| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
(Thread Starter) | Neutral : +3 score I will be replacing old Koni yellows with some new ones and of course decided to do some research as to which parts to use. I've found we have an amazing CHEAP option and that is top hats and bearings directly from Ford. I paid about $55 for both sides SHIPPED from tasca ford. The parts look like they are great quality and both are made in Europe. Definitely, a better option than OEM or rockauto. UPDATE: Parts were installed and everything fits perfectly. Even the stock boot. Part numbers: bearings: DV6Z-18198-C (made in Germany) top hats: CV6Z-18183-A (made in Italy) Pics: Old top hat vs new close up: Old bearing: New bearing (notice the lip, it is on the bottom part, I assume its to stop shit from getting into the bearing and trashing it):
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. Last edited by stockms3; 07-05-2016 at 04:36 PM. |
| The Following 24 Users Say Thank You to stockms3 For This Useful Post: | brandon3212 (06-05-2016), Carskick (11-24-2018), Code Monkey (06-03-2016), dan7225 (06-03-2016), Design (10-07-2016), Easter Bunny (09-23-2016), hartlch (06-04-2016), impossible (06-04-2016), juantaquitos (12-18-2018), KiwiFlavor (06-02-2016), Kuna Alex (05-11-2018), MD1032 (06-04-2016), MSMS3 (06-03-2016), necrophrenic (05-19-2018), Nliiitend1 (06-03-2016), rob ms6gt (07-11-2016), Silaramic (09-21-2016), snailD (06-02-2016), Snyeed (06-02-2016), thrisnospork (06-01-2016), Tomas (07-05-2016), WetzMS3 (07-08-2016), Yatta (06-03-2016), [R]usty (06-03-2016) |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score Interesting... Let us know how this goes
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | snailD (06-02-2016) |
Groans: 74
(Thread Starter) | Not Ranked : 0 score Its going to be another week or so till I actually get around to it. I need to powdercoat the springs first but I will definitely update the thread.
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. |
| The Following 3 Users Say Thank You to stockms3 For This Useful Post: |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
| The Following User Says Thank You to snailD For This Useful Post: | KiwiFlavor (06-04-2016) |
![]() Join Date: Oct 2013 Location: Dundas, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score If these tophats work - does that mean we can use ford focus camber plates? Last edited by swd120; 06-03-2016 at 12:01 AM. |
Groans: 74
This weekend if I have some time I will take a look at my fiancee 2012 focus and see what other parts might fit .Edit: Looks like SPC rear adjustable upper arm is the same too!
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. | |
| The Following 2 Users Say Thank You to stockms3 For This Useful Post: | impossible (06-04-2016), snailD (06-03-2016) |
| The Following User Says Thank You to swd120 For This Useful Post: | Tomas (07-05-2016) |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
| Not Ranked : 0 score Great find! Subbed for results.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Interesting! Bookmarked just incase I go with another strut/shock combo vs a drag coilover.
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
Groans: 74
(Thread Starter) | Not Ranked : 0 score So, big update!!!! Finally got around to installing the shocks/struts. I am happy to report that everything fits great! Even the factory boot fits no problem on the Ford bearing. I will be taking a closer look at a suspension from a 2012 ford focus it appears that the front struts would also fit. I roughly looked at control arms and they look very similar.
| The Following 5 Users Say Thank You to stockms3 For This Useful Post: | KiwiFlavor (07-05-2016), Nliiitend1 (07-06-2016), Ranyard (07-05-2016), snailD (07-05-2016), WetzMS3 (07-08-2016) |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
![]() Join Date: Jun 2012 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score I've been running these top hats and bearings for the last 2 years. Way cheaper and better than the Mazda ones.
__________________ 2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob Dyno'ed at 277whp/290lb-ft on 91 piss |
| The Following 5 Users Say Thank You to EvoFire For This Useful Post: | Easter Bunny (09-23-2016), KiwiFlavor (07-08-2016), Nliiitend1 (07-06-2016), snailD (07-05-2016), stockms3 (07-05-2016) |
![]() Join Date: Nov 2011 Location: Houston Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 117
| Not Ranked : 0 score Installed these on my 2012. Fit perfectly.
__________________ 2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks 2003 A4 1.8TQ APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars. |
![]() Join Date: Dec 2010 Location: Miamisburg, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 149
| Not Ranked : 0 score yep, put on my 13 yesterday, much nicer than RA or oem
__________________ "The eagle never lost so much time as when he submitted to learn from the crow" ...nobody |
![]() Join Date: Oct 2014 Location: sudbury ON, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 82
| Not Ranked : 0 score how did you get these for $55?! comes up to 83$ before shipping for me? |
Groans: 74
(Thread Starter) | Not Ranked : 0 score Where are you looking them up? Tasca ford? Sent from my Nexus 6P using Tapatalk
Groans: 74
![]() | | #19 | ![]() |
![]() Join Date: Jun 2012 Location: Wichita, KS
| Not Ranked : 0 score When I was looking at these I found if I searched using C-max or Courier van the identical part was cheaper than when searching using the Focus. FWIW, Tasca wasn't the cheapest when I looked but I don't remember the name of the website that was cheaper. I moved on when I stumbled on affordable camber plates that use the Ford bearing.
__________________ '10 VRM MS3 3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3 Strive for perfection in everything. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough. Sir Henry Royce |
![]() | | #20 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score If anyone is looking for a brand new set of the bearings; I have them up for sale in the gen2 section.
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite |
![]() | | #21 | ![]() |
![]() Join Date: May 2013 Location: CO
Rep Power: 2406 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
![]() | | #22 | ![]() |
![]() Join Date: Nov 2014 Location: La Porte, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score moog has these as well 66 a side. 908961 pt number. probably going to snag these next payday and maybe the k80001 camber kit just to play around with it
__________________ Cobb AP JBR Tru-3.0 CNT Catted DP "Gutted" CNT Catback JBR 88 RMM DM PMM and TMM 3 port, Turbosmart dual port FReaktune E33 |
![]() | | #23 | ![]() |
It's made for the original C170 chassis Focuses (2000-2011), not the later "Global C Platform" that was an evolution of the C1 chassis, upon which the MS3 is built. ...as for the 908961 part, Google is leading me to believe it is a Monroe part. Did you mis-type?
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Shit, you're right. yeah thats the monroe set.
| The Following User Says Thank You to PurplFox For This Useful Post: | Nliiitend1 (11-22-2016) |
![]() | | #25 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Would the struts need to be completely removed to swap out the mounts? I'm trying to eliminate some clunk in the front end and these are on my short list of things to replace, but the struts themselves are not that old and I don't think they need replacing. How difficult/time consuming of a job to replace these mounts?
__________________ '07 Speed 3 GT, Red, MSCAI with flow straightener, 2nd cat delete, JBR TMM, AWR RMM, and Cobb AccessPORT running custom 20% e85 tune. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score yes and no lol. but easiest to remove strut, replace tophat reinstall. no longer than replacing a strut, about 30 min per side, if you are well versed in tools
| The Following User Says Thank You to PurplFox For This Useful Post: | bast525 (12-01-2016) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Yeah, pretty good with tools, but never removed the struts on this car myself before. Other than a spring compressor, any other "special" tools needed? Gonna search and see if anyone has posted a walkthrough
![]() | | #28 | ![]() |
![]() Join Date: Feb 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 139
| Not Ranked : 0 score You'll need an offset wrench for the middle top nut, I think stock is 14mm. |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Ive found that if you compress the spring enough you can get the nut run down almost all the way, but break the strut bolt loose before lifting the car. Or like ^^^he said get an offset wrench. oh and a 4lbs sledge helps with the spindle
![]() | | #30 | ![]() |
![]() Join Date: Jul 2013 Location: Saint Louis
Rep Power: 0 ![]() ![]() Thanks: 5
| Not Ranked : 0 score Any updates as to how these are holding up? I rebuilt my OEM top hats when I installed my CS adjustables but now they are clicking and binding up the spring. I'm looking to get new parts and be done with the suspension. |
![]() | | #31 | ![]() |
| Not Ranked : 0 score They work, just buy them. I had them for 3 years, recently sold my car and they are still good.
![]() | | #32 | ![]() |
Groans: 74
(Thread Starter) | Not Ranked : 0 score Yeah no problems at all and I have been driving the car a bit more lately.
![]() | | #33 | ![]() |
![]() Join Date: May 2018
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score This thread is awesome! Million thanks! When I asked Mazda for OEM, I think they told me $200 a piece! So $400 a pair... How come Ford sell these for $60 a pair? Did you also change the rear ones, or thats no necessary ? |
![]() | | #34 | ![]() |
![]() Join Date: May 2016 Location: Sarastoa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score Sorry to rez an old thread, but just wanted to update the part number. There is now a D revision of the bearing: DV6Z-18198-D It looks the same from what I can tell, but I will update once i get it to let you all know that it still works. Hopefully they just made it better! Getting both the top hat & bearing shipped from Tasca with Cyber Monday Pricing came to just over $100 shipped.
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks |
| The Following 2 Users Say Thank You to Carskick For This Useful Post: | MSMS3 (12-02-2018), Nliiitend1 (11-26-2018) |
![]() | | #35 | ![]() |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Just did this with the Ford Focus revised part numbers above, from Tasca. Perfect fit. Tab on the strut bearing faces you. The three tabs on the top hat face the engine. My passenger side strut bearing was so bad that it just fell apart once the spring was compressed. Ball bearings went everywhere in the shop floor under the car. That was Dorman junk.
![]() | | #36 | ![]() |
![]() Join Date: Mar 2014
| Not Ranked : 0 score Used these as well when replacing my front struts with some Bilstein HD's. Worked perfectly. For the price (and quality), there's no reason to bother trying to salvage or rebuild the original stuff.
__________________ 2009 MS3 | Pretty Much Stock |
![]() | | #37 | ![]() |
![]() Join Date: Dec 2013
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Another bump for part number update. I tried to order a part number from a Ford dealer in Canada, and the part DV6Z-18198-D is discontinued. I asked if it was replaced with another strut bearing, and he said the latest version is AD1151. |
![]() | | #38 | ![]() |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score This checks, but both part numbers are on the tag. I ordered these a few months ago and just decided to rip into the box out of curiosity. I haven't put them in yet. The bearings are made in Germany and the mounts are made in Italy. I haven't been able to put them side-by-side with the Mazda parts since I haven't put them in yet. I've had a knocking sound over bumps for years and assumed it was the bearings, but it is probably sway-bar end links. Either way, I'll throw these in at some point. My Bilsteins have about 120k miles on them, so maybe one day I will replace them or have them rebuilt.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
| Display Modes | |
| Reliable strut mounts & bearings needed | Peter B | MazdaSpeed 3/6 - Suspension & Brakes | 28 | 09-19-2015 11:23 AM |
