 Old 01-05-2020, 10:05 PM   #1
EpsilonMSP3's Avatar
Posts: 11   (View Stats)
EpsilonMSP3 is just really niceEpsilonMSP3 is just really niceEpsilonMSP3 is just really niceEpsilonMSP3 is just really nice
any feedback is more than welcome
i cant do the repair myself and i was wondering how much you might be charged by a shop to fix it
EpsilonMSP3 is offline   Reply With Quote
 Old 01-06-2020, 11:05 AM   #2
Db09ms3's Avatar
Posts: 536   (View Stats)
They are fairly easy to change but I would guess around 150 or 200 at a shop not including parts.
Stockish
 Old 01-06-2020, 12:04 PM   #3
MSMS3's Avatar
Posts: 2,826   (View Stats)
If you are going to do the front struts, be sure to replace the parts above the strut. Those are the strut bearings and top hats. If the struts need replacing, they do too. They are inexpensive, but if you fail to replace them and get noise afterward (popping, creaking) caused by the new, stiffer struts, you’ll hate yourself, because you’ll have to do the labor all over again.
Use the ones for the Ford Focus. They are an improved redesign and are cheaper.
Affordable redesigned top hats/struts mounts and bearings from FORD
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
Db09ms3 (01-06-2020), YammerR1 (01-06-2020)
Interested in tubular, adjustable MS3 front lower control arms? Nliiitend1 MazdaSpeed 3/6 - Suspension & Brakes 128 08-02-2019 09:55 PM
Looking for front upper control arms... Ecamp2009 Mazdaspeed3/6 General Discussion 2 05-04-2017 08:41 AM
Whiteline Front Control Arms? Todd98SE 2010 MS3 - Suspension & Brakes 46 11-01-2012 01:16 PM
Front Suspension/Control Arms aaronc7 Miata - Suspension & Brakes 12 11-07-2010 10:27 AM
Page generated in 0.23738 seconds with 22 queries
