 Old 10-01-2009, 11:55 AM   #1
Team Überfrazn
labikesrcool's Avatar
Posts: 782   (View Stats)
labikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the world
Default MS3 Alignment Specifications
I searched for this and couldn't find it on this forum. found it elsewhere. is it just me or are the tolerances huge? they give targets down to the minute but have full degrees for some of the tolerances? it's like you should take this car straight off the dealer lot and to an alignment shop.
Alignment Front & Rear MS3.pdf
"My car won't start!"
"Well, maybe there's a killer after you."-Mitch Hedberg
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming.
- Mitch Hedberg
labikesrcool is offline   Reply With Quote
The Following 2 Users Say Thank You to labikesrcool For This Useful Post:
aaronc7 (10-01-2009), Blackspeed (10-01-2009)
 Old 10-01-2009, 12:18 PM   #2
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
You're right, the tolerances ARE huge. No one should assume that their off-the-lot car is properly aligned. Mine sure wasn't.
Motor Mounts & Alignment badams118 MazdaSpeed 3 - Engine, Transmission & Driveline 18 03-19-2009 01:47 PM
Alignment specs Hectik1 MazdaSpeed 3/6 - Suspension & Brakes 17 02-02-2009 07:33 AM
TIME FOR ALIGNMENT?? wisniaPl MazdaSpeed 3/6 - Suspension & Brakes 14 01-23-2009 11:33 AM
2010 Nissan GT-R Spec-V coming Janaury 8th, full specifications leaked Haltech Automotive News 0 12-01-2008 07:20 AM
Will these rim specifications work? SLOMS3 MazdaSpeed 3/6 - Wheels & Tires 2 09-12-2008 01:29 PM
Page generated in 0.23335 seconds with 22 queries
