 Old 03-16-2019, 07:23 PM   #1
Sierra248's Avatar
Posts: 22   (View Stats)
Sierra248 is an unknown quantity at this point
Default 07 Speed3 where to buy Mazdaspeed Springs
I’ve been putting my suspension together for about a month and I’m almost ready to start installing everything. Then I decided while putting on the bilsteins that maybe I’ll lower it a little. I got everything I need except springs as I can’t make up my mind on which to get. I also already got some oem mazdaspeed camber arms for the rear.
I know all about which spring does what and such and I’m looking for a mild .5-1.0 inch drop at most but I want something stiffer. Really my main question is what part number are the mazdaspeed springs that were sold thru Mazda. I’ve found the camber arms and springs together for like 600 bucks. I paid 49 for a brand new set of mazdaspeed camber arms so I don’t need them. There’s another set on there if anyone’s interested. Listed at 79, make off of 49 and he’ll accept, he’ll try 39. You can always counter back if he says no to 39 but he did accept my 49.99 offer.
Thanks for any help in Advance,
T
Sierra248 is offline   Reply With Quote
 Old 03-17-2019, 04:01 PM   #2
Sierra248's Avatar
It’s an impossible part number for me to find for an 07 speed3. I have the whole internet and can’t find it
 Old 03-17-2019, 05:43 PM   #3
MSMS3's Avatar
Posts: 2,826   (View Stats)
FYI, before you install those camber arms give thought to getting aftermarket adjustable ones. OEM typically produces too much negative camber, like -4 degrees. rear tires were wearing badly on the inside edges from day one. Stock size Yokohama AD-08R Extreme Performance category summer rubber on stock rims after OEM tires were replaced. AD-08R is serious street rubber, getting close to R.
A good street setup with aggressive driving is -2 in the back. Only way I could do that with my Bilsteins and stock springs was with adjustable camber arms. SPC is a good choice.
Maybe you’ll have better luck and OEM will work for you.
 Old 03-17-2019, 06:14 PM   #4
Sierra248's Avatar
I am running all stock right now. I got the Mazda made Mazdaspeed Camber Arms for the Speed3. There not adjustable but I couldn’t miss out on the deal. They’ll get me close to within spec I’m guessing. I’d wanted to pair them with the matching mazdaspeed springs but there nowhere to be found. So I may go with Swift. I just wish I could find the mazdaspeed branded ones for my speed. There any in the for sale section, I haven’t joined VIP��
Here’s what I got for 49 bucks
https://www.ebay.com/itm/NEW-OEM-MAZ...-/113431786646
Page generated in 0.23938 seconds with 21 queries
