 Old 04-25-2010, 05:19 AM   #1
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Default How do you get the front endlink off?
Hey all, trying to replace my passenger front strut and had it all apart except the damn top nut that is connected to the strut.... I tried to locate it in the forums BUT to no avail.
The nut I am talking about has a hex area in the center of it.
I know they suck but is all I can afford until the CO's
Any help or insight is appreciated. Thanks guys.
 Old 04-25-2010, 09:11 AM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
huh?
endlink nuts are 14mm if i recall correctly.
pzr2874 (04-25-2010)
 Old 04-25-2010, 09:21 AM   #3
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
are you talking about the nut on top of the strut? you need a 6mm hex and 17mm wrench if that's case. i had a hell of a time removing that nut. went through 2 hex keys and eventually purchased a metric hex socket set ($13). deep offset box wrenches also come in handy for the nut, especially if you're going to konis.
The Following User Says Thank You to karl-hungus For This Useful Post:
 Old 04-25-2010, 10:56 AM   #4
pzr2874's Avatar
Groans: 146
Ok, so I need to hold the hex and turn with an open ended wrench ?
Kinda figured that, but wondered if there was a "trick".... thanks for the replies.
 Old 04-25-2010, 12:08 PM   #5
P5_2_MS3's Avatar
Posts: 111   (View Stats)
P5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant futureP5_2_MS3 has a brilliant future
There's no trick. Spray some pb plaster and let it sit for a bit, then a wrench or crow's foot for the nut and and allen key for the bolt. Don't turn the allen key, just hold it in place. I made that mistake once and stripped the inside of the bolt.
P5_2_MS3 is offline   Reply With Quote
The Following User Says Thank You to P5_2_MS3 For This Useful Post:
pzr2874 (04-30-2010)
 Old 04-30-2010, 05:02 AM   #6
pzr2874's Avatar
Groans: 146
Worked like a charm....Thanks
Man, this stock setup is CRAP.
Help with endlink/RSB... Hank3 MazdaSpeed 3/6 - Suspension & Brakes 10 04-11-2010 09:53 PM
endlink upgrade needed w/ ASB upgrade? red07 MazdaSpeed 3/6 - Suspension & Brakes 12 11-26-2008 01:34 AM
Page generated in 0.26327 seconds with 23 queries
