 Old 02-28-2011, 04:00 PM   #1
Magier's Avatar
Posts: 15   (View Stats)
Magier is a jewel in the roughMagier is a jewel in the roughMagier is a jewel in the roughMagier is a jewel in the rough
Default BBK for Mazdaspeed6
Hey guys
I'm currently looking for a BBK for my Mazdaspeed6 but so far I only found the Brembo and the Rotora kit.
Stoptech seems to have one for the speed3, but none for the speed6. Anything else you might be able to recommend?
Of course I know about most of the rotor and pad combinations, but now I'm solely looking around for a BBK...
Cheers
Stefan
Magier is offline   Reply With Quote
 Old 02-28-2011, 04:01 PM   #2
i8urgti's Avatar
Posts: 1,660   (View Stats)
i8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the world
Groans: 267
i would suggest getting better pads and rotors. why do you feel a need for a bbk?
2006 LPM MS6 GT (totaled)
0-60 mph : 4.2 second (as per DH)
12.83 @ ???MPH 1.67 60ft
2002 Miata Se (convertible whore)
i8urgti is offline   Reply With Quote
The Following User Says Thank You to i8urgti For This Useful Post:
jroc (03-01-2011)
 Old 02-28-2011, 04:07 PM   #3
Magier's Avatar
I'm currently driving Rotora Rotors with EBC Red Stuff and steel brake lines but still have fading when driving down our mountain roads in a sportive way...
Last time I could nearly press the pedal down to the floor before I got some braking effect. Not a good feeling when you're driving serpentine roads...
 Old 02-28-2011, 04:51 PM   #4
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
ATE Super Blue brake fluid.
The Following 3 Users Say Thank You to triplejumper18 For This Useful Post:
Angr-E1 (02-28-2011), Magier (03-01-2011), Stealth01 (02-28-2011)
 Old 02-28-2011, 04:55 PM   #5
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
This. Even with OEM pads, grooved OEM rotors, and rubber lines, I had NO problems on the Rocky Mountain roads I've driven. Now that I have StopTech rotors, Hawk HPS Pads, and SS lines, I want to try again, but you should NOT be having that much trouble. Especially since you ought to be downshifting more than braking.
Stealth01
2006 Mazdaspeed6 GT
The Following 3 Users Say Thank You to Stealth01 For This Useful Post:
i8urgti (02-28-2011), jroc (03-01-2011), Magier (03-01-2011)
 Old 03-01-2011, 12:08 AM   #6
jroc's Avatar
Posts: 1,482   (View Stats)
I track my car, and have to flush the brake fluid after every event.
I have a 26 mile (read: one way up, one way down) curvy mountain road, that I've gone up numerous times at almost every type of driving level, most of the time hauling ass on stock pads. Never had to change fluid.
Case in point, your brake fade is due to the reds boiling the fluid and/or getting the fluid too hot to be effective. Either get different brake pads, or slow down
JDMFresh.com 1990 Mazda Miata
The Following User Says Thank You to jroc For This Useful Post:
Magier (03-01-2011)
 Old 03-01-2011, 12:44 AM   #7
Magier's Avatar
The latter is no option on these roads so I will have to see if I can get better results with different brake pads or some other brake fluid. Thanks for your input...
 Old 03-01-2011, 12:54 AM   #8
jroc's Avatar
Personally, I run motul 600. Much higher boiling point that super blow, I mean blue. Might step up to motul 660. Or even a higher temp rated. Might have to when I switch to DTC-60 pads.
Mazda6/MazdaSpeed6 DTC y2kc0wb0y Mazdaspeed3/6 General Discussion 12 01-26-2009 11:11 AM
Page generated in 0.28521 seconds with 24 queries
