 Old 03-26-2019, 10:00 AM   #1
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
Default MS6 Eibach Springs
So I have a chance to get some slightly used Eibach springs for my car, now doing a search for these net a bunch of posts from 8 years ago.. I'm wondering how these have held up for people and what are the draw backs of them. I am sure that the rear spring rate is too soft but do they sag quite a bit easily and quickly or do they hold up decent?
I'm only looking for 1-1.5" lower at the most anyway, I'd love to do some kind of coilover but just not in the cards. Probably would run Bilstien B8's with these if anything.
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
 Old 03-26-2019, 05:50 PM   #2
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
I did not like the Eibachs that were in my car. They sagged in the rear and I think were the source for some issues I had with my rear CV shafts.
hwy vibration, digging deep. Big read if you want to help...
Its as tho the CVs were bottoming out in the cup and the rear diff would do a wierd wobble when the CVs would bind up under acceleration, ending in a snapping or clicking sound with each wheel rotation. The carnage is in the pics. It was worse with more weight in the back seat/trunk.
I still have the Eibachs in the front, but have installed OEM in the rear giving my car a silly hotrod rake, but I plan on cutting 1 round out of the rears as per this...
HOW-TO: Cut OEM Springs
I actually feel the car handles better on off ramps with the OEM springs in the rear. I am able to induce a slight oversteer on long sweepers when boost builds and maintain until adhesion returns with constant throttle application. Comfortably and predictably.
I had considered trying spring rubber to play with the rate under load, but the Eibach springs are smaller diameter than the rubbers I have on hand...And hindered by laziness on the matter.
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
Page generated in 0.22741 seconds with 21 queries
