Like Tree31Likes
 Old 07-25-2010, 01:34 AM   #1
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
Post EVO Brembos on a MS6
Going from this:
To this:
Even before I bought my MS6, I was kinda distraught that Mazda was not going to be using 4 piston front calipers on the MS6. Evos, STis, even the Volvo S60Rs all had Brembo brakes from the factory. It seems that the factory Ford brakes for the MS6 were a bit of an afterthought. Don't get me wrong, the stock MS6 are fantastic, though for track duty, I want something more that isn't going to break the bank. I'm just picking up, where Mazda left off.
As a few of you may know, I'm working on a DIY BBK using Mitsubishi Evolution Brembo 4 piston front calipers. After lots of research and a bit of measuring, I purchased some Evo 7 Brembo calipers, in hopes for a near "bolt-on" BBK. I received the calipers in the post the other day, after picking them up off eBay. This evening I did a test fit, to get some measurements for rotors, and to see if I'd run into any issues. Everything went quite well, and I now have a good baseline of what I still need to work on.
First off, there are quite a few similarities between the Evo 6-9 and the MS6 in the brake department. Both use a 12.6" diameter rotor, both have the same wheel bolt pattern, both have the front calipers mounted towards the front of the vehicle, and both have the caliper mount holes on the spindle at a similar distance near 160mm. However, there are also quite a few differences.
The first issue I ran into, is that the caliper is not a direct bolt on. The MS6's caliper mount holes are around 157mm, vs the Evo's at 160mm. That is very close though, and it shouldn't be to difficult to make the Brembo's fit. Here's a pic, showing how the holes don't line up perfectly:
The next issue is that I'm going to have to run some pretty thick wheel spacers. That's not really a concern though, since it was only a matter of time before I bought some, I just have a reason to now.
I have a few other things I have to work on. Finding rotors that will fit perfectly. It is not too difficult, I've got most of my measurements taken, and I'm thinking 2-piece may be the best solution. Also I may have to get some custom brake lines made, which shouldn't be too hard to get done. I haven't tried yet to see if the MS6 lines work, I've got my stock lines laying around, so I'll give that a try soon.
I've still got a lot of work to do, and plenty of testing before I make a "How-to" for this and go over the full details. I'm not trying to do a DIY BBK for looks, I want this for performance. I've seen some pretty bad hacked-up DIY BBKs, and I hoping to learn from their mistakes, and not replicate them.
I do have to thank the Mazda engineers for the close to 160mm mount span, and plenty of suspension, driveline, and dust shield clearance. I know they had big brakes in-mind, when they designed this car.
Enough of me rambling, here's some more pics:
My goal is a well preforming BBK, for under $1,000. If I do not succeeded... Hello StopTech!
Sinerspeed likes this.
Current Fail:
The Following 35 Users Say Thank You to MATT DAMOND For This Useful Post:
802MS3 (07-25-2010), :: Gusto :: (10-11-2012), adlpb (09-27-2012), ak_spray (05-21-2012), dan7225 (07-25-2010), danesti (07-28-2010), darkcherry (05-12-2012), deniskapliy (09-15-2019), djuosnteisn (01-06-2011), doubleflusher (07-26-2010), Downmented (05-16-2012), dsb_chicago (11-05-2013), Fail_6 (11-06-2012), I Love Brownies (07-28-2010), J-Liss (05-15-2012), jax ms3gt (07-29-2010), josurr (05-17-2012), kore2000 (07-28-2010), labikesrcool (07-29-2010), Lex (07-25-2010), MAZ (12-26-2012), mdd5148 (07-25-2010), Micha (10-25-2014), Night Wolf (11-11-2010), nybe0010 (05-15-2013), RayRayBauder (07-28-2010), redboat (02-01-2013), Sinerspeed (04-01-2014), SLOWHATCH (05-12-2012), Speed3eak (12-17-2010), Tomas (12-27-2012), TopazM3 (07-28-2010), TurboDreams (07-29-2010), WA_MS6 (04-04-2015), xcoldricex (07-25-2010)
 Old 07-25-2010, 10:10 AM   #2
KoukiS14's Avatar
Posts: 146   (View Stats)
KoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond repute
You might consider a custom bracket and a set of easily sourced aftermarket calipers like Wilwoods. I've got nice Wilwood Forged Superlite 4 calipers on 350Z track (Brembo) rotors for my 240SX. The calipers are a little over $300 per pair, and the pad selection is great and inexpensive.
KoukiS14 is offline   Reply With Quote
 Old 07-25-2010, 10:16 AM   #3
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
Man. I didn't think the MS6 calipers were that tiny. The MS3 calipers are pretty beefy compared to those.
Good luck with the install. Evo brakes work very well.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
 Old 07-25-2010, 11:00 AM   #4
mdd5148's Avatar
Posts: 303   (View Stats)
mdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the world
Glad to see someone is doing this finally. Good to know the mount measurements... I was thinking of picking up a single cts-v caliper to see how far off it is from fitting but those are 130mm so that would require some bracket.
Also will you be fitting the rear brembos?
2005 Porsche 911 - Pure Sex
Staggered 19" HRE P47's
2007 Mazdaspeed6 GT - #10318 - Sold
AWR Passenger Side Mount | AWR Transmission Mount | CPE RMM | CPE Intake | CPE Inlet | CPE Downpipe | CPE Catback | CPE Fuel Pump | CPE Manifold | TIAL 44mm Wastegate | Grimmspeed EBCS | Custom FMIC | HKS BOV | GT3076 | Cobb AP | Labonte Stage 2 meth | TWM Stage 2 Short Shifter | VEI boost gauge | CPE Tow Plate | LED Tail Lights | LED Mirrors | CX7 Antenna | 18x8.5 Rays Gram Light 57F
2006 Miata Sport - She took it...
Stock For Now...
mdd5148 is offline   Reply With Quote
 Old 07-25-2010, 11:35 AM   #5
Groans: 70
I was originally going to use Wilwood calipers, but I'm not too big a fan of their caliper design. I'm trying not to have to design a bracket. If I were to, I would just buy radial mount calipers, and design and make the brackets. Plus I have even more pad options with the Brembos. I'm most likely going to use Wilwood 2-piece rotors though.
Your calipers are close to the size of the Brembos, which is good for heat dissipation on the track. I was thinking of just bolting up MS3 calipers, but unfortunately they won't work.
Wanna go for a ride when I'm done? lol
I'm not going to be fitting Brembos in the rear, since I want to retain the factory e-brake. However, I'm looking into upgrading the rears as well. I just want a vented rotor back there, and have the e-brake still incorporated in the caliper. Right now, I'm doing some research, and I'm going to get some measurements of the RX8 rear calipers. I'll most likely have to go 2-piece rotors in the rear as well, since it's slim pickins for large thin vented rotors.
If I need to, I'm also going to upgrade the master cylinder and proportioning valve.
Current Fail:
The Following User Says Thank You to MATT DAMOND For This Useful Post:
 Old 07-25-2010, 02:38 PM   #6
You mentioned Volvo. Any change the S60R calipers bolt on?
Any spacing issues between there the caliper sits and how it fits over the disc?
 Old 07-26-2010, 06:18 AM   #7
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
Very interesting stuff. Sub
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline   Reply With Quote
 Old 07-26-2010, 09:19 AM   #8
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Here are the Centric replacement caliper parts for the 2005 S60R
Front Left:
ELECTRONIC CATALOG - MULTIMEDIA FORM
Rear Left:
The Following 2 Users Say Thank You to triplejumper18 For This Useful Post:
mdd5148 (07-26-2010), Speed3eak (12-17-2010)
 Old 07-27-2010, 09:41 PM   #9
The Angry Goose
Hectik1's Avatar
Hell yeah I want to go for a ride!
Hector
2014 Mazda 3
1979 Mazda Rx7
 Old 07-28-2010, 06:24 AM   #10
volodya84's Avatar
Posts: 1,552   (View Stats)
volodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the world
Groans: 42
keep us updated please. If you work something out, let me know.
Corksport TMIC // Denso ITV22s .028" // COBB SRI // Corksport TIP // Forge V1 BPV // COBB AP // JBR SSP // TWM Bushings // Prosport Boost Gauge // CS Interior LED kit
"ban post whoring brownies"
Forge v1
volodya84 is offline   Reply With Quote
 Old 07-28-2010, 12:57 PM   #11
MSP611's Avatar
Posts: 2,291   (View Stats)
very interesting... super interested in doing this if it comes out well
In progress:
 Old 07-28-2010, 01:01 PM   #12
dave_PEI's Avatar
Posts: 8   (View Stats)
dave_PEI will become famous soon enough
very interesting! i didnt realize our brakes were that small either! i'll be keeping an eye on this too
dave_PEI is offline   Reply With Quote
 Old 07-28-2010, 02:30 PM   #13
Markspd6's Avatar
Posts: 137   (View Stats)
Markspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to beholdMarkspd6 is a splendid one to behold
I dont think our brakes are that small.. thats just the 2 tone paint job it makes them look smaller.. but, yeah for the price of this car upgraded brakes should have been here to start.. im more curious about the volvo fitment? those look they might make it on? maybe?
Markspd6 is offline   Reply With Quote
 Old 07-28-2010, 04:43 PM   #14
AmillieMS6's Avatar
Posts: 1,700   (View Stats)
AmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the world
Groans: 365
Groaned at 594 Times in 575 Posts
damn you werent kidding? im surprised you actually went along with this
Mazdaspeed
AmillieMS6 is offline   Reply With Quote
 Old 07-28-2010, 08:57 PM   #15
Groans: 70
As far as the Volvo calipers go, I'm going to email a company who made a bracket for them to fit an older Volvo model, and see if they'll let me know the spacing. They do "look" identical to the Evo mount spacing, but IDK. I'll also look into the the spacing of the holes for the rear calipers, since they might be a closer fit for the MS3.
I was originally going to use the Volvo calipers, since I can get both fronts for under $500 new.
I'm going to have to use probably a 2-piece rotor because how the rotor meets with the calipers. I cannot use MS6 discs, since they are too thin. I cannot use Evo or STi discs, since their diameters are a few mm too small, I'd have to get the center hub hole drilled out too, but that wouldn't be too big of an issue. I'm still researching to find a cheaper non 2-piece solution. Ferrari 360 Modena discs have close to perfect dimensions for what I need, but I'll have to get the wheel stud holes drilled out, since Ferrari's bolt pattern in 108mm.
I'm always serious. Except when I talk to you. lulz
Current Fail:
 Old 07-28-2010, 09:16 PM   #16
MSP611's Avatar
damn puttin some thought into this. ferrari 360 rotors dont u think those woudl cost some extra big greenbacks?
In progress:
 Old 07-28-2010, 11:30 PM   #17
Groans: 70
Yeah the Ferrari rotors may be out of the question, since they are impossible to find, and when I do, they're expensive.
I did however find some rotors that match my specs very well, they're almost identical for what I need. Unfortunately, they're a bit tricky to find, since they're off an Alfa Romeo, but they're cheaper than MS6 rotors.
I'm going to double check my specs I've gathered, re-mount up the caliper and re-measure again, before I start buying more shit.
Current Fail:
Alpha (07-29-2010)
 Old 07-29-2010, 01:42 PM   #18
MSP611's Avatar
good idea like pops always says measure twice cut once... lol keep us updated
In progress:
 Old 07-29-2010, 02:56 PM   #19
The Volvo ones may be of extra interest since if they bolt onto the ears, they may allow you to use a Volvo disc to match.
 Old 11-03-2010, 07:22 AM   #20
Dark's Avatar
Posts: 130   (View Stats)
Dark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the world
Updates?
Ryan | 06 ZX10r | 08.5 Speed3 GT
Dark is offline   Reply With Quote
 Old 11-09-2010, 02:13 PM   #21
meh, no ideas
Jedyboyrokr's Avatar
Posts: 528   (View Stats)
Jedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the world
updates?
89 toyota supra 1JZ Twin Turbo---Sold
2006 MS6 GT few mods ---Sold
Monaco White '13 Genesis 2.0T R-Spec-- ISIS downpipe/testpipe, Agency Power CBE, Injen SRI, Forge BOV, JBR Heavy Shift knob should be 240ish wheel right now, tune coming April 27th
Jedyboyrokr is offline   Reply With Quote
 Old 11-10-2010, 09:19 PM   #22
Nataphen's Avatar
Groans: 31
No updates, guys. Haven't you heard? Matt's making '99 Toyota Camry OCC and brake kits now.
The Following 2 Users Say Thank You to Nataphen For This Useful Post:
i8urgti (11-23-2010), MATT DAMOND (11-11-2010)
 Old 11-11-2010, 02:06 AM   #23
MSP611's Avatar
WTF y? Does camry have mean breaks?
In progress:
 Old 11-11-2010, 10:27 PM   #24
Groans: 70
No updates, I'm selling the MS6 soon, and I've pretty much stopped work on this project. If anyone wants the calipers send me a PM.
lmao, I was actually thinking of upgrading the brakes on the camry, since there are a lot of direct bolt-on options. But... my goal is to keep that car alive, for as little money as possible.
Current Fail:
Nataphen (11-12-2010)
 Old 11-12-2010, 03:09 PM   #25
bbjoy's Avatar
Posts: 113   (View Stats)
bbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to beholdbbjoy is a splendid one to behold
Groaned at 5 Times in 2 Posts
nicce
bbjoy is offline   Reply With Quote
 Old 11-12-2010, 03:48 PM   #26
Matx's Avatar
Posts: 1,681   (View Stats)
Matx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the world
really WTF... why you selling it? just delete this whole thing!!!!!!!!
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
Originally Posted by backward_0 View Post
.... I will be more than happy to fuck your world off....
Matx is offline   Reply With Quote
 Old 11-12-2010, 04:50 PM   #27
06speedemon's Avatar
Posts: 1,521   (View Stats)
06speedemon is the leader of the world06speedemon is the leader of the world06speedemon is the leader of the world06speedemon is the leader of the world06speedemon is the leader of the world06speedemon is the leader of the world06speedemon is the leader of the world06speedemon is the leader of the world06speedemon is the leader of the world06speedemon is the leader of the world06speedemon is the leader of the world
Groaned at 26 Times in 10 Posts
Would have been sweet if you got it to work Matt.
06speedemon is offline   Reply With Quote
The Following User Says Thank You to 06speedemon For This Useful Post:
MATT DAMOND (11-13-2010)
 Old 11-12-2010, 10:06 PM   #28
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
I would like to continue this project but transfer it to an MS3 if at all possible
Questions:
1. What is the hole mount distance on an MS3 if anyone knows?
2. Is the offset of the brake discs on the MS6 the same as the MS3? Are the MS6 discs only larger in diameter? If disc thickness is 28 or 32mm should be OK either way I think.
3. What is the distance from the outer surface of the brake disc to the outer surface of the caliper? I am assuming clearance to the inside of the car is OK since the MS3 calipers are fat as hell and go about 2-3" to the inside. I would also assume the length of the calipers will clear 18" wheels since you probably tried it?
4. How much for the calipers shipped to Florida?
 Old 11-13-2010, 07:57 AM   #29
foney_email's Avatar
Posts: 62   (View Stats)
foney_email is a jewel in the roughfoney_email is a jewel in the roughfoney_email is a jewel in the roughfoney_email is a jewel in the rough
What a disappointment. I was really hoping this project would see a finale. Oh well. Who will make the easy big brake upgrade alternative now. (cheap too)
foney_email is offline   Reply With Quote
 Old 11-13-2010, 09:10 PM   #30
Groans: 70
Oaky, since everyone is bitching that I never got around to finishing this, here's some info in hopes that someone else will.
The MS6 stock brake lines will work perfectly. The connections are the same size between the stock and brembo calipers. Here's a pic, I'm sure the orientation of the line will be slightly different if the caliper were mounted:
The rotors I was planning on using were newer Alfa Romeo 159 rotors, where brembo calipers were used. The measurements I took were almost exact to these rotor specs. The only issue, is that the bolt pattern for Alfa Romeo's is 5 X 110, so new holes would have to be machined to Mazda's 5 X 114.5. Also the center hole might be 1mm too small, but that's not a big deal.
Now someone else go try this.
Questions:
1. MS3 caliper bolt span is something like 140mm, you'd need to make a bracket for these calipers to work.
2. I wouldn't be using MS6 discs, since they are too thin, MS3 discs are almost identical, apart from being like 1mm taller IIRC. You have to use a custom disc, or one off another car.
3. it's probably around 2-3", but I'd still have to
4. I kinda want to keep them, for a future project, since the calipers have little miles on them(the paint is shit though). But, I'd prob take like $300 shipped for them.
Current Fail:
The Following 2 Users Say Thank You to MATT DAMOND For This Useful Post:
Nataphen (11-14-2010), Tomas (11-15-2010)
 Old 11-15-2010, 11:20 AM   #31
Bob Ross Fanclub
Tomas's Avatar
ok, thanks.
Since the bolt span is not even close I think trying this on an MS3 is too much hassle.
 Old 11-16-2010, 07:57 PM   #32
Burn69's Avatar
Posts: 143   (View Stats)
Burn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to behold
Groaned at 7 Times in 4 Posts
Dayum that sux.
2012 Speed3 w/ Tech. / SURE Full3 Aeros & TIP Combo / SURE Shortcut w/ Counterweight / SURE TorqR3 RMM / SURE AGS Shift Knob / COBB AP Programmer / CNT CBE Blue Tip / UR Test Pipe / RallyArmor Flaps / SPC Rear Camber Arms / MORE (coming soon).....
Burn69 is offline   Reply With Quote
 Old 12-11-2010, 08:25 PM   #33
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
ohhh nice...
finish it.. so i can copy u.. hahah
yea yea - i know i cant spell
 Old 12-14-2010, 04:23 PM   #34
speed666's Avatar
Posts: 21   (View Stats)
speed666 will become famous soon enough
fit for oem wheels? more picture
speed666 is offline   Reply With Quote
 Old 12-17-2010, 06:56 PM   #35
Markspd6's Avatar
bummer so much hope..
 Old 01-01-2011, 11:44 PM   #36
jdcms6's Avatar
Posts: 234   (View Stats)
jdcms6 is the leader of the worldjdcms6 is the leader of the worldjdcms6 is the leader of the worldjdcms6 is the leader of the worldjdcms6 is the leader of the worldjdcms6 is the leader of the worldjdcms6 is the leader of the worldjdcms6 is the leader of the worldjdcms6 is the leader of the worldjdcms6 is the leader of the worldjdcms6 is the leader of the world
TEASED!!! lol just kidding... that was a good idea project you started. My brother has an evo x and I've been thinking since I bought my ms6 about the brembos
jdcms6 is offline   Reply With Quote
 Old 01-06-2011, 08:59 AM   #37
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
here are mine
355mm slotted discs with lightweight central part, 4-piston JBT calipers
working perfectly for two years already
paveltol is offline   Reply With Quote
The Following 6 Users Say Thank You to paveltol For This Useful Post:
jdcms6 (01-06-2011), jmhinkle (03-15-2014), redboat (02-01-2013), Tomas (12-27-2012), TopazM3 (01-06-2011), WA_MS6 (04-04-2015)
 Old 01-06-2011, 09:05 AM   #38
Alpha's Avatar
Posts: 3,711   (View Stats)
Originally Posted by paveltol View Post
here are mine
Nice! What brand and how much did they run you?
 Old 01-07-2011, 07:41 AM   #39
paveltol's Avatar
These are the JBT brake kit. JBT BRAKE SYSTEM There are two options for MS6 front axte: 4 and 6-piston calipers(6 pistons shown below). 4 piston calipers come with 355mm rotors and 6 piston calipers usually come with 380mm rotors. As for me, I'd recommend you installing the 4 piston calipers not only because they are cheaper and fit the OEM wheels(the 5-6mm wheel spacer required), but because the 6 piston calipers tend to overheat and deform the rotors if you drive fast. 355mm + 4 piston version is better cooled, yet when the outside temp is about 77+F, you need additional air supply to cool the brakes in order to have good decelerations without damaging the system.
I've driven more than 20k miles on 4 piston JBTs and still like them.
The prices for them here in Russia are 2000$ for the 4 piston version. That hurts( Yet, the Brembos cost even more here.
F%cking Moscow city(
The Following User Says Thank You to paveltol For This Useful Post:
abespeed6 (12-17-2019)
 Old 01-07-2011, 08:33 AM   #40
Alpha's Avatar
Wow! Great info, thanks! Pricey, bit the do look awesome!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/evo-brembos-mazdaspeed-6-a-62296/
MAZDA 6 FORUM ? Upgrade hamulców na grubo - temat pitolniczy ? Strona 3 ? Hamulce GH This thread Refback 11-15-2014 01:20 PM
I bought a Silver 6MPS This thread Refback 09-24-2014 05:08 PM
MAZDA 6 FORUM ? Upgrade hamulców na grubo - temat pitolniczy ? Strona 3 ? Hamulce GH This thread Refback 09-14-2014 11:26 AM
MAZDA 6 FORUM ? Upgrade hamulców na grubo - temat pitolniczy ? Strona 3 ? Hamulce This thread Refback 07-18-2014 01:48 AM
??? brembo This thread Refback 05-15-2014 07:28 AM
Upgrade to factory Brembo brakes - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 01-23-2014 09:15 PM
Aaron's bright red land barge This thread Refback 11-06-2013 04:14 AM
DIY big brake upgrade? This thread Refback 05-03-2013 12:15 PM
Bolt-on Caliper Conversions (Multi-Piston) - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-18-2013 09:34 AM
I bought a Silver 6MPS ? Mazda MPS Owners Club This thread Refback 01-29-2013 02:08 AM
jeffjassky comments on Ladies of reddit - what air freshener scents should guys have? This thread Refback 01-22-2013 12:46 AM
HOW TO: Evo Brembos on a Mazda MPS 6 - Page 2 This thread Pingback 05-13-2012 07:16 PM
Evo 8 MR brakes on a MPS 6 This thread Pingback 03-21-2011 08:09 PM
Glue-on Brembos: Your AMG Sentra wants an upgrade Haltech Automotive News 8 07-04-2009 04:52 PM
Spy Shots: Chevy Camaro arrives at Nürburgring wearing Brembos Haltech Automotive News 1 04-07-2008 12:21 PM
Page generated in 0.61105 seconds with 45 queries
