| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
(Thread Starter) | Not Ranked : 0 score I am looking for a 1" coil spring spacers. I am a big'n and I always carry a 40lb tool bag in the back of my car and I have bearly in spec camber in the rear. So I am looking to go beefier such as the Cobb but I am not looking to ride lower. My jack only has 1/4" clearance as is. Have yall seen spacers so I can keep stock ride height? GM coil spring spacer pictured in the thread.
__________________ That pic is in a Miata. Damn midget mobile. Seat was all the way back. Mods: Turbo Inlet, Short Ram, IDRVSLO's L2AIC, TRZ RMM, Shifter Bushings, PG Mani, CS DP,HF Cat, DS Trans Mount, Stiffened Passenger MM, CDFP Internals, Saikou Michi OCC, DIY BS Delete, DIY Windage Tray. Falken 235/45 17 7.5 |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score ok dude..am i on crack or is there a thread about this shit that u posted on close by?? wtf man
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
(Thread Starter) | Not Ranked : 0 score Ya that was an old post the dude was asking about the mr gasket donut. I am not looking to reduce the coil compression like he was. I want stock height maintained.
Groans: 356
| Not Ranked : 0 score didnt u sell or werent u selling the car?
(Thread Starter) | Not Ranked : 0 score No I was wanting to sell my stock parts and a few other items. I know you are just being mesmerized by my zexy legs in the pics. I understand.
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
You are a huge motherfucker. Like squeezing a bison in a miata.
__________________ | |
![]() Join Date: Nov 2010 Location: Dallas. Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I've actually been looking for something similar to this for my Speed 6. I'm lowered on RPM Street springs and would like to raise the front about 1/4" to 3/8". The only thing I've found is the spring inserts that circle track users put in their springs to raise spring rate and ride height. I'd be interested to see what other people have to say about this. Here's what I'm talking about: Spring Rubbers : Coil Spring Rubbers : Coil-Over Spring Rubbers |
![]() Join Date: Nov 2008 Location: Irving, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,506
| Not Ranked : 0 score wheelman, check out DFW Mazdas Home and come out to our thursday night meets in addison.
__________________ 2008.5 Crystal White Pearl MS3 A lot of mods Check out my big turbo build! |
![]() Join Date: Jun 2008 Location: SF CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score maybe another solution but there was a post about adding air bags within the spring to add spring rate and stiffness. I cant seem to find a link can someone chime in on this. |
I had Airlift1000 (made by Airlift Air Lift - Home) in a minivan before. It works great. But I can't find one for the Mazdaspeed3. I guess you have to measure the ID of our rear spring and get one from Airlift that fits. | |
Uhhhhh Air Lift Kit 1000 | |
(Thread Starter) | Not Ranked : 0 score I was in a mood to comment in equally and opposite magnitude of stupidity that is all Tomas. The air bags were wow, but to much for me. Thanks for the replies. I will try and take the negative camber out first. But Mr Gasket looks the 1st option I try.
| How To: Ignition coil spring stretch mod | cld12pk2go | MazdaSpeed 3 - How-To's | 56 | 03-21-2016 02:58 AM |
| Possible track spring spring setup for use with Koni yellows | stretch | MazdaSpeed 3/6 - Suspension & Brakes | 154 | 04-18-2011 12:18 PM |
| Donut Style Coil Spring Spacer | booya620 | Drag Racing | 2 | 02-07-2011 08:00 PM |
| Another "read my plugs" and Coil Spring Mod | Frequentflyer | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 12-13-2008 11:16 PM |
