 Old 05-21-2008, 06:57 PM   #1
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
Default going to the dealer Tuesday
wondering if anyone encountered this problem. From a stop eihter in reverse or 1st gear very lightly accelerate (maybe 2 full tire rotations maybe even less) and a slight clunk from the left front. Brakes are not engaged so its either axle to hub related or a suspension piece, either way it takes the shift in direction of weight transfer to re-create the sound. I am all ears for any opinions, my car has 30k miles and at 36k the basic warranty goes bye bye. (tuesday I am taking it in)
The Following 2 Users Say Thank You to rodrigo For This Useful Post:
aaronc7 (07-15-2009), corbs (07-15-2009)
 Old 05-23-2008, 11:01 AM   #2
creature75's Avatar
Posts: 17   (View Stats)
creature75 is an unknown quantity at this point
+1. i was never able to figure out what that sound was. I even went out with a tech from Galpin and i could not reproduce the sound for him. mine started at 1000k it comes and goes. i now have 20000k and it occasionally does it.
please keep us posted on what the dealer tells you.
by the way, i am completely stock. if the info helps.
creature75 is offline   Reply With Quote
 Old 05-23-2008, 09:12 PM   #3
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
well, the best way to re-create it is by shifting the weight transfer (going back and forth)which leads me to believe it has to be suspension related since its what "rests" under load. The tech said it even sounded like axle noise but again if it only does it once it cant be on something that is constantly rotating. It has been suggested to me by someone that a lose nut in the front sway bar is the culprit, but the Service manger said"these cars dont have front sway bars" . I wonder what the guys that have bought the front and rear Cobb sway bars are doing with the front ones.....using is as a tire iron maybe?..........and we are supposed to respect the techs at dealerships?
 Old 05-23-2008, 09:13 PM   #4
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
I will keep you posted, anyone else experience this. And by the way what does +1 mean when you guys put it up?
 Old 05-23-2008, 10:04 PM   #5
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
+1 means "i agree"
I have the same deal, I notice mine when the car has been sitting overnight or for long enough to really cool down, then I put it in reverse and right when it starts to move i hear a little clunk.
Once its warmed up I don't hear the noise at all.
I think its coming from the transmission, maybe the locking of the differential or something.
I'm not too worried about it, my last car made all sorts of crazy noises, thats just how it was.
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
 Old 05-25-2008, 03:23 PM   #6
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
if its under warranty you should worry about it because it will be a free fix. I checked today(saturday) and they havent even touched my car (originally I had an appointment for next tuesday but I didnt want to drive it anymore so i took it in thursday). I got my AP at home (came in later that day) ........the way things are going I am gonna take my mods in the trunk of the rental when its time to pick it up, including the AP. They gave me a 2.0 mazda3 slug. (makes me appreciate my car though)...ill post what they find.....and I also mentioned the fact that this car at 60-65mph in 6th gear with slight load sometimes cuts the engine power and does a horrible rattling noise (kinda like an F1 car hitting the speed limiter in the pits)
 Old 05-27-2008, 12:19 PM   #7
NEC
btw, you should DEFINATELY have this checked out, tell them to inspect the drivers side transmission mount.
Why? Because my engine fell out last night. I was hearing the noise you described intermittently, then on my way back from the beach I was hearing it more often, low and behold it was just a matter of time before catastrophe.
You're 100% right, I should have had them look at it, but I couldn't duplicate it until about an hour before the engine fell out it was doing it a whole bunch.
 Old 05-27-2008, 02:48 PM   #8
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
WOW!.....
 Old 05-27-2008, 02:53 PM   #9
NEC
Yeah. Sucks b/c when I bought the car I explicitly asked if they had performed the recall... they said they did. So one of two things happened, either they performed the recall and the thing still failed, or they didn't perform the recall work.
I'm kind of hoping they never performed the recall work cause if they did and I still managed to rip the engine loose that scares the hell out of me.
 Old 05-28-2008, 02:23 PM   #10
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
I got it back, #4 mount bolt was loose, didnt get a chance to test out the car that much but so far no more noise. I will test it out tonight see if that did it for me. Mount bolts getting loose, thats scary
 Old 05-28-2008, 10:55 PM   #11
NEC
yeah.... as soon as that noise shows up, time to test the bolt. What happened with mine wasn't that the mount broke, but the bolt broke loose / backed out.
 Old 05-29-2008, 03:05 PM   #12
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
car doesnt make noise anymore, as far as that , its fixed
 Old 05-30-2008, 05:30 PM   #13
creature75's Avatar
sorry to hear about your engine falling out!!!!!
i was begining to wonder if its a motor mount issue. i see after reading that it just might be. looks like i need to make an appointment at the Stealership soon.
 Old 05-30-2008, 10:14 PM   #14
desertrat's Avatar
Posts: 132   (View Stats)
desertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant future
I'm hearing a klunk as well but it happens when there is alot of travel in the suspension on the front left\drivers side. i.e when I go over speed bumps\humps and up and down driveways. I checked the #4 mount and is torqued right. I'm taking it to the dealer next fri. Any suggestions?
desertrat is offline   Reply With Quote
 Old 05-31-2008, 12:27 AM   #15
NEC
The #4 mount may be torqued correctly but the threads could have begun to strip maybe? Causing movement? If its not the #4 mount I would check the endlinks, they've been known to have the nuts come off. Happened to me with the stock endlinks.
You might want to try and get a friend to stand by the car and see if you can figure out if its coming from more under the hood, or farther back, closer to the wheels.
Or if its easily reproducible, I'd say just take it to the dealer and let them worry about it.
 Old 06-02-2008, 08:36 PM   #16
NEC
OK so the clunk is back. This sucks. When can I get some upgraded side engine mounts?
Markup Much? Dealer demands $155k for Shelby GT500KR Haltech Automotive News 0 05-19-2008 09:50 AM
Markup Much? Dealer demands $155k for Shelby GT500KR Haltech Automotive News 1 05-19-2008 09:08 AM
Tuner Tuesday: Steinmetz tweaks the Opel Corsa OPC Haltech Automotive News 0 04-29-2008 05:30 PM
Trouble at the top? Toyota vehicles sitting longer on dealer lots Haltech Automotive News 0 04-28-2008 01:30 PM
Scion xB spontaneously combusts during dealer service Haltech Automotive News 1 04-08-2008 08:51 AM
Page generated in 0.34676 seconds with 23 queries
