| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Jan 2019
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I recently replaced the front struts on my 07 MS3 120k with FSDs. Despite my quick look at the ball joints while I did the replacement, a reputable shop told me I need to have both ball joints replaced before they align the front end. So I will be replacing both front lower control arms. Since I will be doing this and dont want to mess with the front end for a while, what else should I replace while I am in there? I was looking at just buying this Moog kit: https://www.rockauto.com/en/moreinfo...=1434570&jsn=8 It includes both inner and outer tie rods. Is there anything else that I should look at replacing while Im doing this job? Thank you! |
![]() Join Date: May 2019 Location: Tampa, FL
| Not Ranked : 0 score If your front end isn't clunking you might not need it but I would look into replacing your sway bar end links and sway bar bushings while you are there. That would pretty much refresh your entire front end. |
![]() Join Date: Dec 2017 Location: Chico CA for school. Originally From the Bay Area
Rep Power: 27 ![]() Thanks: 17
| Not Ranked : 0 score If you end up doing your front endlinks, you CAN do Moog just to keep it all on one platform, but the moog's grease fittings bump into the inner tire well. New Redesigned Moog front endlinks (K750073) Here's a little thread about swapping the fittings. Figures the images are gone, but I think you can get the gist of it from the fuzzy pictures and the text
__________________ 2009 CWP GT MS3 Damond Motorsports RMM PMM and TMM Autotech HPFP Cobb SF Intake Cobb AP Autotech HPFP Corksport RSB+FSB Corksport Adjustable Short Throw Corksport Metal Skid Plate Koni FSD |
(Thread Starter) | Not Ranked : 0 score Thank you for the info! I had not heard of this issue before |
| Not Ranked : 0 score I'm not 100% sure if this is still an issue with the moogs. I was just putting it on your radar.
| 2019 Audi A4 will get a mild refresh up front | Haltech | Automotive News | 0 | 05-24-2018 10:20 AM |
| Removing rear/front subframe to refresh everything | stockms3 | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 04-18-2016 09:47 PM |
| Suspension Refresh @ 85K | Murcielago311 | MazdaSpeed 3/6 - Suspension & Brakes | 47 | 08-27-2015 02:27 PM |
| front suspension noise? | schiccc | MazdaSpeed 3/6 - Suspension & Brakes | 9 | 04-15-2010 02:19 PM |
