| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Nov 2016 Location: Kansas City, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
Groaned at 9 Times in 6 Posts
(Thread Starter) | Not Ranked : 0 score Please, not all at once... Sent from my XT1254 using Tapatalk |
| Not Ranked : 0 score Do you have a video of the noise? Could be the diff.
| The Following User Says Thank You to Djohns For This Useful Post: | mr_mazda329 (07-31-2017) |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
![]() Join Date: Feb 2017
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score What setting is your sway set to? I had a similar noise which ended up being the rear part of the sway bar hitting the spring bucket. Solution for me was to move the setting to the softer one (rear most hole) and raise the rear spring height adjuster a couple more threads. Not sure if you have the H&R coilovers set up or not. If not moving the sway bar setting might be all that's required. I have the Whiteline Rear Sway and Racing Beat Endlinks as well
__________________ 2007 MS6: H&R Coilovers, Whiteline RSB, Corksport Rear Diff and Engine Mount, SPC RCAs, SPC Ball Joints, Corksport Exhaust, Racing Beat Endlinks, Amsoil Fluids 2011 F150 FX4 EB: Fox Coilovers / Rears, Icon UCAs, RCI Full Skid Plates, Turbosmart Kompact BOVs, Alpine Restyle FD001 (Past) 2004 350Z: Turbonetics Single Turbo, NISMO Rear Diff, ACT Clutch, JWT Flywheel, Hotchkis RSB, Cusco UCA, HKS Coilovers, Apexi WS2 Exhaust, SPC RCA, Motordyne Plenum Spacer, |
Sent from my XT1254 using Tapatalk | |
| Not Ranked : 0 score Interesting, well, just to make sure it's still not hitting you might consider painting the cut off end and drive it for a day, see if the paint gets scraped off. I noticed that with mine at the stiffest setting the end links were at a very acute angle and might have been binding as well. Moving to the softer setting at least after a few "on ramp laps" seems to leave them a more normal/natural angle.
Sent from my XT1254 using Tapatalk Last edited by turbskies; 07-08-2017 at 01:30 PM. Reason: MSF Database - Automerged Doublepost | ||
(Thread Starter) | Not Ranked : 0 score Think I found the problem,looked under the car and the rear lateral links bushings look torn to shit. Ordered replacement ones off Rock Auto. I'll update when I get them installed and get an alignment done. Sent from my XT1254 using Tapatalk |
| The Following User Says Thank You to turbskies For This Useful Post: | Shwaykid (07-14-2017) |
![]() Join Date: Apr 2016 Location: Long Island
Rep Power: 0 ![]() ![]() ![]() Thanks: 138
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Have you checked the rear trailing arm bushings? That's what it was for me with my MS3 Sent from my SM-G900T3 using Tapatalk |
Do you have to get an alignment after doing the trailing arm? Sent from my XT1254 using Tapatalk | |
![]() Join Date: Jan 2018 Location: NYC
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Sorry to bring up old post but did you ever find it? im having the same issue rn. |
| The Following User Says Thank You to turbskies For This Useful Post: | MSMS3 (12-16-2019) |
| Weird metal creaking noise in the rear when getting off the brake | Speed3Pedro | MazdaSpeed 3/6 - Suspension & Brakes | 2 | 11-03-2016 10:42 AM |
| Creaking noise from rear when parked in e-brake? | furinax | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 07-11-2016 11:06 AM |
| Creaking noise from kw's | I_AINT_RICE | MazdaSpeed 3/6 - Suspension & Brakes | 5 | 10-24-2014 12:03 AM |
| Creaking noise coming from the right-rear of back window | Flaverre | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 10-20-2013 05:57 PM |
| Creaking Noise | boost2dms6 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 10-27-2011 08:49 AM |
