> MazdaSpeed 6 - How-To's
Like Tree6Likes
 Old 06-09-2015, 08:16 AM   #41
SURGESPEED6's Avatar
Posts: 6   (View Stats)
SURGESPEED6 will become famous soon enough
OK thats simple enought, it looks like you have all the other wires bunched up and not leading to anything, is that the case or am i missing something?
Originally Posted by blam1 View Post
It's ghetto looking. Don't judge.
Orange and Black
Yellow and Green
The other two are listed. Hope that helps.
SURGESPEED6 is offline   Reply With Quote
 Old 06-09-2015, 10:39 AM   #42
blam1's Avatar
Posts: 359   (View Stats)
blam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the world
4 of the 5 wires are wired up. The brown one isn't. I only showed you a picture of the two (Orange and yellow) that were vague to me. You still have to wire up the red and black as instructed.
I didn't cut the wires shorter. I just tied them up and zipped them under the IC shroud. I'll cut and refit after my smog and I reinstall my mods.
FYHN except Odyssey's. Ody's are bad-ass
1996 Acura Integra HB Sold
1998 Acura Integra GSR Sedan Sold
2008 Honda Pilot Sold
2006 Honda Accord Sold
2008 Honda Odyssey
2007 MS3 Silver Sport
Cobb AP SRI TIP // CNT DP // JBR SSP Bushings Knob RSB // CPE TMM // SU TMIC // AT INTERNALS // MD OCC RMM // NGK // Bilstein B8 // Swift Springs // Evo 9 wheels // SPC camber arms
Freek tuned 91 and 3 gal E85
blam1 is offline   Reply With Quote
 Old 06-09-2015, 11:30 AM   #43
Im kind of a noob to this and dont want to mess anything up, could you possibly show me where the red and black wires wire up to?
Thanks
 Old 06-09-2015, 11:48 AM   #44
blam1's Avatar
the first part is easy. Cut the two wires that go into the Vacuum solenoid. It is on the intake manifold, under the tmic.
Just like the picture except Red Connects to green/black at the vacume solenoid(86) and Black Connects to black/red at the vacume soleniod(85)
I just put everything back together so that's the best you'll get. It's easier than it sounds.
2008 Honda Odyssey
 Old 06-09-2015, 01:50 PM   #45
OK that's better than anything i have found online, Thanks for all the help and putting up with the noob lol
The Following User Says Thank You to SURGESPEED6 For This Useful Post:
blam1 (06-09-2015)
 Old 06-20-2015, 07:30 AM   #46
RX7Racer46's Avatar
Posts: 2   (View Stats)
RX7Racer46 will become famous soon enough
Here are the wires you tap into. Anyone, correct me if I am wrong. Thanks.
RX7Racer46 is offline   Reply With Quote
The Following User Says Thank You to RX7Racer46 For This Useful Post:
kosti365 (05-27-2019)
 Old 06-22-2015, 08:50 AM   #47
Thats exactly what i did. Started it up and no more CEL Thanks for all the help.
 Old 06-23-2015, 09:21 PM   #48
RX7Racer46's Avatar
Glad to help! I'm doing this once my JMF manifold comes in. Can't wait! Thanks to everyone who helped out!
 Old 08-14-2015, 06:57 AM   #49
davros's Avatar
Posts: 1,021   (View Stats)
davros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the worlddavros is the leader of the world
Clarification. ... the relay makes the ecu think everything is there and working correctly? So not giving a cel or mil.
We are only allowed one mil code in MA and my egr delete takes that place. For now. . . .
Hmmm $5 relay. Hours of enjoyment. ...
2009 Metro Gray Mica Mazdaspeed 3
Cobb AP - HTP INTAKE - HKS BPV - GrimmSpeed EBCS - Autotech HPFP - ATP catless DP - JBR EGR full delete - Damon RMM PMM TMM- TR8/CX Piping - Damon Catch Can - FREEKTUNED
davros is offline   Reply With Quote
 Old 08-14-2015, 10:50 AM   #50
Bulgsta's Avatar
Posts: 120   (View Stats)
Bulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond repute
Or do what I did. Just disable the codes in ATR and be happy. When inspection comes around plug the egr and the vacuum distributer in the plugs. Enable 2/4 codes so it sees there is an egr and the vacuum distributer and pass inspection. After that just unplug it all and delete the codes again
2007 Mazdaspeed 6
GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel
Bulgsta is offline   Reply With Quote
 Old 07-21-2016, 06:58 PM   #51
Ajbobtom's Avatar
Posts: 1   (View Stats)
Ajbobtom is an unknown quantity at this point
So, I installed the dei relay as above. I've cleared the runner stuck closed code but am still getting stuck open and now a circuit high code. My diode is a 3W diode I got from RadioShack. Did any of you guys have this problem? Any suggestions?
Ajbobtom is offline   Reply With Quote
 Old 03-15-2017, 11:29 PM   #52
Mike4g64's Avatar
Posts: 7   (View Stats)
Mike4g64 will become famous soon enough
hey guys, nice write up. I have bought the relay and diodes that were recommended and my shutter valve stuck open went away but now I got a high circuit code p2010. I have changed diodes and rewired many times. Any suggestions?
Mike4g64 is offline   Reply With Quote
 Old 04-29-2017, 08:40 AM   #53
SpeedThrills's Avatar
Posts: 172   (View Stats)
SpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond repute
Did this a couple of days ago. Local Radioshack is going out of business so I got everything i needed for about $5. Worked like a charm, no CEL. Thanks for the help!
SpeedThrills is offline   Reply With Quote
 Old 04-30-2017, 06:49 PM   #54
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Sounds like you may have the diode installed backwards.
 Old 08-05-2017, 11:43 AM   #55
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
ugh that picture is gone. where does the diode go?
edit: nm tracked it down, uploaded to the forum.
radbrad and davros like this.
'08 CWP MS3 w/ T3 3071r
 Old 12-11-2017, 01:40 PM   #56
6strngs's Avatar
6strngs is an unknown quantity at this point
Hey guys. I'm just did this, but used a 30A starter kill relay. Wired it up exactly as said (86 to green/black, 85 to black/red, 87a and 30 to the plunger) and I'm still getting p2004 stuck open and now a p2010 circuit high code. I've tried the diode both ways and same thing. What do I do now?
6strngs is offline   Reply With Quote
 Old 12-12-2017, 05:36 PM   #57
Groans: 60
Fixed the picture in the OP.
P2010 is caused by the diode being installed backwards. Remove it entirely, and your mil should go away. Installed backwards it's no different than connecting the two wires together. It can damage the ECM, and will stop the relay from working..
 Old 06-20-2018, 04:13 PM   #58
HumbleGhost's Avatar
Posts: 18   (View Stats)
HumbleGhost has a little shameless behaviour in the past
Hi there,
I purchased the 8616 DEI relay after deciding to delete my VTCS when the plastic POS broke.
I also bought an assortment of diodes, can someone let me know which diode from this list will work best? I don't want to fuck something up royally here.
Does there need to be a diode at all? If so, what is the best way to tap into those lines with the diode? T-taps and connectors or just wrap and tape?
1N4148 switching signal Doide DO-35
1N4007 1A 1000V Rectifier Diode DO-41
1N5819 1A 40V SCHOTTKY DIODE DO-41
1N5399 1.5A 1000V 4.8W Rectifier Diode DO-15
FR107 Fast Recovery Diodes FR107 1A 1000V DO-41
FR207 2A 1000V Fast Recovery Diodes DO-41
1N5408 Diode Rectifier 3.0 amp 1000V DO-201AD
1N5822 40V 3A SCHOTTKY DIODE DO-201AD.
@SSinstaller;
HumbleGhost is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-remove-mil-s-caused-deleting-vtcs-9150/
After VTCS Delete Code p2006 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-13-2015 11:38 PM
My list so far - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 07-25-2014 12:39 PM
VVT Relay to get rid of Code - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 09-10-2012 12:33 PM
Intake butterflies This thread Refback 08-15-2012 08:55 AM
How to install new bumper protector to remove Front License Plate Holes. FastAttack MazdaSpeed 3 - How-To's 20 12-19-2014 01:19 PM
How-To remove O2 sensors without messing them up mazdaspeedjay MazdaSpeed 3 - How-To's 38 07-14-2009 08:02 AM
Interesting Thread on the Effects of Braking caused by Grippier Tires/Lighter Wheels Crossbow MazdaSpeed 3/6 - Suspension & Brakes 32 12-16-2008 10:33 PM
PTP's CAT back exhaust system, soon to be TBE system. ptperformance Mazdaspeed3/6 General Discussion 56 10-05-2008 02:08 PM
NVIDIA Drivers Caused Lions Share of Early Vista Crashes Haltech Computers & Technology News 0 03-26-2008 02:10 PM
Page generated in 0.38945 seconds with 32 queries
