 Old 05-27-2009, 01:10 PM   #1
08BLKMS3's Avatar
Posts: 240   (View Stats)
08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future
Default Camber problems with COBB/H&R springs?
I need to know if those who are running on COBB or H&R springs have any type of camber problems. Thanks.
08BLKMS3 is offline   Reply With Quote
 Old 05-27-2009, 03:13 PM   #2
08BLKMS3's Avatar
damn no one has any insight on this?
 Old 05-27-2009, 03:22 PM   #3
Eazy's Avatar
Posts: 1,539   (View Stats)
Eazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the world
Groaned at 32 Times in 14 Posts
Cobb is supposedly within specs, but as with any suspension modification an alignment is a good idea.
Eazy is offline   Reply With Quote
 Old 05-27-2009, 03:52 PM   #4
Eazy's Avatar
Cobb does not require camber plates.... it's not a bad idea, but not necessary.
i don't know about H&R
There are a ton of threads about this.
 Old 05-27-2009, 03:45 PM   #5
08BLKMS3's Avatar
True but there is threshold on how well an alignment can help without a camber kit. Just don't want to get springs and have a big hassle with camber/alignment jobs. Hate going to places and them not doing an alignment with a camber kit because its aftermarket. Or just people that are complete idiots and don't try doing anything because they're lazing fuck tards.
 Old 05-27-2009, 04:04 PM   #6
08BLKMS3's Avatar
ok, lock it up then/delete it
 Old 05-28-2009, 12:05 PM   #7
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
I will answer you as completely as I can:
You won't NEED camber links with either in order for a shop to get your toe settings in check (which is about all they can do anyway, since camber isn't independently adjustable on either the front OR the rear UNLESS you have an aftermarket camber solution). There is a little bit of wiggle room for camber/caster adjustment on the front (you basically have to muscle the top of the strut mount into position and then tighten the bolts) but there's probably only +/- ~0.2 degrees adjustment there at the very best. Of course, the more you lower the car, the more negative your camber will be (especially in the rear, as the camber curve is substantially more agressive in the rear than in the front).
I, on the other hand, wouldn't lower this car AT ALL without at least putting in rear camber links to dial out some of the added negative camber. This car already has too much negative rear camber for my tastes, relative to the front...
Addikted To Boost (06-29-2010)
Cobb Springs-Impressions MidwestSpeed3 MazdaSpeed 3/6 - Suspension & Brakes 39 07-05-2010 01:16 PM
Camber problems when lowered? 08BLKMS3 MazdaSpeed 3/6 - Suspension & Brakes 3 10-30-2008 12:01 PM
MS6 + H&R springs...what about camber?? Street Sleeper6 MazdaSpeed 3/6 - Suspension & Brakes 1 09-25-2008 03:47 PM
Cobb fmic and forge bpv problems.. SharkDiver MazdaSpeed 3/6 - Turbo Induction 31 08-15-2008 06:51 PM
Page generated in 0.27285 seconds with 22 queries
