Like Tree5Likes
  • 5 Post By stockms3
 Old 06-01-2016, 09:35 PM   #1
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Neutral  :  +3 score
Default Affordable redesigned top hats/struts mounts and bearings from FORD
I will be replacing old Koni yellows with some new ones and of course decided to do some research as to which parts to use.
I've found we have an amazing CHEAP option and that is top hats and bearings directly from Ford. I paid about $55 for both sides SHIPPED from tasca ford. The parts look like they are great quality and both are made in Europe. Definitely, a better option than OEM or rockauto.
UPDATE: Parts were installed and everything fits perfectly. Even the stock boot.
Part numbers:
bearings: DV6Z-18198-C (made in Germany)
top hats: CV6Z-18183-A (made in Italy)
Pics:
Old top hat vs new
close up:
Old bearing:
New bearing (notice the lip, it is on the bottom part, I assume its to stop shit from getting into the bearing and trashing it):
The Following 24 Users Say Thank You to stockms3 For This Useful Post:
brandon3212 (06-05-2016), Carskick (11-24-2018), Code Monkey (06-03-2016), dan7225 (06-03-2016), Design (10-07-2016), Easter Bunny (09-23-2016), hartlch (06-04-2016), impossible (06-04-2016), juantaquitos (12-18-2018), KiwiFlavor (06-02-2016), Kuna Alex (05-11-2018), MD1032 (06-04-2016), MSMS3 (06-03-2016), necrophrenic (05-19-2018), Nliiitend1 (06-03-2016), rob ms6gt (07-11-2016), Silaramic (09-21-2016), snailD (06-02-2016), Snyeed (06-02-2016), thrisnospork (06-01-2016), Tomas (07-05-2016), WetzMS3 (07-08-2016), Yatta (06-03-2016), [R]usty (06-03-2016)
 Old 06-02-2016, 05:21 AM   #2
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Interesting...
Let us know how this goes
2012 NASA Spaceship Gray MS3
snailD (06-02-2016)
 Old 06-02-2016, 10:04 PM   #3
stockms3's Avatar
Groans: 74
Interesting...
Its going to be another week or so till I actually get around to it. I need to powdercoat the springs first but I will definitely update the thread.
The Following 3 Users Say Thank You to stockms3 For This Useful Post:
KiwiFlavor (06-03-2016), MSMS3 (06-03-2016), snailD (06-02-2016)
 Old 06-02-2016, 10:17 PM   #4
snailD's Avatar
Posts: 3,039   (View Stats)
Interesting...
this x2. cool find
The Following User Says Thank You to snailD For This Useful Post:
KiwiFlavor (06-04-2016)
 Old 06-02-2016, 11:45 PM   #5
swd120's Avatar
Posts: 126   (View Stats)
swd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond repute
If these tophats work - does that mean we can use ford focus camber plates?
swd120 is offline   Reply With Quote
 Old 06-03-2016, 12:54 AM   #6
stockms3's Avatar
Groans: 74
You mean like these? Moog K80001 Camber Plate | eBay You should test em out! You can wait till I try these top hats but I'm pretty sure they will work.
This weekend if I have some time I will take a look at my fiancee 2012 focus and see what other parts might fit .
Edit: Looks like SPC rear adjustable upper arm is the same too!
The Following 2 Users Say Thank You to stockms3 For This Useful Post:
impossible (06-04-2016), snailD (06-03-2016)
 Old 06-03-2016, 01:09 AM   #7
[R]usty's Avatar
Posts: 2,204   (View Stats)
Great find! Subbed for results.
2010 Mazdaspeed3 w/tech
 Old 06-03-2016, 02:06 PM   #8
swd120's Avatar
Even Cheaper
The Following User Says Thank You to swd120 For This Useful Post:
Tomas (07-05-2016)
 Old 06-04-2016, 01:09 AM   #9
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Interesting! Bookmarked just incase I go with another strut/shock combo vs a drag coilover.
 Old 07-05-2016, 04:35 PM   #10
stockms3's Avatar
Groans: 74
So, big update!!!!
Finally got around to installing the shocks/struts. I am happy to report that everything fits great! Even the factory boot fits no problem on the Ford bearing.
I will be taking a closer look at a suspension from a 2012 ford focus it appears that the front struts would also fit. I roughly looked at control arms and they look very similar.
The Following 5 Users Say Thank You to stockms3 For This Useful Post:
KiwiFlavor (07-05-2016), Nliiitend1 (07-06-2016), Ranyard (07-05-2016), snailD (07-05-2016), WetzMS3 (07-08-2016)
 Old 07-05-2016, 05:02 PM   #11
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
FYI:
2012 Focus Aluminum Lower Control Arms...adaptable to the MS3?
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
stockms3 (07-05-2016), Tomas (07-05-2016), WetzMS3 (07-08-2016)
 Old 07-05-2016, 05:23 PM   #12
EvoFire's Avatar
Posts: 389   (View Stats)
I've been running these top hats and bearings for the last 2 years. Way cheaper and better than the Mazda ones.
The Following 5 Users Say Thank You to EvoFire For This Useful Post:
Easter Bunny (09-23-2016), KiwiFlavor (07-08-2016), Nliiitend1 (07-06-2016), snailD (07-05-2016), stockms3 (07-05-2016)
 Old 07-07-2016, 06:35 PM   #13
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
Installed these on my 2012. Fit perfectly.
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
 Old 07-08-2016, 12:01 PM   #14
Ranyard's Avatar
Posts: 146   (View Stats)
Ranyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond repute
yep, put on my 13 yesterday, much nicer than RA or oem
"The eagle never lost so much time as when he submitted to learn from the crow" ...nobody
Ranyard is offline   Reply With Quote
 Old 09-20-2016, 03:40 AM   #15
alden's Avatar
Posts: 400   (View Stats)
alden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant future
how did you get these for $55?! comes up to 83$ before shipping for me?
alden is offline   Reply With Quote
 Old 09-20-2016, 07:11 AM   #16
stockms3's Avatar
Groans: 74
Where are you looking them up? Tasca ford?
 Old 09-20-2016, 05:31 PM   #17
alden's Avatar
yes sir!
 Old 09-21-2016, 06:12 PM   #18
stockms3's Avatar
Groans: 74
yes sir!
I guess I got lucky. Too bad they raised the prices.
 Old 09-21-2016, 07:47 PM   #19
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
When I was looking at these I found if I searched using C-max or Courier van the identical part was cheaper than when searching using the Focus.
FWIW, Tasca wasn't the cheapest when I looked but I don't remember the name of the website that was cheaper. I moved on when I stumbled on affordable camber plates that use the Ford bearing.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
 Old 09-23-2016, 10:39 AM   #20
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
If anyone is looking for a brand new set of the bearings; I have them up for sale in the gen2 section.
 Old 09-23-2016, 11:09 AM   #21
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Yes, I'll check your for sale link.
 Old 11-22-2016, 07:25 AM   #22
PurplFox's Avatar
Posts: 352   (View Stats)
moog has these as well 66 a side. 908961 pt number. probably going to snag these next payday and maybe the k80001 camber kit just to play around with it
Cobb AP
JBR Tru-3.0
CNT Catted DP "Gutted"
CNT Catback
JBR 88 RMM DM PMM and TMM
3 port, Turbosmart dual port
FReaktune E33
 Old 11-22-2016, 07:55 AM   #23
Nliiitend1's Avatar
I highly doubt that camber kit will work.
It's made for the original C170 chassis Focuses (2000-2011), not the later "Global C Platform" that was an evolution of the C1 chassis, upon which the MS3 is built.
...as for the 908961 part, Google is leading me to believe it is a Monroe part. Did you mis-type?
2008 MS3 GT
2016 MX-5 Club
 Old 11-22-2016, 08:11 AM   #24
PurplFox's Avatar
Shit, you're right. yeah thats the monroe set.
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
The Following User Says Thank You to PurplFox For This Useful Post:
Nliiitend1 (11-22-2016)
 Old 12-01-2016, 01:03 PM   #25
bast525's Avatar
Posts: 487   (View Stats)
bast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond repute
Groaned at 3 Times in 1 Post
Would the struts need to be completely removed to swap out the mounts? I'm trying to eliminate some clunk in the front end and these are on my short list of things to replace, but the struts themselves are not that old and I don't think they need replacing.
How difficult/time consuming of a job to replace these mounts?
'07 Speed 3 GT, Red, MSCAI with flow straightener, 2nd cat delete, JBR TMM, AWR RMM, and Cobb AccessPORT running custom 20% e85 tune.
bast525 is offline   Reply With Quote
 Old 12-01-2016, 02:26 PM   #26
PurplFox's Avatar
yes and no lol.
but easiest to remove strut, replace tophat reinstall. no longer than replacing a strut, about 30 min per side, if you are well versed in tools
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
bast525 (12-01-2016)
 Old 12-01-2016, 02:40 PM   #27
bast525's Avatar
Yeah, pretty good with tools, but never removed the struts on this car myself before. Other than a spring compressor, any other "special" tools needed? Gonna search and see if anyone has posted a walkthrough
 Old 12-01-2016, 02:53 PM   #28
thrisnospork's Avatar
Posts: 254   (View Stats)
You'll need an offset wrench for the middle top nut, I think stock is 14mm.
thrisnospork is offline   Reply With Quote
 Old 12-01-2016, 03:39 PM   #29
PurplFox's Avatar
Ive found that if you compress the spring enough you can get the nut run down almost all the way, but break the strut bolt loose before lifting the car. Or like ^^^he said get an offset wrench. oh and a 4lbs sledge helps with the spindle
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 05-18-2017, 09:47 AM   #30
ajw85's Avatar
Posts: 35   (View Stats)
ajw85 has a spectacular aura aboutajw85 has a spectacular aura about
Any updates as to how these are holding up?
I rebuilt my OEM top hats when I installed my CS adjustables but now they are clicking and binding up the spring. I'm looking to get new parts and be done with the suspension.
ajw85 is offline   Reply With Quote
 Old 05-18-2017, 03:14 PM   #31
EvoFire's Avatar
They work, just buy them. I had them for 3 years, recently sold my car and they are still good.
 Old 05-18-2017, 04:02 PM   #32
stockms3's Avatar
Groans: 74
Yeah no problems at all and I have been driving the car a bit more lately.
 Old 05-11-2018, 11:34 AM   #33
Kuna Alex's Avatar
Posts: 2   (View Stats)
Kuna Alex has a little shameless behaviour in the past
This thread is awesome! Million thanks!
When I asked Mazda for OEM, I think they told me $200 a piece! So $400 a pair... How come Ford sell these for $60 a pair?
Did you also change the rear ones, or thats no necessary ?
Kuna Alex is offline   Reply With Quote
 Old 11-24-2018, 09:45 AM   #34
Carskick's Avatar
Posts: 315   (View Stats)
Carskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond repute
Sorry to rez an old thread, but just wanted to update the part number.
There is now a D revision of the bearing: DV6Z-18198-D
It looks the same from what I can tell, but I will update once i get it to let you all know that it still works. Hopefully they just made it better!
Getting both the top hat & bearing shipped from Tasca with Cyber Monday Pricing came to just over $100 shipped.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Carskick is offline   Reply With Quote
The Following 2 Users Say Thank You to Carskick For This Useful Post:
MSMS3 (12-02-2018), Nliiitend1 (11-26-2018)
 Old 12-02-2018, 09:46 PM   #35
MSMS3's Avatar
Posts: 2,825   (View Stats)
Just did this with the Ford Focus revised part numbers above, from Tasca.
Perfect fit. Tab on the strut bearing faces you. The three tabs on the top hat face the engine.
My passenger side strut bearing was so bad that it just fell apart once the spring was compressed. Ball bearings went everywhere in the shop floor under the car. That was Dorman junk.
 Old 12-27-2018, 08:30 AM   #36
mgeoffriau's Avatar
Posts: 17   (View Stats)
mgeoffriau has a spectacular aura aboutmgeoffriau has a spectacular aura about
Used these as well when replacing my front struts with some Bilstein HD's. Worked perfectly. For the price (and quality), there's no reason to bother trying to salvage or rebuild the original stuff.
2009 MS3 | Pretty Much Stock
mgeoffriau is offline   Reply With Quote
 Old 02-11-2020, 04:35 PM   #37
leifmadsen's Avatar
Posts: 18   (View Stats)
leifmadsen is a jewel in the roughleifmadsen is a jewel in the roughleifmadsen is a jewel in the roughleifmadsen is a jewel in the rough
Another bump for part number update. I tried to order a part number from a Ford dealer in Canada, and the part DV6Z-18198-D is discontinued. I asked if it was replaced with another strut bearing, and he said the latest version is AD1151.
leifmadsen is offline   Reply With Quote
The Following 3 Users Say Thank You to leifmadsen For This Useful Post:
Anaphra (02-11-2020), Db09ms3 (02-11-2020), stockms3 (02-11-2020)
 Old 02-16-2020, 07:58 AM   #38
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
This checks, but both part numbers are on the tag. I ordered these a few months ago and just decided to rip into the box out of curiosity. I haven't put them in yet. The bearings are made in Germany and the mounts are made in Italy. I haven't been able to put them side-by-side with the Mazda parts since I haven't put them in yet. I've had a knocking sound over bumps for years and assumed it was the bearings, but it is probably sway-bar end links. Either way, I'll throw these in at some point. My Bilsteins have about 120k miles on them, so maybe one day I will replace them or have them rebuilt.
Frequentflyer is offline   Reply With Quote
Reliable strut mounts & bearings needed Peter B MazdaSpeed 3/6 - Suspension & Brakes 28 09-19-2015 11:23 AM
Page generated in 0.56230 seconds with 44 queries
