume ports.
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks Last edited by SSinstaller; 12-12-2017 at 05:38 PM. |
| The Following 14 Users Say Thank You to SSinstaller For This Useful Post: | ak_spray (01-03-2012), alphasaur (03-16-2014), anavrinIV (10-28-2012), Axspeed6 (09-03-2012), boost_me (08-06-2008), dadasracecar (07-29-2008), El_Diablo (10-30-2013), ESB Jiu JItsu (08-16-2012), FezMS6 (01-19-2009), SpeedSixxx (12-02-2009), Tomas (12-21-2011), Tres3 (12-28-2013), WetzMS3 (12-08-2014), wingcmdr (01-22-2019) |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,642
Groans: 78
| Not Ranked : 0 score What's this for? You might as well put a explanation in here now, lots of people will ask.
__________________ In reality I love lenny |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
Groans: 70
| Not Ranked : 0 score did you read the title?
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! |
Groans: 60
(Thread Starter) | Not Ranked : 0 score When you remove the complete VTCS system you can throw two codes..IIRC you will get P2006 VTCS shutter valve stuck closed, and you might get VTCS P2009 variable swirl soleniod valve control circuit low. The relays coil being wired in elimiates P2009, and the connections to the pluger mimic the action of the switch on the pluger getting rid of the P2006. The computer thinks everything is there so it doesn't throw any codes..
| The Following User Says Thank You to SSinstaller For This Useful Post: | littleloogy (07-08-2018) |
Groans: 70
| Not Ranked : 0 score does anything happen to your car like limp mode,or do you just have the annoying cel
Groans: 60
(Thread Starter) | Not Ranked : 0 score You just have the MIL..
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
| Not Ranked : 0 score What plunger are you refering to, just to be clear? |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
Groaned at 70 Times in 44 Posts
Groans: 60
(Thread Starter) | Not Ranked : 0 score When the vacume canister moves the actual rod in the IM it has a tab that hits a little plunger type switch, it's how the ECM knows the VTCS system is working properly...
Groans: 78
Groans: 70
| Not Ranked : 0 score lol i wasnt trying to be an ass if i came off that way,i was just asking cause the title pretty much explains what its for.
![]() Join Date: Mar 2008 Location: NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
| Not Ranked : 0 score HAHA sorry to be picking your brain here but I was also checking the wiring for this trick on the Sped 3. Just to be clear the "vac solenoid" is on the black plastic box between the #2 and #3 runners. Then the "plunger" is the cylindrical thing under the gray plastic dohicky on the trans side of the intake manifold. The plunger has 2 wires and goes to a gray connector on the opposite side of the gray plastic do hicky. The 3's wire colors match what the 6 has on the vac solenoid so this write up should work on both cars then. I will try it before I take off the manifold and gut it just incase though. |
| Not Ranked : 0 score As long as the colors match the orientation on both cars, then yes it will work the same. That would suprize me, cause nothing else seems to match up easily between the two. |
![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 998 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 167
Groans: 31
Groaned at 86 Times in 65 Posts
| Not Ranked : 0 score So all i did was take the rod out and cut it off right before the plastic part that attaches to the ball socket that goes into the plunger. This way it all still works but there are no flaps. I am getting a p2006. wtf?
__________________ -JEWBERT |
| Not Ranked : 0 score how bout an option to delete the EGR code?
Groans: 60
That plunger needs to move when the VTCS is actuated, if it doesn't the ECM thinks the flaps are stuck...and throws the DTC P2006 (variable swirl shutter valve stuck closed). I checked into this last year for whoosh.. The EGR has 4 differnt modes of operation, and must return the corresponding proper voltage change to the ECM when each is activated. The problem is that the EGR test is done by the computer using the dealer scan tool and the neither the service manual nor the electrical manual list the specific voltage changes that should occur. That's not a huge issue as long as you are willing to leave the EGR itself in place and connected. The real issue is that the ECM actually monitors the MAP to insure the EGR system is flowing enough exhaust--there is no mention in either service manual of the voltage change that should occur when the egr is active. Even if there was it would be overly complicated to simulate the 4 difffernt modes of the egr operation while not influencing the MAP output at other times--even the resistance of a simple relay could effect the map ouput during normal driving. This is a problem that will need to be solved in the ECM itself. Luckily I've been talking back a forth with Jordan at CP-E about thsi for a while now and they are very close to being able to delete these specific MIl's from the ECM firmware...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks Last edited by SSinstaller; 01-26-2009 at 02:04 PM. | |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score worked for me, but i just used a cheapo relay. couldnt find a dei microrelay...
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
![]() Join Date: Dec 2008
Rep Power: 139 ![]() ![]() ![]() Thanks: 1
![]() | | #19 | ![]() |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Ok for those who dont have a DEI relay and dont speak in colors. Here is a break down of the wiring to a SPDT relay. 85 black/red at the vacume soleniod 86 green/black at the vacume solenoid 87 No connection 87a Connects to a wire at the plunger 30 Connects to a wire at the plunger |
![]() | | #20 | ![]() |
Groans: 60
(Thread Starter) | Not Ranked : 0 score For those having trouble finding the DEI 8616. http://www.amazon.com/gp/offer-listing/B000CJ05WW/ref=dp_olp_new?ie=UTF8&qid=1249930236&sr=8-1&condition=new
![]() | | #21 | ![]() |
![]() Join Date: Apr 2009
| Not Ranked : 0 score Has anyone come across a detailed HOW-TO document with pictures for a complete VTCS system delete? I've found pieces here and there, but nothing complete.
__________________ 2006 Mazdaspeed 6 Cobb AP 2.0 with 1.01 stage 2 93 octane SF map Cobb Turbo Inlet, Cobb SF Intake ATP 3inch downpipe with metal spun High-Flo Cat |
![]() | | #22 | ![]() |
Groans: 60
(Thread Starter) | Not Ranked : 0 score Once the manifold is off it's easy to see what needs to be done, that's probably why there isn't a step by step how to. Just remove the actual flappers, and either leave the rod, or remove the rod completely and have the hole welded shut.
![]() | | #23 | ![]() |
![]() Join Date: Aug 2009
| Not Ranked : 0 score great discussion!!!! |
![]() | | #24 | ![]() |
| Not Ranked : 0 score For those of you who have done the VTCS delete, have you experienced any cold weather issues or do you all live in the southern US?
![]() | | #25 | ![]() |
Groans: 60
(Thread Starter) | Not Ranked : 0 score I'm in NC, and I've never had any issues. I don't see sub 0 temps or anything, but it gets down below freezing in the winter...
| The Following User Says Thank You to SSinstaller For This Useful Post: | ESB Jiu JItsu (08-16-2012) |
![]() | | #26 | ![]() |
![]() Join Date: Oct 2012 Location: Richmond,Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
| Not Ranked : 0 score @BigO; peep this. |
| The Following User Says Thank You to cbunn79 For This Useful Post: | jeopardy98 (10-06-2014) |
![]() | | #27 | ![]() |
![]() Join Date: Jun 2014 Location: Logan, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score I know this thread is older then old but none of the relays I could find have those color wires. They come with just black and grey. Any ideas? Would this one work? New Dei 8616 Mini Circuit Relay 20 10 Amp Prewired Directed 4 Car Alarm System | eBay
__________________ 2010 Mazda Speed3- Mods: Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell Next up: tune. |
![]() | | #28 | ![]() |
![]() Join Date: Jul 2012 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 593
![]() | | #29 | ![]() |
| Not Ranked : 0 score Because then I will be up to 4 not ready when I go in for testing. I am not sure if that test in my state only looks at emmsions items or the over all system. If it's the over all system I would fail the test big time which is why I want to solve it this way.
| The Following User Says Thank You to blake0521 For This Useful Post: | davros (08-14-2015) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Don't see why the dei 8616 you link to would be different than the one the OP posted. I assume you don't have a way or don't want to install the oem actuator? |
![]() | | #31 | ![]() |
| Not Ranked : 0 score I am going with a pnp mani so not vtcs.
![]() | | #32 | ![]() |
| Not Ranked : 0 score Gotcha. Kinda figured as much. |
![]() | | #33 | ![]() |
![]() Join Date: Jun 2014 Location: Breinigsville PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score Thanks for the how to... I'm looking to delete my VTCS soon
__________________ 06 Black Cherry Mica Mazdaspeed 6 GT Stratified Stage 2 93 OTS Tune JBR S2 Intake - JBR TRILOGY Mounts JBR Shift Plate, Weight & Knob - CP-e HPFP Ebay Test Pipe - AP V2b - UltraGauge MISHIMOTO Retrofitted Projectors - 35W HID CS2 STI Lip |
![]() | | #34 | ![]() |
![]() Join Date: Jan 2011 Location: Naval Station Guantanamo Bay, Cuba
| Not Ranked : 0 score Haha, I was just lazy and took out the rod, cut off everything past the first hole, put it back in there and wired it back up.
__________________ 2006 "GTMO Green" Speed 6 { Corksport TBE w/ resonator }{ COBB AP }{ Corksport Max-Flow internals } { TWM STS Stg 2 w/ bushings }{ Primary/Secondary EGR Deletes }{ JBR Motor Mount Trilogy} {TurboSmart BPV }{ COBB TIP }{ SS Brake/Clutch Lines }{ ARP Head Studs } { HTP 4" intake w/ 51R }{ FMIC }{ Enkei PF01 Rims }{ Stoptech Slotted rotors }{ AEM Wide-band AFR gauge } { AEM TRU-Boost Controller }{ Gauge pod (Block8head) }{ Bnoon Bolt } { Turbo-timer (yeah...) }{ PERM Plate }{ JBR Intake/TB TIGs } { Coming Soon: install GT3071r EWG setup, CPE Seals, tune, and re-paint } |
| The Following User Says Thank You to kvg823 For This Useful Post: | Tokay444 (12-31-2014) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Same here. It has been fine for several years...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() | | #36 | ![]() |
![]() Join Date: Nov 2011 Location: Garden Grove, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 209
| Not Ranked : 0 score Any pictures of what this looks like? The white plastic part broke near the plunger so I'll have to wire this in to eliminate cel and pass smog in Ca.
__________________ FYHN except Odyssey's. Ody's are bad-ass 1996 Acura Integra HB Sold 1998 Acura Integra GSR Sedan Sold 2008 Honda Pilot Sold 2006 Honda Accord Sold 2008 Honda Odyssey 2007 MS3 Silver Sport Cobb AP SRI TIP // CNT DP // JBR SSP Bushings Knob RSB // CPE TMM // SU TMIC // AT INTERNALS // MD OCC RMM // NGK // Bilstein B8 // Swift Springs // Evo 9 wheels // SPC camber arms Freek tuned 91 and 3 gal E85 [SIGPIC][/SIGPIC] |
![]() | | #37 | ![]() |
![]() Join Date: Jul 2014
Rep Power: 0 ![]() Thanks: 0
![]() | | #38 | ![]() |
| Not Ranked : 0 score I did figure it out. The part that confused me was on the plunger. The plunger has a green and a black wire. I don't remember which one I connected to which, but it worked and CEL went away. I can confirm tonight if you need me too. Orange Connects to a wire at the plunger(87a) Yellow Connects to a wire at the plunger (30)
![]() | | #39 | ![]() |
| Not Ranked : 0 score If you could that would be great, that way I don't mess anything else up.
![]() | | #40 | ![]() |
Orange and Black Yellow and Green The other two are listed. Hope that helps.
__________________ FYHN except Odyssey's. Ody's are bad-ass 1996 Acura Integra HB Sold 1998 Acura Integra GSR Sedan Sold 2008 Honda Pilot Sold 2006 Honda Accord Sold 2008 Honda Odyssey 2007 MS3 Silver Sport Cobb AP SRI TIP // CNT DP // JBR SSP Bushings Knob RSB // CPE TMM // SU TMIC // AT INTERNALS // MD OCC RMM // NGK // Bilstein B8 // Swift Springs // Evo 9 wheels // SPC camber arms Freek tuned 91 and 3 gal E85 [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to blam1 For This Useful Post: | Vader (06-09-2015) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-remove-mil-s-caused-deleting-vtcs-9150/ | ||||
| After VTCS Delete Code p2006 - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 06-13-2015 11:38 PM | |
| My list so far - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 07-25-2014 12:39 PM | |
| VVT Relay to get rid of Code - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 09-10-2012 12:33 PM | |
| Intake butterflies | This thread | Refback | 08-15-2012 08:55 AM | |
| How to install new bumper protector to remove Front License Plate Holes. | FastAttack | MazdaSpeed 3 - How-To's | 20 | 12-19-2014 01:19 PM |
| How-To remove O2 sensors without messing them up | mazdaspeedjay | MazdaSpeed 3 - How-To's | 38 | 07-14-2009 08:02 AM |
| Interesting Thread on the Effects of Braking caused by Grippier Tires/Lighter Wheels | Crossbow | MazdaSpeed 3/6 - Suspension & Brakes | 32 | 12-16-2008 10:33 PM |
| PTP's CAT back exhaust system, soon to be TBE system. | ptperformance | Mazdaspeed3/6 General Discussion | 56 | 10-05-2008 02:08 PM |
| NVIDIA Drivers Caused Lions Share of Early Vista Crashes | Haltech | Computers & Technology News | 0 | 03-26-2008 02:10 PM |
