| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
| Not Ranked : 0 score Get Centric blanks and EBC Redstuff pads.
__________________ |
(Thread Starter) | Not Ranked : 0 score arent redstuffs like only for track use... this is my dd and my mountain fun car nothing really more i go to track every once and awhile |
![]() Join Date: Apr 2010 Location: Suburban Detroit
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
(Thread Starter) | Not Ranked : 0 score does anyone have them? hows dusting on them? and hows noise? |
Groans: 196
| Not Ranked : 0 score I daily drive with the Redstuffs. Fantastic pads for this car. Lower, lighter dusting and brakes better than OEM.
![]() Join Date: Mar 2010 Location: Memphis, TN
Rep Power: 315 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 621
| Not Ranked : 0 score ive heard redstuff are good for daily driving as well. i will be getting them when i wear out my stock brakes
__________________ 2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune |
(Thread Starter) | Not Ranked : 0 score i decided to go with hawk HPS street performance pads have heard nothing bad about them and they are a little easier on the pocket book |
![]() Join Date: Apr 2010 Location: Northern VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score They're better than the green stuff.
__________________ Ryan | 06 ZX10r | 08.5 Speed3 GT |
(Thread Starter) | Not Ranked : 0 score cool good i jst received my rotors and brake pads today!!!
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() Join Date: May 2010 Location: Beaumont, AB, Canada
| Not Ranked : 0 score anyone have a bb kit like 1500 dollar one? curious of resiults |
(Thread Starter) | Not Ranked : 0 score got all my stuffs in .... excited to put it on this friday!!! and some shoes lol
(Thread Starter) | Not Ranked : 0 score well i have diff prob i think now... i think my calipers r too tight? like the brakes are always slightly on. did i tighten something too much or is it becuz i have new pads and the thickness of the pad?
![]() Join Date: May 2009 Location: Browns Mills/NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score why do you think your brakes are always on? do they constantly squeal? Did you break them in like your supposed too. FYI those pads will make a ton of noise on the street until you warm them up.
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA |
(Thread Starter) | Not Ranked : 0 score because on a slant in neutral my car doesnt roll ne more.... i think i can hear them a tiny bit too andn i can smeel breaks everytime i stop driving and i havent evn driven it hard yet and yes i burnished them in according to instuctions on HAWK HPS pad box
| Not Ranked : 0 score did you grease up your calipers and sliders? how many miles on new pads(ive had them smell burnt for about 50-100mi) im guessing your wearing the pads uneven, by not having enough grease on the calipers though.
(Thread Starter) | Not Ranked : 0 score grease wat part of the calipers i greased the 2 lil pins u put through the caliper. what else do u grease? im thinkin thts its the ebrake i need to adjust. since i put new pads and rotors with way more thickness on front and back i need to adjust so the ebrake releases more then it did before... kinda jst logic i was thinkin but does tht sound right?
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna Last edited by MSP611; 07-18-2010 at 11:18 PM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score The ebrake should only be an issue if these pads are thicker than new oem pads. jack up the car and find out which wheels your having issues with. Yea those pins need to be really greased up otherwise they bind.
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score they were greased very well i think i found out the problem
![]() | | #20 | ![]() |
| Not Ranked : 0 score when you find it let us know. im sure it will help others in the future.
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score are speed 3 and speed 6 rear calipers the same?
![]() | | #22 | ![]() |
| Not Ranked : 0 score I'd be interested in hearing what you think it was. No idea on the MS3 vs. MS6 tho. |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score im not sure i think its either an ebrake adjustment or my right rear caliper is shot.... cuz i twisted tht bitch a shit load and once i got to a point it wasnt going ne farther.
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score alright took back off to show some pics with the rubber boot off too see if u guys could help ne with the answer if it is seated all the way... heres some pics the one with the feeler gauges in is about .163" tht is how much space is in the piston other than the head of the piston. Tht is the amount right after the head of the piston( after the part u can turn in slimmer part)
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score figured it out yay its all good no heat or stench coming from right rear now and i can easily roll in neutral
![]() | | #26 | ![]() |
| Banned ![]() Join Date: Apr 2009 Location: Misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,148
Groans: 546
Groaned at 125 Times in 71 Posts
| Not Ranked : 0 score Your fail is amusing. Thank you for posting the progression of it in different threads. How to bleed ur brakes calipers mayb too tight? http://www.mazdaspeedforum.org/forum/foru...nded-up-61827/ http://www.mazdaspeedforum.org/forum/foru...caliper-61842/ The last one really cracks my shit up. |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score i didnt fail i fixed it and made sure i didnt drive it until i did only test drives. first brake job on this car and thx for the criticism i just posted it in diff threads so obviously peps didnt wanna answer in jst one
![]() | | #28 | ![]() |
Groans: 546
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score i fixed the problem. it was my first brake job on this car. and only reason i posted it in diff threads becuz the orig thread i posted it in no one was answering
![]() | | #30 | ![]() |
| Not Ranked : 0 score for arguements sake well call it temporary phail
![]() | | #31 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score just because people don't answer doesn't mean you should start 4 different threads about it. |
![]() | | #32 | ![]() |
![]() Join Date: Feb 2009 Location: San Diego, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score I have power slot rotors with Hawk HPS pads and the improvment is amazing. |
| OEM MS3 brakes = Volvo S60 brakes? | levitron | MazdaSpeed 3/6 - Suspension & Brakes | 109 | 03-02-2012 06:14 PM |
| Help changing brakes | Fletch | MazdaSpeed 3/6 - Suspension & Brakes | 4 | 03-13-2010 10:51 AM |
| 2009 MS3 brakes vs. 2010 MS3 brakes | Driver72 | 2010 MS3 - Suspension & Brakes | 11 | 11-21-2009 10:34 AM |
| No Brakes...Need help/opinions | Engi-Freakin-Neer | MazdaSpeed 3/6 - Suspension & Brakes | 25 | 10-09-2009 10:04 PM |
| 130 in MS6 shitty brakes ! | johnnyspeed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 19 | 04-12-2009 07:47 AM |
