 Old 03-13-2011, 07:31 PM   #1
MS6FL's Avatar
Posts: 1,753   (View Stats)
MS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the world
Groans: 43
Default Ball joint help?!
Any suggestions......
I was putting the nut back on the ball joint stud and seems like the stud was a lil messed up and started cross treading. Was holding the stud with an allen and that started to strip....Not having luck. My Question is: Do you think i can pick up a new nut (I think it is a M12x1.25??) and a tap and die set from Sears to clean up the treads on the Ball joint stud? Or should i tale the control arm off and get a new ball joint installed? I HAVE to get this fixed tomorrow. Thanks.
“From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley
MS6FL is offline   Reply With Quote
 Old 03-16-2011, 04:01 PM   #2
MS6FL's Avatar
Groans: 43
Well for anyone interested, A Sears Tap and die kit worked. Yes it is M12x1.25 and it uses a 6mm Allen key.
Size of Pinch Bolt for Ball Joint? 802MS3 MazdaSpeed 3/6 - Suspension & Brakes 1 01-31-2011 02:30 PM
How To Replace A Ball Joint, Transmission Has No Power, Toyota Tundra Check Engine Light, When To Use Injector Cleaner, Haltech Automotive News 0 06-05-2009 03:40 PM
Chevy Malibu Interior Smells Like Gas, How To Replace Boot on Lower Ball Joint of Dodge Dakota, Incorrectly Routed Serpe Haltech Automotive News 1 12-05-2008 09:46 AM
Page generated in 0.22516 seconds with 20 queries
