  • 2 Post By Bob-o
 Old 01-09-2012, 07:00 AM   #1
amc5's Avatar
Posts: 88   (View Stats)
amc5 is just really niceamc5 is just really niceamc5 is just really niceamc5 is just really niceamc5 is just really nice
Default Another.. is my suspension shot thread
Car has not been lowered. However, when I hit dips in the road, or go around a banked turn in, like a driveway, my tires rub. Sounds more on the rear.
Plus getting some of the pops and knocks like everyone else. Car feels like a wagon on bumps.
Sometimes turning I get a pop/grind/notchy metal sound.
Car has 57k miles
Looking to upgrade shocks soon. Something with a smoother ride. Wont be doing any roadracing or anything.
Thanks!!
amc5 is offline   Reply With Quote
 Old 01-09-2012, 08:02 AM   #2
Bob-o's Avatar
Posts: 1,312   (View Stats)
The pop/grind/notch when you turn is 90% probably your strut bushings. That's a wear item, and 57k seems like a good time to replace em. I wouldn't be surprised if the struts on your car may have gone too, cause they come quite underdamped from the factory.
Open your hood, put 2 fingers on the center bolt of your strut mount. Have a friend/wife/gf/dog turn the wheel all the way from one end to the other, and back. It theres anything less than smooth movement; ie. you feel a pop/grind/clunk, then start with replacing strut bushings and mounts.
If you reach behind and feel your struts in the rear, and they feel greasier than a teenager's face, your struts are leaking/blown.
GLHF
amc5 and Dax like this.
The Following 2 Users Say Thank You to Bob-o For This Useful Post:
ak_spray (01-09-2012), amc5 (01-09-2012)
 Old 01-09-2012, 08:19 AM   #3
amc5's Avatar
Thanks man. lol dog.. haha..
So will saggy shit blown struts be causing my rubbing/scraping issues? I am long past the days of actually wanting to scrape and rub tires (ex minitrucker).
 Old 01-10-2012, 08:52 AM   #4
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
It makes more sense to properly size your tires or roll the fenders than blame the struts on rubbing. The struts are not supposed to be relied on to set sag or prevent your tire from contacting the fender...
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline   Reply With Quote
 Old 01-09-2012, 08:27 AM   #5
Bob-o's Avatar
Yes that is correct. With the shock lacking pressure, the car may slouch, and if you are running an aftermarket wheel or tire with a lower offset, it will rub. That's why when some people switch from a stock shock to a koni or bilstein shock, they notice their car has raised a little.
 Old 01-10-2012, 08:31 AM   #6
amc5's Avatar
popping noise came back yesterday intermittently. I am thinking suspension for sure. Almost sounds like a threaded rod being rubbed up and down through a hole if that makes since.
anyone care to share a suggestion on a good shock/strut that is a happy medium between sport ride and smooth?
 Old 01-10-2012, 08:43 AM   #7
nofear72784's Avatar
Posts: 72   (View Stats)
nofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond repute
Have you check the sway bar links for play? Haven't screwed with the rear susp of a 3 but the links are usually what go first on many makes. The wheel rubbing could be the shocks, are they wet around the shaft?
06 Pearl White MS6 Grand Touring- Cobb SRI- Cobb TIP- BNR S3- P&P Tb- Devils Own Meth kit- CP-E TMIC- Cp-e catless DP- Magnaflow Cb- CP-e RMM-Autotech Internals- Cobb AP with ATR- JBR short shift kit- Brembo GT big brake kit- Custom fiberglass A pillar gauge pod- Intercooler temp gauge
nofear72784 is offline   Reply With Quote
 Old 01-10-2012, 12:06 PM   #8
amc5's Avatar
Have not checked sway bar. Will do that...
The tires and wheels are the stock size.
 Old 01-10-2012, 12:16 PM   #9
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
and offset?
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
 Old 01-10-2012, 02:10 PM   #10
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Damper "stiffness" does not determine or affect static ride height. Springs do.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 01-10-2012, 02:17 PM   #11
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
I had some of the tire rubbing noise on my car which has stock wheels and suspension. Took a look at the rear, where I was hearing it and there was some of the plastic from the wheel well that was bent towards the tire so over certain bumps my rear tire was rubbing that plastic. Removed bent plastic, fixed rubbing problem.
 Old 01-11-2012, 06:11 AM   #12
SRTie4k's Avatar
I don't believe your stock wheels/tires should ever contact any portion of the fender on stock suspension, even with blown struts. It sounds like you might have a problem somewhere else.
 Old 01-12-2012, 09:46 AM   #13
Completely correct, the shocks/struts only control how fast or slow the springs are allowed to compress or decompress. If your rubbing you have something bent, a major alignment issue, tires that are too wide or the incorrect rim offset.
 Old 01-12-2012, 07:57 AM   #14
amc5's Avatar
Best i can tell, stock springs and shocks. I know the wheels are stock. I am going to do more investigation this weekend. I will take some pics of where its rubbing.
 Old 01-20-2012, 08:16 AM   #15
amc5's Avatar
The pops from the front can now be duplicated anytime. Whenever I put it in reverse, the front will pop. When I take off, it pops again. Anytime I stop fast and take of fast it does it. So something possibly loose?
The Official MS6 Suspension Thread RhoadBlock MazdaSpeed 3/6 - Suspension & Brakes 182 07-24-2018 11:38 AM
Another suspension noise/sound thread-Strut Bearing? Raider MazdaSpeed 3/6 - Suspension & Brakes 8 12-07-2011 09:57 PM
50 SHOT OF NOS dgr81izme MazdaSpeed 3 - Engine, Transmission & Driveline 59 12-01-2010 09:03 PM
Page generated in 0.35967 seconds with 26 queries
