Like Tree104Likes
 Old 08-31-2019, 08:33 PM   #161
ProChargedLS2's Avatar
Posts: 129   (View Stats)
ProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the rough
Groaned at 5 Times in 2 Posts
Updates on credible sources of information and specifications for the bracket to get them to fit?
Upon this rock I will build my church
BNR S4 V3, JMF Intake Manifold, XSP Exhaust Manifold V3, ATP Catless DP, SU TMIC, JBR Tru- 3.5 intake, DM Stage 3 DOCC via route 4, JBR Intake Manifold + Throttle Body Insulating Gaskets, CS EBCS, CS High Pressure Fuel Line, CS HPFP Internals, CS Injector Seals, JBR BSD + Baffle Kit, CS RMM, CS SSB, JBR SSP, Forge BPV, 3 BAR MAP Sensor (for now), DM EGR Delete, NGK 6510 Plugs, DM PCV Plate
TUNEDBYNISHAN!!
ProChargedLS2 is offline   Reply With Quote
 Old 08-31-2019, 08:52 PM   #162
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
not possible or worth it according to matt at damond ms
 Old 08-31-2019, 09:59 PM   #163
Damn. I know they make Brembo and Wilwood kits which are nice, but considering these are only 300 on eBay... Oh well. Maybe one day somebody with CAD knowledge with bestow us with a map and data sheet we can give to a machine shop and make it for us! Lmao...
TUNEDBYNISHAN!!
 Old 10-01-2019, 03:19 PM   #164
350phi's Avatar
Posts: 1   (View Stats)
350phi is an unknown quantity at this point
Maybe I can help. This is what I'm gathering.
2004-2007 Cadillac CTS-V 4 piston calipers
324mm (12.75") 350z track rotor
rotor isn't much of an upgrade like someone mentioned but moving to a 4pot light caliper would be.
mazda hub centric is: 67.1 (Centric rotor says it's 72mm. can someone confirm to be the exact hub centric the front spindle has? maybe the rotors are 72mm but the hub is 67.1)
bolt pathern 5x114.3
rotor thickness is 25mm.
rotor out dia is 319.7mm
anyone know if the non speed 3/6 has the same front knuckle as the mazdaspeed? looking through ebay, they look similar. If I were to make the bracket, I want it to have a larger market than just one car. many times, car makers use the same suspension components between models.
also, what common wheel size do people mostly run? 17"??
tons of mazda 3/6 at my local junk yard. I can pull a knuckle. Not sure if they're different than the speed version. calipers are cheap. around 100 bucks. rotors are cheap.
CTSV stock rotor:
dia: 355mm 13.98"
thickness: 32mm
370z Nismo stock rotor:
dia: 355mm
thickness 33mm
center bore 68mm
my best bet is to use the nismo 355" rotor instead of the 350z track version. This will be closer to stock size for the pad. but you must run 18" wheels.
anyone in so cal, LA/OC area that is willing to help with this project? Maybe already have the calipers in hand?
btw, i do not not own this car. I've made caliper brackets just by having knuckles, rotors and calipers.
Is there at least more than 10 people interested in this? making cnc bracket is dumb expansive..
350phi.com is my site, I make brake bracket for lexus/toyota.
edit: why ctsv brembo when you can already put brembo on your car?? EVO Brembos on a MS6
eroler1 likes this.
350phi is offline   Reply With Quote
Miata v8 swap vs rx7 v8 swap blake0521 Miata - General Questions 13 01-21-2015 07:05 PM
GREEK MAZDA 3 MPS XYZ 6-POT BRAKE KIT SERVICE - NEW BRAKE PADS FERODO DS 2500 & NEW CASTROL REACT SRF RACING BRAKE FLUID dgiannitakis MazdaSpeed 3/6 - Suspension & Brakes 5 05-05-2014 01:30 PM
New big brake possibilities? We share front brake calipers with audis/vws breakfasteatre MazdaSpeed 3/6 - Suspension & Brakes 15 11-03-2012 09:18 PM
Hawk HPS brake pads & Goodridge brake lines in stock for the 07-11 MS3. Chris@Xtreme Mazdaspeed3/6 General Discussion 3 08-06-2011 08:56 PM
Hawk Pads, Racing Brake Lines, and ATE Brake Fluid! Race Roots Mazdaspeed3/6 General Discussion 11 09-25-2009 02:04 PM
Page generated in 0.26117 seconds with 23 queries
