| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Nov 2009 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 789
Groaned at 6 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score The noise I was hearing was like Metal rubbing on Metal, plastic scraping on floor.. They were coming from the front left side of the car. Aside from that, it sounds like something is loose in the front end, when going over small bumps (it's been like that ever since I bought the car). Shocks does not feel blown at all. You can hear it all within the first minute of the video. the clunking noise is at 24-25 seconds.
__________________ Mazdaspeed3 E85 ~ Sold 333/383 Mazdaspeed6 #10018 TiGrey Forged Internals, PTE5858. 2015' Freektuned on 93Octane 322/337 (stock top mount and BPV) 2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor) 2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling) Mazda CX-5 AWD Daily |
![]() Join Date: Dec 2010 Location: Whitehall PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 869
Groans: 56
Groaned at 37 Times in 18 Posts
| Not Ranked : 0 score my rear left shock blew out at 57k miles. i would hit a bump and it would hit very hard like metal on metal sound. could be a simple bushing tho. get under the car and check for leaks
__________________ 2007 CBM MS3 GT 66K Mods: --Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV---- New VVT as of 50K miles Thanks Young MazdaNew K04 Turbo as of 57K miles Thanks Young Mazda Last edited by asall667; 12-11-2011 at 02:05 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to asall667 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score I checked already, there's no leaks. I'll be checking my sway bar bushings on monday. Hopefully it's not a blown shock. This car gotta last me another 3-4 months before it gets coilovers =|
Groans: 56
| Not Ranked : 0 score good luck to sir. its prolly not if ur getting clunking over small road rash and no leaks...u would def noticed the leak too. The dealer spotted a puddle under my car when mine blew thats how I found out.
__________________ 2007 CBM MS3 GT 66K Mods: --Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV---- New VVT as of 50K miles Thanks Young MazdaNew K04 Turbo as of 57K miles Thanks Young Mazda |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score These cars tend to squeak and creak when it's cold out. My car did it in stock suspension, and still does it on coilovers. Tapadatass
__________________ |
| The Following User Says Thank You to silvapain For This Useful Post: | predapio (12-24-2011) |
Groans: 56
| Not Ranked : 0 score After all, its a mazdas version of a "sports car". Car and Driver says if u want more luxury u should have bought a GTI lol FYVN
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
| Not Ranked : 0 score wait till it warms up then see if it goes away. the cold makes fluids thicker and closes tolerances in bushings so that may be where your noise is coming from
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
| The Angry Goose ![]() Join Date: Jun 2008 Location: Villa Park, IL
Rep Power: 701 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score When my shock (leaking)went bad I didn't have any noise. It felt unsteady while going through bumpy turns, but nothing else. When my endlink loosened, it sounded like someone was banging a hammer on the underside of my car.
__________________ Hector 2014 Mazda 3 2008 Mazdaspeed3-SOLD 1979 Mazda Rx7 |
| The Following User Says Thank You to Hectik1 For This Useful Post: | ak_spray (12-27-2011) |
![]() Join Date: Nov 2008 Location: Cleveland, OH
Rep Power: 223 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score below freezing my suspension makes some awful noises. they go away once the temps go back up.
__________________ 2008.5 MGM MS3 Cobb SRI, Cobb TIP, CP-E FMIC, Cobb Downpipe, CP-E HPFP, TRZ trans & RMM Cobb AP, Forge BPV, Solid shifter bushings |
| The Following User Says Thank You to Lytheum For This Useful Post: | predapio (12-24-2011) |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
| Not Ranked : 0 score mine made some hideous thunks when it firsts started dropping below chilly. i took it in and was told everything seemed solid. it has since quieted down. not sure if it needed to adjust to the cold or if it will come back when it starts dropping down further in temp. we'll see.
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] |
![]() Join Date: May 2008 Location: New orleans, la
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 294
| Not Ranked : 0 score Sounds Like strut mount. Its common for them to fail it seems |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score lol fwd sports car, hey what you using to mount your camera?
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score There is a thread on here from 3 years ago from yours truly, it explains what to watch for when it gets cold. Too lazy to search for it.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! |
| The Following User Says Thank You to predapio For This Useful Post: | kritz (12-24-2011) |
![]() Join Date: Jun 2008 Location: Raleigh NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
Groaned at 37 Times in 23 Posts
| Not Ranked : 0 score I replaced mine at 50k miles. Turns out they weren't blown but were extremely worn and couldn't rebound dampen worth a shit. Felt dangerous to drive. |
| Not Ranked : 0 score I'd say end link, sway bar bracket, or strut mount. |
(Thread Starter) | Not Ranked : 0 score Thanks guys, I'll probably fix this after winter. Going to find an aftermarket front sway bar and change it along with coilovers or strut/spring combo
| Not Ranked : 0 score I think you might need to check into ths sooner than later. |
![]() Join Date: Dec 2010 Location: Dayton, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,193
As far as an Aftermarket front sway bar you might have to get both of them in a set. As far as I know JBR is the only one that sells sway bars separately and he only sells the rear. If its a bad shock you need to get it taken care of asap. I didn't know mine was leaking and I took a hard turn on the highway and the back end stepped out. If it was intentional it would have been cool but when you aren't expecting it, its not.
__________________ 07 MS3 Sport CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon) JBR: RSB Cobb: Accessport Corksport: TMIC CNT: Catted Downpipe Last edited by ak_spray; 12-27-2011 at 07:25 AM. | |
![]() | | #19 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score I'd see if you can get it up on a lift and check lower control arms, sway bars and links. Just to see if everything is still tight.
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #20 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
If not, I'd suggest replacing that before messing with the front...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Put this on last week, really enjoying it and no squeaks from the rear anymore. You'd be supporting one of the best guys in the business too. Rear Sway Bar Kit 07'-2012 Black [MS3RSB-BLK] - $195.00 : James Barone Racing, Custom Fabrication
__________________ 07 MS3 Sport CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon) JBR: RSB Cobb: Accessport Corksport: TMIC CNT: Catted Downpipe |
| The Following User Says Thank You to ak_spray For This Useful Post: | Hectik1 (12-27-2011) |
![]() | | #22 | ![]() |
I've been debating on Used coilovers, but I think I'll settle with the following Bilstein Shocks/struts H&R or Eibach Springs Hotchkis FSB Some stiffer front and rear end links (haven't done much research on which to get yet) and JBR Rear camber arms. I was planning on purchasing Tigermack's Tein SS with 30k miles for a third of retail. But knowing he's a hardcore autocrosser, I am currently having second thoughts about it. Still unsure of what to do as of now. What would you do? Opinions? Options are: Bilstein Shocks/struts + 1.8 lowering spring (900 ish) Tein SS w/ 30k miles for 500 ish BC coilover w/ 20k for 400 ish
__________________ Mazdaspeed3 E85 ~ Sold 333/383 Mazdaspeed6 #10018 TiGrey Forged Internals, PTE5858. 2015' Freektuned on 93Octane 322/337 (stock top mount and BPV) 2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor) 2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling) Mazda CX-5 AWD Daily | |
![]() | | #23 | ![]() |
![]() Join Date: Dec 2017 Location: Chico CA for school. Originally From the Bay Area
Rep Power: 27 ![]() Thanks: 17
| Not Ranked : 0 score Did you ever figure out what the problem was? The attached videos sort of sounds like what i've got going on. But mine's more clunky and floor boardy
__________________ 2009 CWP GT MS3 Damond Motorsports RMM PMM and TMM Autotech HPFP Cobb SF Intake Cobb AP Autotech HPFP Corksport RSB+FSB Corksport Adjustable Short Throw Corksport Metal Skid Plate Koni FSD |
![]() | | #24 | ![]() |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Good luck getting a reply. The guy hasn't been on the forum since August 2018, and the last post here in this thread was 9 years before yours.
![]() | | #25 | ![]() |
| Not Ranked : 0 score Eh, it was worth a shot.
![]() | | #26 | ![]() |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score Knocking underneath the driver's feet is almost always the swaybar end links. If you are getting a clunking through the steering with what feels to be a little bit of "play", could be the strut bearings.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
![]() | | #27 | ![]() |
| Not Ranked : 0 score I is ended up replacing the top hats to try and fix the the sound and feeling I was getting. It ended up fixing a 1 sound I had that i guess over shadowed another, or something. But last week I finally crawled under there and found that the sway bar to endlink bolt had backout slightly, but enough to make noise. And I also discovered the reason as to why I wasn't able to originally find it. When ever I had the car up in the air or the wheel turned so that I could shake stuff, the swaybar and endlink would bind on each other somehow and not produce the noise. I know this thread is dead, but If anyone is interested I can post the video I got of the noise.
| Help me figure this out..... | Darksun280 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 117 | 06-08-2019 04:33 PM |
| Trying to figure out what this does. | andrewpiro | Mazdaspeed3/6 General Discussion | 6 | 06-22-2011 03:34 PM |
| Everyone, Please help me figure out WTF this is | volodya84 | MazdaSpeed 6 - Engine, Transmission & Driveline | 19 | 07-28-2010 09:31 PM |
| Low Boost .. cant figure it out .. | johnnyspeed6 | MazdaSpeed 3/6 - Turbo Induction | 28 | 06-27-2010 09:30 PM |
