| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Oct 2008 Location: Greenbackville, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,927
(Thread Starter) | Neutral : -1 score I am compiling a list for myself and have spent about an hour doing it so this may help someone else down the road. Any inputs or suggestions let me know and I will try to keep this updated. ROTORS Front Racing Brake $115.43 (each) #9115-111 Centric $144.95 #120 .45078 StopTech $156.80 #120.45078 StopTech D&S $250 #127.45078L & 127.45078R PowerSlot $230 #126.45078SL & 126.45078SR Rotora $223.95 #R .45078x DBA $224.95 #42962SL + 42962SR (104 each through tirerack.com) Italia $295 Royalty Rotors $133.99 #R R45067SD Centric Premium Rotor $55.41 (each) #120 .45073 Rear Racing Brake $79.15 (each) #9023-111 Centric $144.95 #120 .45067 StopTech $100 #120.45067 StopTech Slotted $148.18 #126 .45067 StopTech Drilled $140 #126 .45067 StopTech D&S $154 #127.45067L & 127.45067R PowerSlot $176 #126.45067SL & 126.45067SR Rotora $144.95 #R .45067x DBA $209.95 #42957SL + 42957SR Italia $215 Centric Premium Rotor $30.39 (each) #120 .45074 PADS Front Hawk HPS $80 # HB549F.702 Hawk HP Plus $116 # HB549N.702 Hawk Performance Ceramic $87.16 #HB549Z .702 Carbotech Bobcat 1521 $137 #CT915-1521 EBC RedStuff $109.34 #DP31574C OEM $163 #B3YF-33-23Z Rotora H2 Ceramic MS6 only $87.95 #RP.11860.01 Akebono Euro- msrp $138.09 (place for brakes $67.66) 915A Hawk HT-10 $126.42#HB519S .682 Hawk HT-14 $126.42 #HB519V .682 Hawk DTC-60 $144.61 #HB519G .682 Rear Hawk HPS $64 # HB478F.605 Hawk HP Plus $75 #HB478N .605 Hawk Performance Ceramic $72.56 #HB478Z .605 EBC RedStuff $90.30 #DP31749C OEM $51.40 #C2Y3-26-48ZA Rotora H2 Ceramic MS6 only $68.95 #RP.11610.01 Akebono Euro- msrp $140.75 (place for brakes $68.97) 1095 - Rear Hawk HT-10 $131.65 #HB478S .605 Hawk DTC-60 $131.65 #HB478G .605 LINES Racing Brake $108 #BL908 Goodridge $129 #25048-4-LINE Corksport $99 #AXE-3-451 FLUID Motul RBF 600 Dot4 ~ $30 liter ATE Super Blue Dot4 ~ $14 liter >don't know enough still have to research what's worth using< Well for now this is what I have, I have excluded AutoExe since their stuff is super pricey and if you are spending that much you should probably just look at Big Brake Kits. My information was found in a few different places: http://www.corksport.com,http://edgeautosport.com all vendors. Also http://racingbrake.com, http://www.brakeworld.com, http://www.therpmstore.com, http://www.mazdaspeedstore.com, http://tripointengineering.com UPDATE 12-16-2011 MS6! Brake Rotors, Pads, SS Lines & BBKs for the MS6 ROTORS Front2960S AutoEXE Street Rotor $ -- MGS550S DBA Street Standard $ -- 2960 DBA Premium Street Slotted T2 $349.95 2960S DBA Street Drilled & Slotted $449.95 2960XS DBA 4000 Standard $ -- 42960 DBA 4000 Slotted $ -- 42960S DBA 4000 Drilled & Slotted $ -- 42960XS Disc Italia Slotted $280 -- Disc Italia Drilled & Slotted $280 -- EBC Ultimax USR Slotted $307.77 USR7393 Genuine MS6 Rotor $73.33 G31Y-33-25XA Powerslot Slotted $225 126.45073 Rotora Slotted $239 -- Rotora Drilled & Slotted $269 -- StopTech Street $80 309.11860 StopTech Coated $150 125.45073 StopTech Drilled $170 128.45073 StopTech Cryo Drilled $208 128.45073C StopTech Drilled & Slotted $250 127.45073 Rear AutoEXE Street Rotor $ -- MGS555S DBA Street Standard $ -- 2961 DBA Street Slotted $349.95 2961S DBA Street Drilled & Slotted $449.95 2961XS DBA 4000 Standard $ -- 42961 DBA 4000 Slotted $ -- 42961S DBA 4000 Drilled & Slotted $ -- 42961XS Disc Italia Slotted $245 -- Disc Italia Drilled & Slotted $245 -- EBC Ultimax USR Slotted $202.95 USR73934 Genuine MS6 Rotor $70.85 G31Y-26-251 Powerslot Slotted $159 126.45074 Rotora Slotted $165 -- Rotora Drilled & Slotted $199 -- StopTech Street $54 309.11610 StopTech Coated $110 120.45074 StopTech Drilled $104 128.45074 StopTech Cryo Drilled $146 128.45074C StopTech Drilled & Slotted $185 127.45074 PADS Front AutoEXE Street $137 MGS510P AutoEXE Sport $246 MGS510W Carbotech $146 CT915 Centric PosiQuiet $57 104.11860 Disc Italia Titanium Kevlar $80 -- Disc Italia Hyper Ceramic $95 -- EBC GreenStuff $89.95 DP217773 EBC RedStuff $119 DP31773C Genuine MS6 Pads $112.63 GPYA-33-2326 Hawk HPS $79.64 HB549F.702 Hawk HP Plus $115 HB449N.702 Hawk DTC $195 HB549W.702 ProACT Ceramic $64.95 ACT1164 Rotora H2 Ceramic $72 RP.11860.1 StopTech Street Performance $80 309.11860 Front AutoEXE Street $124 MGS520P AutoEXE Sport $217 MGS520W Carbotech $259 CT1161 Centric PosiQuiet $42 105.11610 Disc Italia Titanium Kevlar $60 -- Disc Italia Hyper Ceramic $75 -- EBC GreenStuff $69.95 DP217766 EBC RedStuff $119 DP31766C Genuine MS6 Pads $85.59 GPYB-26-49Z Hawk HPS $64.13 HB564F.567 Hawk HP Plus $115.94 HB564N.567 Hawk DTC $145 HB564W.567 ProACT Ceramic $59.95 ACT1161 Rotora H2 Ceramic $68 RP.11610.01 StopTech Street Performance $54 309.11610 SS Lines Auto EXE Sports Lines $560 MGS540 Corksport SS Lines $99 -- Techna-Fit SS Lines $89 MA-1255 Big Brake Kits Brembo BBK $1,429.99 -- Rotora BBK $1,795.99 RBK043.01 Corksport BBK $799.99 Wilwood 13" BBK $1,995 KSport ProComp 13" BBK $1,663 Taken from all the same website as OP, a few extra from google, and also www.tirerack.com/.
__________________ CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC PERM TUNED Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around 2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP Last edited by burn813; 10-28-2013 at 10:59 AM. Reason: Cullen Eats Penises |
| The Following 64 Users Say Thank You to jax ms3gt For This Useful Post: | -cj- (06-25-2011), 2008MS3H (12-18-2011), Arnie1229 (01-19-2015), atvfreek (08-29-2012), BIGPATTY101 (11-21-2013), BLURSPORTS (02-18-2011), Boother (02-18-2011), buckeyepost (12-06-2011), Constantin (04-11-2012), dagrimey1 (04-13-2015), Design (02-18-2011), DISIindahead (12-13-2011), Docnox (08-18-2011), ericm979 (02-18-2011), forcedinduktion (03-01-2011), Frequentflyer (02-18-2011), FreshAsWoodie (09-02-2013), galens47 (07-30-2013), grind75 (02-18-2011), Jackis (11-08-2011), JacksonMS30 (03-24-2011), Jakeypoo (02-21-2011), jjfam1 (02-06-2012), kgb (06-04-2012), kingbird72 (05-17-2012), kunfu (12-17-2011), labikesrcool (08-10-2011), mayer (02-24-2012), mazda.speed3 (02-18-2011), meelo88 (02-28-2011), Micha (10-31-2014), MrPrime (12-30-2013), MS6FL (06-03-2011), Nailedit187 (07-06-2016), Nataphen (01-28-2012), Nliiitend1 (02-18-2011), NoisyCricket (07-05-2013), Notorious AMA (01-07-2014), nycMS3 (10-05-2013), obijack (02-18-2011), onelove221 (11-07-2011), paveltol (08-02-2012), pebenito (02-18-2011), pipe (02-18-2011), PunjabiPlaya (02-18-2011), purpledrank (04-20-2014), R.MS3 (02-25-2011), Raider (02-18-2011), SarcasticOne (08-11-2013), sharky (02-20-2011), SkippyScallop (11-24-2014), SKiZ0TT (08-11-2011), Speed 3 Demon (03-13-2011), Speed3eak (03-03-2011), SPEEDfreak239 (01-22-2012), SpicyOrangeMSP (02-21-2011), Supernova Mafia (02-18-2011), tddvrrn (04-11-2012), TheFlash (02-16-2013), TheSchimann (02-19-2011), twincitySPEED6 (01-24-2014), uncorked11 (12-16-2011), usgiorgi (02-21-2014), zpele (06-23-2011) |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score Are those numbers posted after the price supposed to be part numbers? If so, something's up at least with the Hawk pad numbers... Those are not the part numbers for the Hawk MS3 pads. These are: Hawk HPS Front: HB549F.702 Rear: HB478F.605 Hawk HP+ Front: HB549N.702 Rear: HB478N.605 I don't have the numbers for the Ceramics, but I'm guessing they're not right either...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | jax ms3gt (02-18-2011) |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| The Following User Says Thank You to TRex For This Useful Post: | jax ms3gt (02-18-2011) |
__________________ CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC PERM TUNED Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around 2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP | ||
also im not sure if that price is for set or single | |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score whoa OEM front pads for $130? where at??
__________________ '08 CWP MS3 w/ T3 3071r |
(Thread Starter) | Not Ranked : 0 score from what I found earlier just said mazdaspeed motorsports..hold on I still have a million tabs open I will search again. unless you are being sarcastic, but everyone knows they are pricey so I can't tell.....
Groans: 221
also I think the part number ends in a "Z" not a 2. here is a decent price, $163, not sure about shipping though. FRONT PADS 2007-2009 MAZDASPEED3
__________________ '08 CWP MS3 w/ T3 3071r Last edited by 802MS3; 02-18-2011 at 02:27 PM. Reason: MSF Database - Automerged Doublepost | |
(Thread Starter) | Not Ranked : 0 score your right supposed to be Z, fixed.. thanks gotta update op, just found tri-point has rotors for cheap!.. SO FAR I APPRECIATE EVERYONES INPUT AND CORRECTIONS. I want this to be as correct and helpful as possible!
![]() Join Date: Dec 2010 Location: Atlanta, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 147
Pads Front Carbotech Bobcat 1521 $137 P/N CT915-1521 (At 07 08 MAZDA 3 MAZDASPEED Carbotech Bobcat 1521 Brake Pads CT915-1521) | |
| Not Ranked : 0 score to the op: thanks for taking the time. There is also a thread where people were experimenting with volvo s40 t5 awd brakes and had some success. OEM MS3 brakes = Volvo S60 brakes? |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score EBC Red Stuff Pads: Front: DP31574C ($109.34) Rear: DP31749C ($90.30) +10% off right now for Presidents Day. AJUSA.com
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
adding now, thanks! There is a lot of EBC stuff didn't add any of it yet..lol
__________________ CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC PERM TUNED Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around 2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP | |||
| Not Ranked : 0 score Thanks for all of the work. It doesn't go unnoticed. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | jax ms3gt (02-18-2011) |
(Thread Starter) | Not Ranked : 0 score added a couple more Hawk Motorsports pads..the first Hawks in list are labeled street, for what it's worth..
![]() Join Date: Jun 2010 Location: San Antonio, TX
| Not Ranked : 0 score Cool awesome info. So are the MS6 and MS3 front brakes pads the same? Thanks. |
![]() Join Date: May 2009 Location: Calgary
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 892
| Not Ranked : 0 score I don't see the OEM Rotors Front/back listed? Does anyone have the part numbers? i need to get some pretty soonish here Cheers, TriO` |
![]() | | #19 | ![]() |
| Not Ranked : 0 score It looks as if Akebono finally got the idea that the ms3 has bigger brakes and is adding a euro 915 (a) ceramic. I will definitely be getting these. Great performance... minimal dust. They haven't been released yet, but I'm going to e-mail them tonight for an estimated release date. |
![]() | | #20 | ![]() |
![]() Join Date: May 2009 Location: Tustin, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 365
| Not Ranked : 0 score This is a great resource! I can't tell you how helpful this is! also to add some current info...this popped up on tirerack for my car....i pulled from another thread for an MS6: Dunno how long they will be this price but it looks like a damn steal.... http://www.tirerack.com/brakes/resul...6&autoModClar= Centric Premium Rotor FRONT: P/N: 120.45073 Price: $65 REAR: P/N: 120.45074 Price: $38
__________________ "If I can't fix it, it was meant to be broken" [SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey TUNED BY NISHAN POWER SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG COSMETIC AND AUDIO Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4 Last edited by meelo88; 02-28-2011 at 11:49 AM. |
| The Following User Says Thank You to meelo88 For This Useful Post: | rfinkle2 (02-28-2011) |
![]() | | #21 | ![]() |
![]() Join Date: Aug 2008 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 60
| Not Ranked : 0 score These are only for MS6. I have had these on mine for almost 25k and they are great. Rotora H2 Ceramic Brake Pads for Mazdaspeed 6 (front) $87.95 RP.11860.01 http://www.therpmstore.com/product_i...roducts_id=592 Rotora H2 Ceramic Brake Pads for Mazdaspeed 6 (rear) $68.95 RP.11610.01 http://www.therpmstore.com/product_i...roducts_id=593
__________________ 2006 Mazdaspeed6 - "Cherry" * Forge BPV * Cobb SF SRI * Cobb TIP * NGK Iridium 1-step colder plugs * Side vent mounted 60mm Prosport Premium Boost Gauge * SU Test Pipe * CX-7 antenna * Clear side markers w/super white led's * R1 Concepts Slotted Rotors/Rotora Ceramic Pads * SU Rear Engine Mount * Magnaflow CBE * TWM Stage 2 SS w/bushings |
![]() | | #22 | ![]() |
| Not Ranked : 0 score Also found this as well... Centric Premium Rotor (FRONT) Manufacturer Part #: 120.45073 Price: $55.41 each Next Day Auto Parts - Discounted Price Auto Parts - NY, TX, FL, CA, DC, MD, NJ Centric Premium Rotor (REAR) Manufacturer Part #: 120.45074 Price: $30.39 each Next Day Auto Parts - Discounted Price Auto Parts - NY, TX, FL, CA, DC, MD, NJ
__________________ "If I can't fix it, it was meant to be broken" [SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey TUNED BY NISHAN POWER SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG COSMETIC AND AUDIO Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4 |
![]() | | #23 | ![]() |
![]() Join Date: May 2009 Location: Kingston MA
Rep Power: 227 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 258
| Not Ranked : 0 score wicked good list guy
__________________ 2009 MS3GT - JBR 3.0" Wide Path Full Intake System | CorkSport TMIC |NATOR'd Test Pipe | Autotech HPFP | COBB AP (freek PERM in process) | NGK LTR7IX-11 (6510) | SURE Anchors | Bilstein B8's | 35% Tint |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score added some of people's update to op..on a side note i have my rotors, pads, and ss brake lines on order! just gotta get fluid now...
| The Following User Says Thank You to jax ms3gt For This Useful Post: | rfinkle2 (03-01-2011) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score BTW Centric and Stoptech are the same and the numbers i posted are for the MS6 ONLY.. ..just FYI
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score yeah Centric, StopTech, and PowerSlot are all the same company now..
![]() | | #27 | ![]() |
| Not Ranked : 0 score EBC rotors (drilled (with blind hole even, not through hole) and slotted) front: GD7501 340.96 pair Rear: GD1315 185.44 pair EBC rotors (slotted) front: USR7501 311.70 pair Rear: USR1315 166.00 pair found here Edge Autosport also...i would like to start another database regarding what people are running...if you want to start it jax that would be cool...othewise i will get it going later today...something like year, mileage, mileage of first replacement, current set, mileage on current set....stuff like that |
| The Following User Says Thank You to TRex For This Useful Post: | rfinkle2 (03-23-2011) |
![]() | | #28 | ![]() |
| The Following User Says Thank You to jax ms3gt For This Useful Post: | rfinkle2 (03-24-2011) |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
| Banned ![]() Join Date: Feb 2011
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score I purchased a set of Wagner ThermoQuiet brake pads (front only) from Rock Auto for something ike $45 (before $15 mail-in rebate). You certainly get what you pay for. Do they stop you? Yes. Well? Not really. Conclusion: I wish I would have gotten something better but frankly spending $100+ for brake pads on my daily driver wasn't something I had considered. Please put these in your brake pad database as a "better than no brakes at all" contender. |
![]() | | #31 | ![]() |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I am looking at getting the StopTech Drilled front and back with RedStuff in the back and YellowStuff in the front with the Techna-Fit SS for my Speed6. Anyone used that combination? P.S. Sry, dont mean to jack your thread, just need some pronto help |
![]() | | #32 | ![]() |
| Not Ranked : 0 score My advice is to stay away from drilled rotors, for one. I've never used EBC products on my Mazda. I haven't used EBCs stuff since ~10 years ago after being wholly unimpressed with a set I had on my first Focus.
![]() | | #33 | ![]() |
| Banned ![]() Join Date: Sep 2008 Location: Calgary, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score The new P/N for: Centric Premium Rotors (Front) is 125.45078 Centric Standard Rotors (Front) is 121.45078 Both for the Mazdaspeed 3. |
| The Following User Says Thank You to Monkey_3 For This Useful Post: | TheFlash (02-22-2013) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Changed rotors/pads this weekend with Centric Premium rotors and Hawk HPS pads. Also flushed the system with Valvoline synthetic DOT3/4 fluid. As far as the pads go, the Hawk's definitely don't have the initial bite the OE pads do. Even with the OE pads down at 5mm, they still had more initial bite than the Hawks do which is amazing, but lay into the Hawks and they do stop just as good if not better. It just doesn't feel like it because you don't get that initial neck jerking of the stock pads, but make no mistake, the Hawks do perform. After bedding them in and putting about 100 miles on them already, I like the feel of the Hawk pads over the OE pads.
| The Following User Says Thank You to Frequentflyer For This Useful Post: | kunfu (12-17-2011) |
![]() | | #35 | ![]() |
![]() Join Date: Aug 2009 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score AIMCO (no idea, Chinese low end) front rotors: rwiamerica.com SKU 31363 $89 shipped pair Stoptech SS brake lines P/N 950.61010G: vr-speed.com $105 shipped set
__________________ 08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
![]() | | #36 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score Stoptech complete brake kit 977.45001 $585 Front and rear slotted rotors Front and rear street/track pads Front and rear ss brake lines This is probably what Ill end up doing here soon. My shits shot from autocross season.
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Post up how you like them.
![]() | | #38 | ![]() |
Groans: 221
| Not Ranked : 0 score I'm updating the OP with proper Centric rotor part #'s for front/rear MS3 if no one objects. Premium rotor (coating) 120.45078 Front 120.45067 Rear C-tek rotor (no coating, cheaper) 121.45078 Front 121.45067 Rear
![]() | | #39 | ![]() |
![]() Join Date: May 2008 Location: Brandon, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Brake Rotors, Pads, SS Lines & BBKs for the MS6 ROTORS Front AutoEXE Street Rotor $ -- MGS550S DBA Street Standard $ -- 2960 DBA Street Slotted $349.95 2960S DBA Street Drilled & Slotted $449.95 2960XS DBA 4000 Standard $ -- 42960 DBA 4000 Slotted $ -- 42960S DBA 4000 Drilled & Slotted $ -- 42960XS Disc Italia Slotted $280 -- Disc Italia Drilled & Slotted $280 -- EBC Ultimax USR Slotted $307.77 USR7393 Genuine MS6 Rotor $73.33 G31Y-33-25XA Powerslot Slotted $225 126.45073 Rotora Slotted $239 -- Rotora Drilled & Slotted $269 -- StopTech Street $80 309.11860 StopTech Coated $150 125.45073 StopTech Drilled $170 128.45073 StopTech Cryo Drilled $208 128.45073C StopTech Drilled & Slotted $250 127.45073 Rear AutoEXE Street Rotor $ -- MGS555S DBA Street Standard $ -- 2961 DBA Street Slotted $349.95 2961S DBA Street Drilled & Slotted $449.95 2961XS DBA 4000 Standard $ -- 42961 DBA 4000 Slotted $ -- 42961S DBA 4000 Drilled & Slotted $ -- 42961XS Disc Italia Slotted $245 -- Disc Italia Drilled & Slotted $245 -- EBC Ultimax USR Slotted $202.95 USR73934 Genuine MS6 Rotor $70.85 G31Y-26-251 Powerslot Slotted $159 126.45074 Rotora Slotted $165 -- Rotora Drilled & Slotted $199 -- StopTech Street $54 309.11610 StopTech Coated $110 120.45074 StopTech Drilled $104 128.45074 StopTech Cryo Drilled $146 128.45074C StopTech Drilled & Slotted $185 127.45074 PADS Front AutoEXE Street $137 MGS510P AutoEXE Sport $246 MGS510W Carbotech $146 CT915 Centric PosiQuiet $57 104.11860 Disc Italia Titanium Kevlar $80 -- Disc Italia Hyper Ceramic $95 -- EBC GreenStuff $89.95 DP217773 EBC RedStuff $119 DP31773C Genuine MS6 Pads $112.63 GPYA-33-2326 Hawk HPS $79.64 HB549F.702 Hawk HP Plus $115 HB449N.702 Hawk DTC $195 HB549W.702 ProACT Ceramic $64.95 ACT1164 Rotora H2 Ceramic $72 RP.11860.1 StopTech Street Performance $80 309.11860 Front AutoEXE Street $124 MGS520P AutoEXE Sport $217 MGS520W Carbotech $259 CT1161 Centric PosiQuiet $42 105.11610 Disc Italia Titanium Kevlar $60 -- Disc Italia Hyper Ceramic $75 -- EBC GreenStuff $69.95 DP217766 EBC RedStuff $119 DP31766C Genuine MS6 Pads $85.59 GPYB-26-49Z Hawk HPS $64.13 HB564F.567 Hawk HP Plus $115.94 HB564N.567 Hawk DTC $145 HB564W.567 ProACT Ceramic $59.95 ACT1161 Rotora H2 Ceramic $68 RP.11610.01 StopTech Street Performance $54 309.11610 SS Lines Auto EXE Sports Lines $560 MGS540 Corksport SS Lines $99 -- Techna-Fit SS Lines $89 MA-1255 Big Brake Kits Brembo BBK $1,429.99 -- Rotora BBK $1,795.99 RBK043.01 Taken from all the same website as OP, a few extra from google, and also www.tirerack.com/. |
| The Following User Says Thank You to RhoadBlock For This Useful Post: | SKiZ0TT (01-24-2012) |
![]() | | #40 | ![]() |
![]() Join Date: Jan 2011 Location: Scranton, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,797
Groans: 62
| Not Ranked : 0 score ^^^nice work, thanks! but you missed centriz rotors, it's too lte and i'm too drunk to look them up but i know kns brakes has them
__________________ Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL |
| The Following User Says Thank You to Don06speed6 For This Useful Post: | down_shift (04-12-2014) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/brakes-database-mazdaspeed-3-mazdaspeed-6-a-72761/ | ||||
| günstigste Variante Bremsen zu tauschen - Seite 12 | This thread | Refback | 09-22-2014 12:21 PM | |
| Brake rotors | SpeedForums.org | This thread | Refback | 01-16-2012 10:44 AM | |
| HOW-TO DATABASE MS6 | MATT DAMOND | MazdaSpeed 6 - How-To's | 42 | 11-21-2016 07:07 AM |
| HOW-TO DATABASE MS3 | MATT DAMOND | MazdaSpeed 3 - How-To's | 39 | 07-15-2015 07:29 AM |
| Cobb AP Map Database? | DaAznKnight | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 11-30-2010 06:14 PM |
| 2009 MS3 brakes vs. 2010 MS3 brakes | Driver72 | 2010 MS3 - Suspension & Brakes | 11 | 11-21-2009 10:34 AM |
