 Old 04-09-2012, 04:30 PM   #1
freeryder's Avatar
Posts: 5   (View Stats)
freeryder is an unknown quantity at this point
Default 08 Speed 3, About to install Koni Yellow's
Hey everyone!
I ordered and received a set of Koni Yellow's for my Speed 3 and am planning to get the install underway. However, I want to make sure that I have everything I need to do it right and fix the problem I have right now.
Car: 2008 Speed 3 with ~55000km on it. Cobb springs, front and rear sway bars using new OEM endlinks (replaced when the bars went on about 20,000km ago), and stock struts.
Problem: Kinda depends on the day. But usually the car will start quiet but after I have been driving now maybe about 5 minutes and the "parts warm up" the rear starts to rattle over bumps (those sharp joints in the road and deep cracks, etc.). As I said, it seems to take a bit to start rattling but sure enough, it rattles. Some days it seems to take less time to start making noise (maybe more bumps that day, maybe warmer weather... not sure). It rattles at low speed and even on the highways depending on the road. I want to say its as the rear unloads the noise happens.
I have inspected the struts and while there isn't any visible leaking, I have attested the noise to these being the stockers and likely at the "please replace me" point. However, the more I read about noises, the more I have heard about top mount bushing/bearing issues.
With the way the car is beginning to drive I knew it was time for the struts but I want to make sure I am covering everything. Can people who have dealt with these noises and/or have done a koni sport conversion comment?
Some of the areas I am now wondering about:
Bumpstops for the front a rear.:
Use what is there or replace with OEM or aftermakerts? And which aftermarkets? Does length matter as much because I am basically at stock height using Koni yellows and not the FSDs?
Top Mount Bearing/Bushing: This area is the newest to me. Should I just replace the bushing and bearing just in case? Are they expensive?
Sway Bar Bushings/Endlinks: Again, visual inspection of the Cobb Sway bushings appear to look in good condition (although they need to be greased again But could the clunking be coming from the sway bar endlinks? They have been replaced once, and appear in good shape.
Koni Install: Is there any special tricks beyond lock-tite on everything that anyone can offer when the new struts are installed to ensure a rattle free future? I am getting my local Mazda dealer to install (unless anyone in the North Bay... specifically Santa Rosa Area, can recommend somewhere they trust) so I am compiling a list for the dealer of tips/pics/etc. to help things go smooth.
Thank you in advance for you input! I want to make sure I do this right
freeryder is offline   Reply With Quote
 Old 04-10-2012, 03:44 PM   #2
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
replace the front bump stops with ground control or fat cats and just cut the rears.
i wouldn't bother replacing the top mount but others will say yes.
it sounds like you rear endlinks aren't tight to get the clunk.
study the how-tos (in the how-to section) and do the install yourself. reverse bolt quarter and scissor jack are your tricks.
 Old 04-10-2012, 04:25 PM   #3
freeryder's Avatar
I've already tried tightening the endlinks and it didn't stop the rattle but it does sound like that. I think I will replace the endlinks just in case anyways. I'd love to be able to do the install myself but I dont have the appropriate tools with me.
 Old 04-10-2012, 08:23 PM   #4
oakley990099's Avatar
Posts: 246   (View Stats)
oakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the world
all you need is a couple basic things and a rented spring compressor
it'll save you a lot of cash especially if your going to a dealer to do this.
oakley990099 is offline   Reply With Quote
 Old 04-10-2012, 03:58 PM   #5
I just lowered mine on koni yellow. Changed the front bumpstops to ground control. (firm) (2 of them)
Also cut the rear oem ones from 5" to 3"
And although not always needed I purchased 2 front bushings
It is better to buy things you suspect you will need and swap them anyway rather than being in the install and not having the parts..
I didn't use lock tight though ops. .. Do people who have replaced used it?
 Old 04-11-2012, 05:01 AM   #6
patrick failman
Groans: 74
did you tighten both bolts on the endlinks (top and side)?
we're talking basic tools. you don't even need spring compressors since you're on cobb springs.
 Old 04-11-2012, 05:11 AM   #7
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groaned at 34 Times in 31 Posts
You will probably need to replace them in the front. Mine were destroyed after 53k. Even if yours aren't worn out yet, this is the time to do it since you'll have everything out anyway. I paid $144 for the set on onlinemazdaparts.com.
Pseud0logik is offline   Reply With Quote
The Following User Says Thank You to Pseud0logik For This Useful Post:
Nliiitend1 (04-11-2012)
 Old 04-11-2012, 06:10 AM   #8
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
The topmounts themselves might be overkill, but replacing both the topmounts and the bushings/bearings together ensures that you won't be ruining your brand new bushings with a slightly deformed or no-quite-perfectly-aligned topmount.
It comes down to what you can afford and what you're comfortable with.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 04-11-2012, 07:43 AM   #9
i agree with @Nliiitend1 ^^ +1
find someone in a local nator to help you and you'll save major $$$
 Old 04-11-2012, 08:21 AM   #10
here is a little something that might help a tiny bit.. not a complete install; but has some good info:
H&R + Koni Install and impression
 Old 04-11-2012, 01:34 PM   #11
freeryder's Avatar
Thanks guys! @oakley990099 or @Nliiitend1 , do you have the part numbers for the bushings, bearings (is this separate from ordering the bushing assembly?), and top mount that I'll need for the front end?
Also, @oakley990099 I am chatting with a local fellow who is quite well studied in Mazda suspension. Both His mz3 and his bros MS3 have been worked on and he has done it for members of the forum so I will likely go with him.
There also happens to be a good alignment shop very close to that will do a custom alignment for me.
I am going to replace the top mount/bearing/and bushing to be on the safe side and I'm going to try and reuse the rear bump stops, and order up Fat Cats for the front.
 Old 04-11-2012, 05:11 PM   #12
Nliiitend1's Avatar
The bushing/bearing is ONE item (linked in the post above this one), and the top mount is another item (item #8 in this diagram -click--> http://www.partswebsite.com/mazdapar...imagecallout=8).
You'll obviously need one of each for both sides.
2008 MS3 GT
2016 MX-5 Club
 Old 04-11-2012, 03:02 PM   #13
Good for you!!
And here are the bushings for ya:
BUSHING,MTG. RUBBER (BBM2-34-38X) - $39.03 - BBM23438X
 Old 04-11-2012, 08:20 PM   #14
As he stated^ combined both posts and good luck!
Dano's Koni FSD install Dano MazdaSpeed 3 - How-To's 64 03-03-2015 12:49 PM
Koni yellow's and bilstein sport part #'s sg1320 2010 MS3 - Suspension & Brakes 5 09-20-2011 03:06 PM
Koni FSD Install Questions TegRacer324 MazdaSpeed 3/6 - Suspension & Brakes 16 08-18-2011 09:14 PM
H&R + Koni Install and impression jamesthebikeguy MazdaSpeed 3/6 - Suspension & Brakes 49 08-04-2010 06:37 AM
Koni Yellow Install this weekend... thanotosq MazdaSpeed 3/6 - Suspension & Brakes 29 06-29-2009 09:24 PM
Page generated in 0.36148 seconds with 24 queries
