 Old 11-13-2010, 05:09 PM   #1
surfwagon's Avatar
Posts: 456   (View Stats)
surfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the world
Default KW Variant 1 Coils vs. H&R Coils
I'm trying to decide between the KW Variant 1 and the H&R Coilovers. Does one have any benefit over the other? Which has the most compliant (comfortable) ride at the lower settings?
2012 G37S; 7 speed paddle shifters
2007 Mazdaspeed3 GT; Hypertech Tuned, MS CAI, ETS 3" TMIC, Catless CorkSport Down-Pipe, Catted Corksport Mid-Pipe, Corksport Cat-Back Exhaust, Forge II BPV, Cobb front and rear sway bars, KW V1 Coilovers, JBR Shifter Plate, TWM STS/Bushing, SU Rear Mount, GROM ipod link, Sub/Amp added to Bose - Sold
1995 Nissan 300ZX Twin Turbo; SRI - ASHSPEC ECU - MBC @ 14psi - Turbo-Back Exhaust - Larger Intercoolers - RPS Street Sport Clutch - RPS Flywheel - Megan Springs - Subframe Spacers - 51,000 original miles - Thrill Ride and Sold
surfwagon is offline   Reply With Quote
 Old 11-13-2010, 05:15 PM   #2
KW hands down, don't even spend the money on the H&R's.
 Old 11-13-2010, 05:59 PM   #3
surfwagon's Avatar
Thanks Kevin. Why is the KW 1 a better set-up? Do you lose suspension travel as you lower it the same as you do with H&R
 Old 11-13-2010, 10:37 PM   #4
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
I have ridden in both - H&R has a more compliant ride. KW has stiffer, linnear springs that are better suited for track use. And V1's are a bit harsh at any height w/o adjustable damping. But if you're going to drop the car beyond 1.5" get KW's and call it a day. The stiffer rate is better suited for limited suspension travel.
09 CWP MS3 GT
Ownership & Build Thread
 Old 11-13-2010, 10:45 PM   #5
surfwagon's Avatar
Thank you Sir. Are there any other opinions? Any help is appreciated.
 Old 11-14-2010, 05:47 AM   #6
If you wanted comfort... you wouldnt be considering coilovers to begin with. KW's have progressive rate springs so as the suspension demand increases so does the springs rate. V1s are 1 way adjustable but you can spend another $500 and gef the V2s and be a straight baller
 Old 11-14-2010, 11:39 AM   #7
Design's Avatar
LOL few corrections there:
- KW is a linear system. Rear has "dead" coils to maintain control at full droop.
- V1's have no damping adjustment.
- If you're paying more than $300 for rebound adjustment/inox you're being ripped off.
Originally Posted by surfwagon View Post
Is $1500 at Protege Garage the best price for the KW V2's. Has anyone found a better price?
That's about has cheap as they come. Have you tried the site vendors?
09 CWP MS3 GT
 Old 11-14-2010, 08:00 AM   #8
surfwagon's Avatar
 Old 01-22-2011, 06:20 PM   #9
surfwagon's Avatar
Alright, I bought the KW V1's and I put them on today. Two questions...
1. How do you adjust the rear height? Are you supposed to use an allen wrench at the underside of the spring perch?
2. To raise the ride height at the front do you turn clockwise or counter clockwise?
The car is slammed right now.
 Old 04-10-2011, 10:18 AM   #10
surfwagon's Avatar
I almost forgot...
1. The rear is easy to adjust. Jack up the rear so the suspension is unloaded. A 10mm hex socket allows you to raise and lower the perch.
2. To adjust the front you turn counter-clockiwise.
 Old 04-10-2011, 08:01 AM   #11
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
I would get the KW's
 Old 04-10-2011, 09:54 AM   #12
surfwagon's Avatar
I bought the KW's shortly after posting. They're great. I definitely made the right choice.
Tein coils on ebay? TheNewGuy MazdaSpeed 3/6 - Suspension & Brakes 1 07-28-2010 02:42 PM
affordable coils for ms3? phillyb MazdaSpeed 3/6 - Suspension & Brakes 51 05-27-2010 03:11 PM
drop on BC coils MS3Zoom24 MazdaSpeed 3/6 - Suspension & Brakes 10 02-03-2010 11:46 PM
How often to coils need adjustment KayWhy MazdaSpeed 3/6 - Suspension & Brakes 4 09-28-2009 06:17 AM
Page generated in 0.33138 seconds with 23 queries
