 Old 09-10-2012, 11:00 PM   #1
tinboi479's Avatar
Posts: 267   (View Stats)
tinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the world
Default Koni Yellows installed with Eibach pro kit now shock mount broken!
I just got the Koni Yellows installed with the Eibach pro kit. Car looks good and drives way better than stock struts. Had the stock ones for 80k. Totally gone. Well after driving for around 60 miles, I started hearing clunks and rattle as if something is flying around my rear right fender. When I got home I checked everything that could've made the the clunking noise and I found out that the rear shock mount broke! I had these professionally installed so I don't know what went wrong that cause the shock mount to break on me. Are they made for aftermarket or they're just old?
tinboi479 is offline   Reply With Quote
 Old 09-11-2012, 10:50 AM   #2
Kawiralph's Avatar
Posts: 17   (View Stats)
Kawiralph is just really niceKawiralph is just really niceKawiralph is just really niceKawiralph is just really niceKawiralph is just really nice
Probably just old and worn or a bad install. I'm running the same setup on my Pu and no problems up to now.
Kawiralph is offline   Reply With Quote
 Old 09-11-2012, 11:29 AM   #3
SKiZ0TT's Avatar
Posts: 542   (View Stats)
SKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the world
Groans: 33
I'm trying to find the OEM rear bump stops and shock mount, but can't find the part numbers.
2008.5 MAZDASPEED3 GT - SOLD
2004 MAZDASPEED Miata
SKiZ0TT is offline   Reply With Quote
 Old 09-11-2012, 12:10 PM   #4
dark_matter's Avatar
Posts: 193   (View Stats)
dark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond repute
Don't think Mazda sells the rear mounts by itself. They sell it with the shocks and bumpstop as an assembly.
Sparkling Graphite Metallic E90 330i 6speed ZSP
RIP: くろ ひめ BlackMica SPEED3
dark_matter is offline   Reply With Quote
The Following User Says Thank You to dark_matter For This Useful Post:
SKiZ0TT (09-11-2012)
 Old 09-11-2012, 12:34 PM   #5
SKiZ0TT's Avatar
Groans: 33
From the illustrations on mazda-parts.com thats what it looked like to me..
Rockauto does carry the shock mount:
More Information for DORMAN 924412
The Following User Says Thank You to SKiZ0TT For This Useful Post:
Nliiitend1 (09-13-2012)
 Old 09-12-2012, 12:07 PM   #6
justint5387's Avatar
Posts: 608   (View Stats)
justint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the world
Do you have a picture? Did they break the two upper studs?
justint5387 is offline   Reply With Quote
 Old 09-12-2012, 12:30 PM   #7
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
I broke one of those studs surprisingly easily.
 Old 09-12-2012, 12:38 PM   #8
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
torque spec for shock mount is about 25 or 30 lbs if i remember correctly, which is not much at all ... possible that the person who installed it over torqued it.
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 09-13-2012, 04:41 AM   #9
tinboi479's Avatar
Ya one of the studs broke and they replaced it for free. Yes they had to order the whole shock assembly in order to get the mount. Well at least I got a new bump stop on one side. I always carry heavy things in my car so that might have caused it to be more worn out. But now that everything is fixed the car handles wayyyyy different than stock. Most people change the struts at around 50k but I didn't notice how bad they've gotten until I hit 80k recently. Like I get wheel hops when I turn then I know that I really have to get them changed. Now I corner like crazy I hope the other side doesn't break on me too though.
 Old 09-13-2012, 06:17 AM   #10
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
you'll notice an even bigger change with better springs. eibachs are too soft
Blue Pu.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
easy (09-13-2012), SKiZ0TT (09-13-2012)
 Old 09-13-2012, 06:19 AM   #11
SKiZ0TT's Avatar
Groans: 33
I'm looking to replace my Eibachs with Cobb springs. Among other things I want to get done..
 Old 09-13-2012, 06:20 AM   #12
anavrinIV's Avatar
Groans: 63
I plan on getting cobbs as well once they're re-released
Blue Pu.
 Old 09-13-2012, 07:34 AM   #13
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Mounts are available stand-alone, but they don't come with bumpstops (those only come with a new shock)...
Dorman 924-412 Upper Shock Mount for Mazda 3/5 : Amazon.com : AutomotiveDorman 924-412 Upper Shock Mount for Mazda 3/5 : Amazon.com : Automotive
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
daafisch (09-13-2012)
 Old 09-13-2012, 09:34 AM   #14
SKiZ0TT's Avatar
Groans: 33
RockAuto is a bit cheaper, but if you have Amazon prime the shipping is free anyway - so it would be pretty much a wash.
 Old 09-13-2012, 10:48 AM   #15
Nliiitend1's Avatar
Lol. I apparently just skipped over your original post...
2008 MS3 GT
2016 MX-5 Club
 Old 09-13-2012, 11:19 AM   #16
SKiZ0TT's Avatar
Groans: 33
No worries, I'm brown - easy to gloss over any posts by brownie.
Rear Koni Yellows kinetiq MazdaSpeed 3/6 - Suspension & Brakes 11 08-16-2012 11:47 PM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Koni Yellows - who has them in stock? martin_nj MazdaSpeed 3/6 - Suspension & Brakes 4 09-20-2011 02:43 PM
Page generated in 0.38052 seconds with 28 queries
