 Old 12-08-2010, 12:53 PM   #1
bbjoy's Avatar
Posts: 113   (View Stats)
bbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to behold
Groaned at 5 Times in 2 Posts
Default Anyone on BC coilovers?
My stock suspension is shot so time for an upgrade.... I have a 2007 speed3 and just wondering if anyone is on BC BR coilovers and what theyre opinion is about them, are they good for a DD, are they easy to adjust, how do they handle, and are they durable.
bbjoy is offline   Reply With Quote
The Following 4 Users Say NO Thank You to bbjoy For This Un-useful Post:
CeeeJay (12-17-2010), KeysMS3 (12-17-2010), sellers (12-08-2010), spoolin00 (12-08-2010)
 Old 12-08-2010, 12:57 PM   #2
sellers's Avatar
Posts: 1,280   (View Stats)
sellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the world
Groans: 546
Groaned at 125 Times in 71 Posts
No, no one has ever bought BC coilovers.
sellers is offline   Reply With Quote
The Following 4 Users Say Thank You to sellers For This Useful Post:
CeeeJay (12-17-2010), I<3Groceries (12-12-2010), KeysMS3 (12-17-2010), spoolin00 (12-08-2010)
The Following User Says NO Thank You to sellers For This Un-useful Post:
bbjoy (12-08-2010)
 Old 12-08-2010, 02:05 PM   #3
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
i ran BCs for about a year here in VA, and my opinion of them is that they're very easy to bolt on as far as suspensions go, but they do sacrifice on comfort. they run linear springs, which are pretty rough going over bumps and make a decent amount of noise from the initial impact of bumps. for the price, you'll have a terribly hard time finding a coilover that gives you as much functionality, but there are definitely compromises when it comes to how well it performs.
basically, take this info and decide for yourself if it's sufficient for your DD needs. everyone is different, and what's comfortable enough for one may not be comfortable enough for someone else.
Sacrilicious is offline   Reply With Quote
 Old 12-08-2010, 02:10 PM   #4
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Brandon, I thought you said you already picked up some coils from that dude that builds drift cars?
 Old 12-08-2010, 02:30 PM   #5
bbjoy's Avatar
Havent gotten them yet....theyre just my best option at the moment for $1000..... still trying to shop around though for the best setup I can get. I wont be able to do anything until tax return time anyway ha
 Old 12-08-2010, 02:44 PM   #6
Groans: 35
just go BC....people seem to like. I hear replacement parts are cheap too.
 Old 12-12-2010, 10:00 PM   #7
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
I've had a set on the car for nearly three years, and on their lowest height setting and most stiff dampening setting. I think they are fair for their price. Of course, you get what you pay for. I think they are a fair purchase for those on a budget.
I have a clunk up front that I haven't been able to investigate yet. Sounds an awful lot like a blown shock. We shall see. I know BC rebuilds their shit if you send it in to them. Not a big deal for me, as I hardly drive the car any more anyway.
There's just as many, if not more people who will deter you from BC, than there is who will emplore you to run them.
 Old 12-13-2010, 05:15 AM   #8
pewpew
if yours is anything like mine, it's due to the top hat nut coming loose. try this: jack one of the front wheels off the ground and then just use your hand to see if the really big nut below the dampening-adjustment knob is loose. that was the problem with mine, and it went away as soon as i tightened it. you can actually tighten this nut with the coil still installed in the car if you use a 19mm (i think) open-faced wrench.
The Following User Says Thank You to Sacrilicious For This Useful Post:
I<3Groceries (12-13-2010)
 Old 12-13-2010, 02:52 PM   #9
IM A SCAMMER
BlackMS6's Avatar
Posts: 63   (View Stats)
BlackMS6 is just really niceBlackMS6 is just really niceBlackMS6 is just really niceBlackMS6 is just really nice
I had the same top hat issue. I raised the front of the car off the ground like you to tighten the 2 nuts on the top hats and havent had them come loose yet.
BlackMS6 is offline   Reply With Quote
 Old 12-13-2010, 01:21 AM   #10
IM A SCAMMER
BlackMS6's Avatar
Ive had my BCs on for about almost 3yrs now and they have been serving there purpose very well. In the end though the decision is yours, I vote yes!
 Old 12-13-2010, 12:03 PM   #11
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Very common for the top nut to come loose on coilovers over time - especially if your strut constantly makes contact with the bump stop. Has happened to at least 5 members here already. BC's are not horrible but they are not a "set it and forget it" type of suspension. Lots of failed components and warranty claims in the long term. If you don't mind the nuisance of taking your suspension apart on multiple occasions then they should suit you just fine. The combined failure rate on Bilstein, Koni, H&R, Eibach, KW, Greddy, and AutoExe is much smaller in comparison.
09 CWP MS3 GT
Ownership & Build Thread
The Following User Says Thank You to Design For This Useful Post:
 Old 12-13-2010, 02:59 PM   #12
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Here's my take:
http://www.mazdaspeedforum.org/forum/foru...-setups-39059/
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 12-17-2010, 07:20 PM   #13
Markspd6's Avatar
Posts: 137   (View Stats)
Markspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to behold
Always heard they were shit.. I think kw has a budget line of coils now? I'd look into those.l they're called suspension teqniques
Markspd6 is offline   Reply With Quote
 Old 12-17-2010, 07:30 PM   #14
CeeeJay's Avatar
Posts: 43   (View Stats)
CeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to beholdCeeeJay is a splendid one to behold
Yes, similar to KW v1 but doesn't have the stainless steel body on the dampener. Theres also a $100 mail in mfg rebate if you purchase before the end of the month
CeeeJay is offline   Reply With Quote
 Old 12-17-2010, 08:40 PM   #15
Markspd6's Avatar
Yeah was lookin into that.. But thyve got two sets for the 6 and no specific set for the ms6..
 Old 12-18-2010, 12:44 AM   #16
s!lv!a's Avatar
Posts: 89   (View Stats)
s!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud ofs!lv!a has much to be proud of
I'm running bc's (on my Miata... Lol) and I love them. I had Stance on my s14 for almost two years and I can vouch for stance being a badass company too but a bit more pricey. Either way you can't go wrong
s!lv!a is offline   Reply With Quote
D2 RS coilovers SMC MazdaSpeed 3/6 - Suspension & Brakes 4 07-08-2009 09:48 AM
GB: D2 RS Coilovers kevin@gripgarage.com Mazdaspeed3/6 General Discussion 1 04-09-2009 04:33 PM
BC Coilovers FTW wassup61 MazdaSpeed 3/6 - Suspension & Brakes 3 03-14-2009 06:28 PM
what is need with coilovers ms3boost MazdaSpeed 3/6 - Suspension & Brakes 1 03-11-2009 10:33 AM
Page generated in 0.46222 seconds with 30 queries
