 Old 05-26-2014, 07:22 PM   #1
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Default Installed Bilstein B14 PSS Coils
Got these from edge last week, they are only height adjustable, no adjustable damping, but I am just using them for parkway runs and occasional mountain driving. I got to try them out a couple days ago on the parkway (after an alignment) and damn to they make the car handle great. I had Bilstein B8s and Eibachs on my old speed 3 and they were decent, but I was throwing the car into curves harder than I would ever dare on my old setup.
It could also be the new wheel/tire combo helping out, I went with 17x8 +45 RPF1s with conti extreme contact dw 235/45s. The car rides great over very bumpy back roads around my house, and feels awesome on the highway as well, close to stock but a little rougher over big bumps and dips. I did manage to fuck up my driverside fender while trying to roll them using the baseball bat method, and that really pisses me off, hopefully the dent can be pulled using PDR...
Anyway, here are some pics, they dont slam the car by any means, the fronts have a 15mm adjustable range that you have to measure once they are installed on the car from the center of the strut knuckle bolt up to the spring perch. However there is at least an inch and a half of extra threaded part where you "could" lower the car more, but im assuming that puts the struts into an area it isnt meant to operate in. The rears only have 5mm of adjustable range, which you can measure and set before installing them above the springs.
Some of these were before i installed my DIY center caps, others were after.
09 MGM MS3
The Following 2 Users Say Thank You to Addikted To Boost For This Useful Post:
doctavus (05-26-2014), Jester2552 (05-28-2014)
 Old 05-26-2014, 07:28 PM   #2
doctavus's Avatar
Posts: 1,728   (View Stats)
Sexy, looks great!
The Following User Says Thank You to doctavus For This Useful Post:
Addikted To Boost (05-27-2014)
 Old 05-26-2014, 09:21 PM   #3
jtday's Avatar
Posts: 650   (View Stats)
That color combination looks AWESOME...
2009 MS3 GT
The Following User Says Thank You to jtday For This Useful Post:
 Old 05-26-2014, 09:38 PM   #4
dealerjohn1's Avatar
Posts: 268   (View Stats)
dealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the world
Damm fine setup you have got there
dealerjohn1 is offline   Reply With Quote
The Following User Says Thank You to dealerjohn1 For This Useful Post:
 Old 05-26-2014, 10:09 PM   #5
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Maybe it's the tires then, because B8 + Eibach pro (=B12) + alignment kit (Corksport camber plates in front, Eibach arms for the rear) handles better than the B14.
However, there's just a tad more roll with the B12 than the B14 and about as much more squat, which takes away from the driver's confidence when throwing the car hard around curves and tight turns, but the grip is there and about the same.
With the B14 kit always have a spare set of strut bearings at reach. On rough roads the coils of the front spring may come in contact occasionally and every 6-8k miles the front strut bearings will need to be replaced.
Otherwise it's an awesome suspension kit which will put a smile on your face both on the track and road.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 05-27-2014, 06:13 AM   #6
Im hoping i dont have to swap the strut bearings that often...the roads around me are pretty decent so hopefully that wont be an issue
09 MGM MS3
 Old 05-28-2014, 03:22 AM   #7
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
Looking good! Although I'm not used to see MS3 with 17's on, and man that's a lot of tires. They look comfortable.
May I ask why you decided to go with 17's instead of 18's?
 Old 05-28-2014, 06:58 AM   #8
I wanted something lightweight, and these wheels are only about 16 lbs each, and also wanted a little taller sidewall to offset some of the harshness from the coilovers. Plus they were out of the OZ Ultralaggeras i wanted which were 18s in gold, and they dont make the RPF1s in 18s in gold that fit our car...
09 MGM MS3
 Old 05-28-2014, 02:59 PM   #9
Nice! I'm a big fan of OZ stuff.
I had my eyes set on the OZ Alleggerita's until I realized it'll bankrupt me if I were to buy them new.
 Old 10-16-2014, 01:42 PM   #10
RusianKid's Avatar
Posts: 353   (View Stats)
RusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the world
@Addikted To Boost;
Could you give us an update on how these are holding up?
How many miles driven on them?
Any weird noises?
"RACING IS AN ADDICTION CURED ONLY BY POVERTY"
RusianKid is offline   Reply With Quote
 Old 10-17-2014, 09:08 PM   #11
I've got about eight thousand miles on them so far, they're doing great, no noises, car handles like it's on rails
09 MGM MS3
The Following User Says Thank You to Addikted To Boost For This Useful Post:
mituc (10-17-2014)
 Old 10-17-2014, 09:55 PM   #12
RusianKid's Avatar
That is great to hear!
Do you remember what your front strut measurement was(the one between 225mm-250mm)? and the back(between 45mm-50mm)?
Do you feel like the dampeners are valves properly for the MS3?
 Old 10-18-2014, 04:28 AM   #13
I set them to as low as the manual allowed, I'm by no means a suspension expert but they behave well in my opinion in just about all conditions
09 MGM MS3
 Old 10-18-2014, 06:41 AM   #14
RusianKid's Avatar
Thanks for all the feedback!
One last question, how is the clearance between tire and strut?
 Old 12-02-2014, 08:34 AM   #15
RusianKid's Avatar
What paint did you use for the center caps?
I just purchased some gold RPF1s and am looking to paint my Honda caps gold
 Old 12-02-2014, 09:28 AM   #16
I dont remember really, i just picked out a gold color at advance auto that looked close. Mine isnt an exact match but its close enough. I just sold these wheels actually.
09 MGM MS3
 Old 12-02-2014, 03:54 PM   #17
its certainly not as smooth as stock but ive riden in cars with much stiffer coilovers i'd say these are good for daily driving but it can get a little unruly over rough patches of road.
09 MGM MS3
installed: bilstein sports & cobb springs jack_hammer MazdaSpeed 3/6 - Suspension & Brakes 38 09-29-2014 01:59 PM
Sonic Tuning Coils Installed narezzaspeed3 2010 MS3 - Suspension & Brakes 30 12-23-2013 02:36 PM
Installed Bilstein Shocks & EiBach Springs on the Speed6 RAR MazdaSpeed 3/6 - Suspension & Brakes 14 04-25-2012 02:53 PM
KW Variant 1 Coils vs. H&R Coils surfwagon MazdaSpeed 3/6 - Suspension & Brakes 11 04-10-2011 10:18 AM
Page generated in 0.38377 seconds with 26 queries
