Like Tree8Likes
 Old 12-17-2011, 11:25 PM   #1
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
Neutral  +2 score
Default The Official MS6 Suspension Thread
Updated 9/2015! Thank you to @Navy_Mech2; and @phate;!
I've added a few things and did an overhaul of the pic sizes and general formatting. Hope it's easier to read through, now.
I don't care what the "go fast or GTFO" guys say ... 4x4's look gay as hell! And if you put together a good suspension setup, the car gets fun as hell to drive. Fast straight lines are fun, but corners are something entirely better. The ghey Miata guys are onto something. Here's a big list of what we have available for lowering springs, shocks/struts, and coilover kits.
Nearly every product listed on this page was designed for the regular Mazda 6, but happens to fit the MS6. Due to the lighter weight of the regular 6, the spring rates are often disproportional to what the car needs to maintain the factory balance or (more ideally) increase the rear spring rate more than the front. The exceptions to this are the BC Racing coil overs, Fat Cat Motorsports coil overs (because they're completely custom), and the DIY coilovers where you can choose your own rates.
Lowering Springs - Lowering springs are one of the most common car tuning purchases. Lowering springs help minimize brake dive, body roll, rear squatting on acceleration and keep a smooth, comfortable ride. But they're mostly for making the car looks less like a stupid 4x4 and more like the way a car is supposed to look.
Shocks/Struts - Where real suspension performance starts to happen. If you ask Forzda here on MSF, he swears on a simple aftermarket strut/spring combo. Often allows adjustability of damping levels.
Coilover Kits - A simple, easy full coilover system with the spring over the strut. Usually offers much more adjustability than spring/shock setups. Typically offers adjustability of ride height & damping levels. The majority of the coil over kits listed in this thread are very similar to each other, being from the same country and possibly even the same factory. Each have their own variations, but have a look at each before purchasing. The exceptions to this are the Fat Cat Motorsports coil overs and DIY coilovers, since both are based on a Bilstein shock absorber.
Air Ride - With these kits, an air bag is used in lieu of the traditional coil spring. You can adjust ride height at the push of a button.
Sway Bars - Helps limit body roll. Can be adjustable. The thicker the diameter, typically the stiffer they are. Used in the rear can imply more oversteer during cornering.
As a reference, the stock spring rates are 280 lb/in front, and 180 lb/in rear.
LOWERING SPRINGS
AutoEXE Low Down Springs | Drop: 30mm | Part Number: MGS700
Spring Rates: 370/225 lb/in front/rear
A full length height adjustable suspension kit that puts sports performance first with features like a hard setting mono tube damper and linear rate race spring, and an aluminum upper mount with enhanced bush. Without interfering with cooling performance, the newly developed thin ö40 piston reduces friction surface, which decreases friction during damper operation. This has the effect of facilitating uniform handling while simultaneously restricting discomfort. The damping force is adjustable in 12 levels. Overhaul is possible.
Eibach Pro-Kit | Drop: 1.5" front, 1.4" rear | Part Number: 5543.140
Spring Rates: Unknown (advertised as progressive)
The Eibach Pro-kit dramatically improves both a vehicle's performance and appearance. The huge fender-well gap inherent from the factory or the installation of performance wheels and tires can give a vehicle a lifted look. The Pro-Kit is the perfect addition to any vehicle, lowering the fender gap and giving your ride a more attractive, sportier stance. By lowering the car's center of gravity, the Pro-Kit reduces squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus 1 or Plus 2 Size wheels and tires, the Eibach Pro-Kit is the finishing ingredient to a winning recipe for performance.
- Excellent ride quality - comfortable in cruising
- Sportive handling in cornering, resulting in improved performance
- Lowered center of gravity, increased stability
- Enhanced appearance of vehicle
- Million mile warranty
Eibach Sport Line | Drop: 2.0" front, 1.5" rear | Part Number: 4.4355
Spring Rates - Unknown (advertised as progressive)
Created for the extreme enthusiast, who wants that race-car attitude, Eibach Sportline springs are designed for maximum street performance - with the lowest possible drop. Engineered with the same care as Pro-Kit springs, Eibach's Sportline springs achieve legendary handling by aggressively lowering the vehicle's center of gravity with precision-engineered spring rates. The results is a car that handles as well as it looks. Eibach also offers top-quality Alignment Kits to keep proper suspension geometry.
- High Performance Handling
- Lower Center Of Gravity
- Excellent Ride Quality
- Top Quality Craftsmanship
- Million Mile Warranty
H&R Sport Springs | Drop: 1.4" front, 1.3" rear | Part Number: 52611
Spring Rates: 250/210 lb/in Front/Rear
The most popular spring in H&R's line-up, Sport Springs will lower your vehicle an average of 1.5 - 2 inches (depending upon the make and model of your vehicle) for a lower center of gravity, improved handling and a more aggressive appearance. The H&R Sport Springs for the Mazdaspeed 6 will lower your car 1.4 inches in the front and 1.3 inches in the rear. Sport springs feature more control than that of the OE Sport spring, but is still comfortable for daily use. Sport springs are an excellent choice for street and occasional track use.
Tokico Springs | Drop: --, -- | Part Numbers: 5110F-P / 5110R-P (front / rear)
TOKICO Sport Springs are manufactured using only the highest grade materials, and are matched to work in perfect unison with TOKICO performance Shocks. Our sport springs provide your car with improved chassis stability, better cornering, as well as vehicle
appearance. Our innovative spring design means dramatically improved aesthetics and handling, without compromising ride quality.
Depending on the application, TOKICO springs will lower your vehicle between
.75 to 1.75 inches. Since Shocks and Struts control the springs, it is important
to use performance Shocks and Struts when lowering your vehicle.
- Increased corner grip and chassis stability
- Phosphated and powder coated for superior corrosion protection
- Lifetime warranty
Corksport Springs | Drop: ~1.5" Front ~1.6" Rear | Part Number: Ate-3-288-10
Spring Rates - 280/215 lb/in Front/Rear
Give your car the performance appearance and edge you have been looking for with the CorkSport Lowering Springs for the Mazdaspeed 6. By reducing ride height approximately 1.5" in the front and 1.6" in the rear, adding the CorkSport Lowering Springs to your Mazdaspeed 6 will result in a quicker turning response, crisper road feel, a more aggressive appearance, and a firmer spring rate, all while maintaining excellent ride quality.
Designed for and tested on the Mazdaspeed 6
Lower your car by approx. 1.5" front and 1.6" rear for improved handling and less wheel gap
Crafted from high tensile strength spring steel for long lasting quality and performance
OEM finish to ensure lasting durability and rust protection
Backed by CorkSport limited two-year warranty
CorkSport Service and Support: Receive full color installation instructions, all of the needed installation hardware, and knowledgeable telephone installation support
SHOCKS/STRUTS
Bilstein HD | Part Number: BE5-A256/7/8
Bilstein HD shocks provide improved handling and stability without sacrificing ride comfort. They offer super damping ability that makes them ideal for occasional track use, while maintaining an exceptional street ride.
Bilstein's shock bodies are precision formed through a unique seamless extrusion process. This provides superior strength along with high finish tolerances that are usually associated with surgical instruments. The finished body is then mated with a solid, induction hardened steel chrome plated and polished shaft, machined valving components and highest quality seals. Combined with extreme attention to detail, Bilstein provides you with the closest thing to a hand built shock available today.
This is a complete set of direct replacement shocks for the Mazda 6 or Mazdaspeed 6, suitable for vehicles at stock ride height, or lowered up to 1.5 inches.
Front Left: BE5-A256
Front Right: BE5-A257
Rear: BE5-A258
Note: These can be converted to coilovers, as seen here: MS6 Suspension Data & DIY Bilstein Coilovers
Koni FSD Damper Set | Part Number: 2100-4052
KONI’s latest technology accomplishes the task that has eluded most shock makers until now - great handling + excellent ride quality:
- Taut body motion control
- Excellent ride quality on all road surfaces
- Patented, parallel-valve design
- Pair with Eibach springs for 1-1.5” lowering (not included)
- Gold metallic finish shocks
- Less expensive than electronic systems
Koni Yellow (front) | Part Number: 8041-1305
Koni Yellow (rear) | Part Number: 8041-1306
KONI Sport Shocks (Also known as KONI Yellows) serve sporting drivers with sport shock absorbers that focus on exceptional road holding combined with an acceptable level of comfort. Their characteristics include responsive steering, reduced body-roll and limited body movements. They are also externally adjustable, making fine tuning even more easy.
Tokico HP Series | Part Numbers: HU3758 / HU3759 / HE3760 (FL, FR, R)
*Note: These are designed for the regular Mazda6, but some vendors (specifically on eBay) are marketing them for the MS6. They will fit, but the damping may not be ideal for the MS6. Thanks to @KevinK2; for pointing this out.
The famous “Blue Shocks,” TOKICO’s HP Series continues to be the overwhelming choice of performance enthusiasts looking for the best in overall handling and ride quality.
Not all shocks and struts are created equal. TOKICO Performance shocks have many features that are unique in their design, and the source of their reputation as a premium shock absorber.
The HP Series typifies TOKICO’s damping philosophy and valving flexibility. By minimizing low-speed damping force and greatly increasing damping at medium and high piston speeds, HP shocks and struts optimize tire adhesion, handling precision and ride composure.
The heart of TOKICO’s HP Series is its unique piston design. A multi-stage variable-aperture valve system features precise orifice control, creating the unique flexibility and accuracy of its damping response. The oil lubricant is also specially compounded to resist breakdown and minimize viscosity change as temperatures vary. A superior performance and traction upgrade with virtually no compromise in ride quality, TOKICO’s HP Series shocks and struts are also an ideal upgrade for vehicles with lowering springs and larger, heavier aftermarket wheels.
Benefits of tokico’s aftermarket performance shocks and struts:
Improved:
Traction
Stability
Steering response
Cornering ability
Braking ability
Superiors:
Ride quality
Shock and strut longevity
Reliability
Reduced:
Dive under braking
Squat under acceleration
Pitch during straight-ahead driving
Suspension bottoming
Precision Construction
Pressure Tube is mandrel-drawn twice to ensure precise dimensional tolerances
and concentricity, for excellent sealing and minimal dynamic friction (drag).
Reduced Friction
Teflon™ coated Piston Rod Guide minimizes dynamic friction and extends piston-rod life.
Piston Quality
Piston Rod is hardened, chrome-plated and micro-polished, for smooth operation and
contributing to long seal life.
COILOVERS
AutoEXE Sports Tunable Suspension | Drop: -- | Part Number: MGS7900
Spring Rates: 900/336 lb/in Front/Rear
BC Racing BR Series | Drop: -- | Part Number: BC-N-01
Spring Rates: 660/440 lb/in Front/Rear (other rates available upon request)
Ride Height Adjustable: The ride height adjustment ranges from a conservative stance, to being low enough to tuck the tires up into the fender well.
Dampening Adjustable: Dampening adjustment is done by hand on the top of each strut. The 32 levels of the dampening force allows for a very comfortable, smooth ride on the street to a very tight ride which is great for track visits.
BC Racing ER Series | Drop: -- | Part Number: BC-N-01-ER
Spring Rates: Unknown, assumed the same as BR series (other rates available upon request)
ER SeriesOur newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
- External Reservoir Mono-tube shock design
- 30 levels of damping force adjustment, adjusts both compression and rebound separately
- Twin piston design
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
H&R Coilover Tunable Suspension | Drop: 1.2"-2.5" front, 1.0"-2.3" rear | Part Number: 29278-6
Dampened and tuned specifically for the all wheel drive MAZDASPEED 6.
H&R Threaded-Body Coil-Over Suspension Kits come directly from engineers who design and develop racing suspensions.
Blueprinted as coil-overs (not just a modified shock body), the H&R units are hand assembled in Germany by H&R Speziafedern under rigid ISO 9001 and German TÜV standards. Strict attention to the function of the complete suspension system is the number one design priority.
Their threaded body means that the outside of the strut or shock tubes are threaded like a bolt. This allows the threaded spring perch to be moved up or down to fine-tune the ride height, optimizing looks and handling.
Equally at home on the street or the track, H&R Coil-Over Suspension Kits provide enhanced performance, improved corner-holding ability and a sleek, aggressive stance for performance driving characteristics without harshness.
The Coil-Over Suspension Kits pictured above represent just a few samples of those available from H&R. Coil-Over Suspension Kits are engineered specifically for each vehicle and may combine different components than those pictured based on the vehicle's design. Coil-Over Suspension Kits can be used for driving in weekend club sport events or lapping the public course at the Nurburgring.
KW Variant 2 | Drop: -- | Part Number: 15275005
Spring Rates: Unknown (Progressive in rear)
The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
• Damping technology with individually adjustable rebound
• inox-line stainless steel technology at no additional charge
• Individually height adjustable
• German TUEV-tested adjustment parameters
• High-quality components for long life
• Comprehensive documentation for ease of use
• Infinitely adjustable rebound damping
Yellowspeed Dynamic Pro Coilovers | Drop: -- | Part Number: YS01-MZ-DPS008-10
DYNAMIC PRO SPORT coilovers are designed and developed for all motoring enthusiasts wanting excellent handling without sacrificing comfort. This suspension system features 33-way adjustable dampening settings and full length adjustment to meet every driver’s handling desires. Pillowball mounts and adjustable camber plates are included for front and rear on most kits to increase steering response, while aluminum upper mounts with hardened rubber bushings are used on some applications for noise reduction. This suspension system is ideal for daily driving and occasional track use.
High quality components are adopted to ensure product durability and stability. Each application is fully test fit and completely road tested to guarantee all our customers perfect performance and comfort.
33-WAY DAMPENING ADJUSTABLE
This suspension system features 33-way dampening force adjustment (compression/ rebound). A wide range of dampening adjustments can be made to provide a variety of responses to different road conditions and to tune the ride feel.
PILLOW BALL UPPER MOUNT W/ ADJUSTABLE CAMBER PLATE
The pillow ball mount with camber plate is included on the front and the rear to offer direct and complete handling response (not available for some applications). For those people who dislike the slight noise caused by the pillow ball, we also offer hardened rubber upper mount for noise reduction and enhancement of ride comfort and handling stability.* The hardened rubber upper mount is optional.
MONO TUBE INTERNAL DESIGN
15 month limited warranty on insert
The needle valve piston (material imported from Sweden) is utilized to make the steering more agile and to stabilize the vehicle. A high rigidity 52mm shock body with extra oil capacity enables the cushioning force to have optimal linear change. We use highly reputable seal brand - NOK, whose seals can withstand high temperatures and prevent oil leakage. The piston rod is made from high quality S45C steel and is processed with Thermal Refining and High-frequency Induction Hardening Treatments for rigidity and durability. YELLOW SPEED’s commitment is to ensure safety and to provide high quality products, hence the shock stroke movement has been tested 10 million times on advanced testing equipment; this amount of testing is equal to a vehicle with 5-years of mileage. Each component of the suspension system is rigorously inspected and strictly tested by YELLOW SPEED to avoid any failure. Our commitment to continual driving improvement goes beyond words.
HIGH RIGIDITY STEEL SPRING
The spring is made from high quality SAE9254 steel for optimal durability and high tensile strength. The spring rate remains unchanged and undeformed even after the spring has been subjected to long term wear and even if compressed or extended.
ADJUSTABLE SPRING SEAT
In addition to the lower bracket, the vehicle ride height can be adjusted by the spring seat as well. The spring seats are made from forged aluminum for durability and rigidity.
SHOCK BODY
Shock body is coated with Electroplating treatment to prevent rust and corrosion.
FULL LENGTH ADJUSTABLE
A steel lower bracket is adopted on most MacPherson struts to increase rigidity for safety (some applications use aluminum lower brackets) , while a forged aluminum lower bracket on Double A Arm struts. The ride height can be adjusted by both lower bracket types without affecting the shock stroke.
DEVELOPED DAMPING OIL
Our formula damping oil contains high quality deformer to prevent foaming, and the viscosity remains unchanged under any working temperature conditions to ensure that all internal components perform perfectly.
ISC Adjustable Coilovers | Drop:-- | Part Number: M107B-SC (Street Comfort) / M107B-SS (Street Sport) / M107B-TR (Track/Race)
Spring Rates: 672/336 lb/in Front/Rear
Product Description
The ISC N1 coilover is the optimum suspension tool for improved handling for your street or weekend track car. This product is perfect for someone looking for performance, adjustability (height and dampening) and other quality features.
Our self-manufactured ISC N1 allows us to have top grade quality control, and innovative R&D capabilities due to our in house/ self-made company dynamic. ISC has been present for over 12 years in Asia and Australia, which accomplished drift, road course, street enthusiasts and podiums alike. Over a decade of experience and feedback has allowed the ISC N1 to evolve into what it is today.
Details:
SO9001:2000R Certified
ARTC Certified
ISC Suspension warranties its products to the original purchaser against defects in workmanship and material for 5 years.
All ISC Suspension products with the exception of Brakes are covered by a limited 5 year warranty that is NON-TRANSFERABLE. The Warranty is limited to the United States and Canada. Professional installation is recommended with all products to avoid the warranty becoming void due to improper handling and or installation. This limited warranty covers Bolt-on components such as bottom mounts, top hats, camber plates, and shock bodies. It also covers shafts and internals such as seals, fluids, pillow ball mounts, and leaking shocks 2 years from the purchase date. Parts and REBUILD labor are covered under the warranty however shipping is not covered.
ISC Suspension Bolt-on Components: Lower Mounts, Locking Collars, Spring Seats, Spring Gaskets, Top Hats/Camber Plates, and hardware such as studs and bolts. All Hard Parts have a 5 year limited warranty.
ISC Suspension Shafts and Internals: Thrust Bearings, Pillow Balls, Jetting Assemblies, Shaft Seals and O-Rings and O-Rings Seals, Piston Shafts, Shock Absorber Internals; Oil and Fluid & Shock Absorber Gas Leaks. All Consumables carry a 2 year limited warranty.
ISC Suspension’s 5 year Limited Warranty does not apply to the following:
1. Any products that are used on public roads, highways, and or government maintained roads or non-motorsport roads or tracks.
2. Any products not purchased through an authorized ISC Suspension dealer. Dealer List can be found here: ISC Suspension Dealers
3. Any products that show abuse, improper installation, or collision.
4. Any products that have been altered in any way.
5. Seized Collars, ISC Suspension recommends using anti-seize on all collars to avoid this.
A warranty claim form can be found on ISC’s website, under the warranty section.
32 Step Damper Adjustable:
Rebound/ Compression adjusted in unison via 32 step adjustment
Pillowball Upper mounts:
For optimal performance Pillowball Upper mounts are a great feature. ISC Coilovers include pillowball upper mounts on all N1’s.
Thrust Bearing Kit:
We will not charge you 50.00- 100.00 to upgrade to a thrust bearing kit, these are a FREE upgrade on all ISC N1’s. This helps eliminate the chance of spring bind; a common side effect of running aftermarket coilovers.
Front Camber Plates:
When your vehicle’s suspension geometry allows (vehicle specific, please check our application guide) all ISC N1’s come with adjustable camber plates standard.
Piston Rod Design:
High rigidity steel piston rods
Meets with race/sport standards
Shafts are valved according to the spring rate you choose. A Shock Dyno is used to ensure quality and consistent results.
Single Cylinder Design:
Larger cylinder and piston design to advance driving stability and dexterity. Mono-Tube damper with high pressure nitrogen
Threaded portion of shaft is powder coated then salt spray coated for optimum street durability- We suggest also using anti seize or other protective products when you install your coilovers for even further protection from the elements if you are exposed to snow and salt.
Sports Spring:
Made from high quality SAE9254 steel
Dyno tested over 500,000 times on compression inspection with less than 5% deformation.
Fully Custom Spring Rates/Valving: Street Comfort, Street/Sport or Track/Race (spring rates vary depending on application, custom spring rates are available). We understand each driver has unique demands are happy to offer you a custom set for your vehicle.
Full length height adjustable- 3 inches or more on most applications
High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Bound Adjustable with Separate Spring Locks:
Preload is separate from ride height; the lower you go the ride quality stays the same!
Aluminum Brackets:
Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance
ISC Gold or Black anodized surface to help prevent inside corrosion and surface rust
Brake lines and mounting brackets are welded onto the bottom mounts in most applications for an OEM type installation and fitment.
Fat Cat Motorsports Coilovers | Drop: -- | Part Number: N/A
Spring Rates: This is a completely custom setup for your car, based on what you want the car to do, how you drive the car, and what type of driving/racing you do.
Big shout out to @Code Monkey; for doing all the work getting these made. Since they aren't directly listed on FCM's website, here's a link to his thread on them which also contains a link to his ongoing review of them (since I don't know a damn thing about them). Since they're made to your specs, you can go as mild or wild as you want.
Thread: Fat Cat Motorsports coilovers for MS6
Review: Review of Fat Cat Motorsports coilovers (Mazdaspeed6 road racing setup)
Scale Suspension Innovative Series Coilovers
Spring Rates: 672/280 lb/in Front/Rear (Different rates available upon request)
-12 Level adjustable damping
-Exclusive measurement system
-Monotube design
-Molybdenum* rod
-Adjustable ride-height -0.5” to -4.5”
-Separate ride-height and spring pre-load
-Forged aluminium parts
-Anodized & powdercoated finish
-Custom spring rate
-Affordable
-Short cartridge for lower application
-Fully adjustable
-Street or racing use
Sonic Tuning S3 Coilovers
• Full length adjustment system on lower mount
• Separate ride hight and pre-load adjustments
• 6061 T6 Aluminum alloy construction: lower mount, top mount, spring seat and locks
• 12 level adjustable damper - adjustable dampers allow fine-tuning of the suspension stiffness to best suit the driving condition.
• SCM440 hardened piston rod: special high strength grade material with extra hardening process effectively improves the chances again deformation, fracture and leakage.
• Special formulated oil - stable and durable high quality oil seal can minimize any suspension failures or oil leaking to increase durability.
• Inner polished seamless steel tube - quality high strength tubes ensure the strength of the struts (cylinders). The micro finished inner surface ensures a precise and smooth action, which can reduce the chances of fluid leakage and prolongs struts endurance.
• Mono tube design ensures quick response and comfort. suspension fluid is separated from high-pressure gas in order to reduce damper failure.
• Advanced formulated rubber parts: effectively increase the endurance and help eliminate abnormal noises.
• Forged aluminum alloy top mount: increases the strength and effectively reduces the weight to provide sensitive driving feedback.
• SAE9254 spring: high strength material formed spring effectively minimizes deformation.
DIY Coilovers made from Bilstein shocks
AIR RIDE SUSPENSION
AirREX | Drop: -- | Part Number: MA004
Bellow Strut & Sleeve Strut Specs:
- Vehicle Specific Upper Mount*
Every AirREX upper mount is CNC machined from 6061 aluminum and then hard anodized. High density polyurethane bushings and/or high performance bearings completes the package to ensure exact fitment and durability. These upper mounts not only simplify installation but also improve ride quality, handling, and help provide maximum drop by replacing the bulky OEM upper mount.
- 12 Clicks Adjustable Damper
A 12-way compression + rebound (together) adjustable damper is standard in every AirREX application. Each damper is matched to the air spring (bellow or sleeve) for the vehicle application and the user can further adjust for performance or comfort by the simple turn of a knob.
- Twist Lock Compression Fitting
Compression fittings are used to ensure a reliable leak free seal when used with 6mm or ¼ inch DOT nylon air tubing.
- Fully Threaded Damper
Each AirREX damper is fully threaded to maximize adjustability similar to that of a coil over. Users can easily adjust for maximum drop or for maximum comfort at driving height by simply loosening the lower lock collar and turning the damper + air spring assembly up or down.
- Vehicle Specific Lower Mount
Every AirREX application includes a vehicle specific lower bracket which is manufacture to exact OEM specification. Every tab or bracket for the hub, spindle, sway bar, brake lines, abs sensor, etc. is present to ensure proper fitment like that of the factory suspension. Some applications will include a high density polyurethane lower mount bushing.
**Note: Bellow Strut Applications: - Double Convoluted Bellow
High durability 2-ply double convoluted air springs help provide both a comfortable ride at driving height and maximum drop when aired out. The size of the bellow is carefully chosen by AirREX engineers for each application to ensure correct spring rate and proper clearance for the vehicle.
**Note: Sleeve Strut Applications: - Rolling Sleeve
High durability rolling sleeves help provide both a comfortable ride at driving height and maximum drop when aired out. Rolling sleeves are much smaller in diameter but provide as much travel as large bellows and are used on application where air spring clearance is minimal. The size and type of rolling sleeve are carefully chosen by AirREX engineers for each application to ensure correct spring rate and proper clearance for the vehicle.
Multi-Link Suspension Specs:
- Double Convoluted Bellows or Rolling Sleeves
High durability 2-ply double convoluted air springs or rolling sleeve air springs help provide both a comfortable ride at driving height and maximum drop when aired out. The size of the bellow or rolling sleeve is carefully chosen by AirREX engineers for each application to ensure correct spring rate and proper clearance for the vehicle.
- Vehicle Specific Air spring Mounts
Every AirRex air spring are coupled with top and bottom vehicle specific air spring mounts that fits perfectly onto your vehicle's OEM spring seat without any modification.
- Vehicle Specific Shock Mounts
Every AirREX application includes a vehicle specific mounts which are manufacture to exact OEM specification. All non-transferable hardware such as bump stops collars and washers are included. A high density polyurethane lower mount bushing helps improve handling and ride quality.
SWAY BARS
Whiteline (Rear) | Adjustable: Yes | Part Number: BMR82Z
This Whiteline 24mm 2 point adjustable swaybar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll.
AutoExe (Rear) | Adjustable: No | Part Number: MGS7650
24mm diameter bar
The spring rate increased by the pipe diameter greater than that of the standard car reduces the roll at the comer. It is not supposed to work as a spring when the right and the left tires go up and down simultaneously during straight-ahead driving, etc. Therefore, worsening of ride quality is minimized.
:: Gusto :: and Degerlunden like this.
2007 MS6 - broked & gone
2006 MS6 - less broked
The Following 19 Users Say Thank You to RhoadBlock For This Useful Post:
:: Gusto :: (10-06-2012), ak_spray (01-05-2012), AZSPEED3 (01-10-2012), ButtholeRedMS3 (11-04-2015), Fail_6 (02-05-2013), Familyguy427 (01-29-2014), Ingle (02-27-2012), jcolton (09-27-2015), KevMS6 (04-28-2013), mayer (02-24-2012), MS6FL (07-04-2012), neotide87 (01-10-2012), Neverlift (12-23-2011), redmnsterut (05-15-2012), SPDFoxxx (04-26-2016), speedms6 (12-21-2011), Sullen (07-14-2018), TenaciousBoost (01-07-2012), VRed MS6 (04-02-2012)
 Old 12-17-2011, 11:33 PM   #2
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
1.) awesome.
2.) remove the prices so they don't become antiquated ya know?
The Following User Says Thank You to Mizzle For This Useful Post:
dubunderpar (03-26-2013)
 Old 12-17-2011, 11:47 PM   #3
RhoadBlock's Avatar
Fair enough. I was hoping to keep relatively up to date - anyone posted I'd fix it. BUT, I suppose it's better for everyone to just show the options and everyone can just shop for the best deals. Mo betta fo me
 Old 01-31-2012, 01:19 AM   #4
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
Part numbers/links will be uppreciated.
There's a mistake in the Koni FSD description - it is about Koni Sport.
Check it please)
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline   Reply With Quote
 Old 12-18-2011, 11:38 PM   #5
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Pretty good start. Since this is intended to be an informative thread I would suggest adding that a majority of what you've listed for the MS6 is actually designed for the base 6. Not a huge problem. But for those concerned about damping vs. ride height... they will generally be lower/softer than competitors who account for the increased weight of the MS6.
Only H&R and AutoExe sell springs/dampers specifically tuned for MS6, IIRC.
09 CWP MS3 GT
Ownership & Build Thread
 Old 12-19-2011, 04:35 PM   #6
RhoadBlock's Avatar
^ Good point. I'll mention that. Do you know if BC's new ER series was designed arounf the MS6 or the regular 6?
Also, I'll post up the MS3 stuff when I get some more time to pull all the links together.
 Old 12-19-2011, 05:37 PM   #7
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
feel free to discuss your experiences with the setups you've ran before. Good, bad, and ugly.
Also, I think it would be awesome if people could post up some of their before/after pics, or just after pics and tell what suspension setup is on the car in that pic.
Eibach Pro Kit, stock struts:
Ride is definitely "firm" but not "Harsh" at all. Ride difference is mostly felt on sharp edged bumps (such as potholes) and crossing ruts, such as when going through a 90 degree intersections. Roll, squat and turn in are all improved substantially.
Ride height is perfect for me; car looks very low but I've yet to have a scrape/clearance issue on our beat-to-shit roads. Car is also winter driven at this height without issue.
Needed: Driver mod
The Following User Says Thank You to BigRedSpecial For This Useful Post:
bazzarino (12-29-2011)
 Old 12-21-2011, 11:22 AM   #8
dot584's Avatar
Posts: 426   (View Stats)
dot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the world
Just to not confuse anyone looking to buy the koni struts for the 6, the rears are NOT externally adjustable. You have to take them out of the car or at least one end of the strut in order to twist them. The fronts are easily adjustable tho.
dot584 is offline   Reply With Quote
 Old 07-24-2018, 11:11 AM   #9
MichaelAress's Avatar
Posts: 8   (View Stats)
MichaelAress can only hope to improve
Groaned at 6 Times in 2 Posts
I seem to find a lot of threads have old links to nowhere a lot are stickies. Seems like they shouldnt be a sticky anymore if the links are all dead.
MichaelAress is offline   Reply With Quote
 Old 07-24-2018, 11:38 AM   #10
jcolton's Avatar
Posts: 80   (View Stats)
jcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the worldjcolton is the leader of the world
It's often hard to keep links live forever....especially to products...manufacturers/resellers are constantly changing their website. This post still contains all of the information you are looking for, it's just not spoon fed to you. Run a Google search on a couple of these things that you find interesting and instead of complaining that none of the links work, maybe offer some replacement links to the products you were interested in for those that come next. That's how we all work together in a forum to keep info current and to maintain the library of knowledge here.
Tres3 likes this.
jcolton is offline   Reply With Quote
 Old 01-08-2012, 06:49 PM   #11
DickFitzwell's Avatar
Posts: 996   (View Stats)
DickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the world
be interested to see this thread with the MS3 info and all the current setups being ran by fellow members.
09 CWP MS3: COBB AP / MSD DH / AT HPFP / CPE SRI / CS TIP / CS BT-RH / M2 DP / CNT CBE / HKS BPV / EVO X / E85 PERMFREEKTUNE 330/380
07 TGM MS6: COBB AP / JBR PP SRI/TIP/ JBR BT-RH / CS CBE / FORGE V1 / JBR RMM / H&R CO Stratified OTS
07 BM MS6: DREADNAUGHT / JUGGERNAUT / SU DMM*PMM*TMM / JBR RMM / BC CO / MAGNAFLOW CBE / JBR OCC / SURE BSD / PRODRIVE GC06-H
Long Signature made especially for Micha
DickFitzwell is offline   Reply With Quote
 Old 01-09-2012, 07:41 AM   #12
RhoadBlock's Avatar
Honestly I would to, and that's the intention of this thread. But I don't know all the options for the MS3. If someone could either post up or PM me links to all the MS3 options I can edit the OP to get MS3 info in there.
 Old 01-09-2012, 09:38 PM   #13
I wasn't trying to be a dick if i came off that way Rhoad. I'll see what I can find to contribute
Sent from my SAMSUNG-SGH-I997 using Tapatalk
 Old 01-10-2012, 04:31 AM   #14
RhoadBlock's Avatar
Didn't take it that way at all bro. Was just stating I agree with you. If I get a slow day at work I can work on finding stuff. But I'm not as much an authority on MS3 suspension as I am the MS6 so it'll take longer for me to find stuff.
 Old 01-10-2012, 08:22 AM   #15
I hear ya Man. wish I'd have slow days but I'm in a machine gun school rights now cramming.. ugh
 Old 01-19-2012, 07:34 AM   #16
rednofive's Avatar
Posts: 250   (View Stats)
rednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the worldrednofive is the leader of the world
Rhoadblock,
since you own the sticky, how would you prefer that you get info? I can't send PM's yet, but maybe you can send me one with an email address you don't mind givng out.
I assume you want the following:
part name
description/specs
pic
ball-park street-price
...for all of the following:
springs
dampers (shocks/struts), F&R
coilover kits
camber/caster/toe adjusters (plates, dog-bones, links, etc.)
stabilizer bars
bushings
what's the best format for me to provide it?
what's the best way to message you about it?
later, I plan to upload an excel file with a lot of data in it, plus a
summary with URL's, and also a system cost calculator - simple stuff.
maybe I can later entice some of the real gurus to put in some math
stuff, if applicable and available...
best,
Pete
SPDFoxxx likes this.
rednofive is offline   Reply With Quote
 Old 01-19-2012, 03:36 PM   #17
RhoadBlock's Avatar
@rednofive Damn. Hell of a way to jump into the MSF community as a newb! My email addy should be in my profile so you can send me an email that way.
You pretty much nailed it on what info I'd like. Just follow a similar format to how I did it in the OP. It'd be GREAT if you can get me all the extra suspension components too (ball joints, camber, sway bars, etc) like you mentioned. I'm working on getting all that stuff pulled together for the MS6 right now too.
You can either send it to me in text in an email but make sure you don't forget the BBcode - [IMG][/IMG], , tags and what not. If you do I can cut/paste and add the code on my own, it'd just save me a bit of time. Or you can send me an Word/Excel file if you'd like. I'll take all that info and transfer it to the OP.
If you do this you'll be a badass brownie in my book!
 Old 01-20-2012, 11:15 AM   #18
rednofive's Avatar
K.
I like making XLS documents, so I'll start with all info there.
I'll try to give you an example soon so you can say "hell-no, that's too much work for me" or "keep it coming".
Probably take me a couple of weeks for a complete first draft, maybe a month before all done.
I'll start this weekend.
I'll step out of the way if anyone can do it faster.
 Old 01-20-2012, 11:21 AM   #19
rednofive's Avatar
as for the newb thing.
My suspension experience is limited to the ITS RX7 I built in 2000--2002.
I used:
Tokico struts and cut off their perches for fitment of ground-control coilover kit. spring rate 400F/275R.
I ran an Eibach front sway bar but kept the stocker for rear.
I put in camber/caster plates for the front and a rear subframe link for rear camber adjust.
I pressed in Delrin bushings all-around and active-steer toe "eliminator" bushings in the rear.
ton of fun, except that the Tokico's sucked as struts go (adjustable fast compression only - the worst damper adjustment-type possible!).
live and learn. the Tokico's I could afford - the Koni's not so much at the time.
I've a lot to learn about options for our MS3's, so still a newb...
 Old 01-29-2012, 08:36 AM   #20
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
what, no info on air.ride?
I know there is a company out there that makes application for ms3
devindusza12 likes this.
yea yea - i know i cant spell
The Following User Says NO Thank You to :: Gusto :: For This Un-useful Post:
Mizzle (01-29-2012)
 Old 01-29-2012, 08:38 AM   #21
2011speed's Avatar
Posts: 1,497   (View Stats)
This is not the forum to b herrafrush
Sent from my Cobb Accessport
FreeKtuned
fitty fitty
 Old 02-05-2012, 09:58 PM   #22
Thumbs up
its a suspension thread. it should be included.
check out accu.air .. or airREX..
struts/bags built as 1 unit.. not just bags alone.
race application are currently being used.. Just cuz you don't get it..
doesn't mean you should flame on it.
 Old 01-31-2012, 03:45 AM   #23
xXxDmitriyxXx's Avatar
Posts: 10   (View Stats)
xXxDmitriyxXx will become famous soon enough
A lot of useful stuff, thanks!
xXxDmitriyxXx is offline   Reply With Quote
 Old 01-31-2012, 04:19 AM   #24
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Neutral  -1 score
@RhoadBlock
add Raceland to the list
2015 Mazda 6
The Following User Says NO Thank You to IshiKage For This Un-useful Post:
Neverlift (04-15-2012)
 Old 02-01-2012, 04:59 AM   #25
RhoadBlock's Avatar
@paveltol, I don't want to add links. Most of these items can be bought at our forum sponsors and I don't want to favor any of them in the OP, regardless of my preference. I'll check the Koni info tho and also update with as many more part numbers as I can find. Most part numbers are up there tho. Thanks.
@IshiKage...@rednofive emailed me a bunch of info for the MS3 so I'll probably make a separate thread soon for the MS3 Suspension. Does Raceland make COs for the MS6 too now? Or just the MS3?
The Following User Says Thank You to RhoadBlock For This Useful Post:
paveltol (02-01-2012)
 Old 02-06-2012, 04:55 AM   #26
RhoadBlock's Avatar
Neutral  +1 score
@:: Gusto :: I'll be making a thread for the MS3 shortly. Post up the link in there and I'll add it to that OP.
BlckMs3 (02-06-2012)
 Old 02-27-2012, 06:22 AM   #27
JMEngineer's Avatar
Posts: 2,122   (View Stats)
Does anyone know the stock spring rates for the MS6?
It took me forever to find them once and now I can't find where I wrote them down. I'll be sure to post here if I come across them.
-GTX2867R Coming Soon
 Old 02-27-2012, 07:19 AM   #28
driver311's Avatar
Posts: 1,769   (View Stats)
Where are the yellowspeeds that can be purchased through PG? I ran them all last season with 10k of street use, with aggressive autocross/track use and had awesome results with them. They ride amazing and have lots of ajustability. Camber, pillow mount and 32 levels of dampening. I was more than impressed with them. Definately better than my friends that run BC. Just my .02.
Mazdaspeed
 Old 02-29-2012, 07:13 AM   #29
RhoadBlock's Avatar
Updated OP. Fixed bad links, listings, etc. Added Yellowspeed. Even added AirREX.
If anyone ever notices anything that needs correcting or that should be added be sure to "mention" me along with said info.
 Old 03-02-2012, 05:38 PM   #30
air.rex
Neverlift (05-07-2012)
 Old 03-07-2012, 11:29 AM   #31
JMEngineer's Avatar
Fortune Auto is no longer an option. Apparently there wasn't much interest from our platform and someone (probably a pu owner) pissed them off with too many stupid questions so they dropped the 3 and 6 completely.
 Old 04-05-2014, 10:00 AM   #32
denvemolorado's Avatar
Posts: 6   (View Stats)
denvemolorado will become famous soon enoughdenvemolorado will become famous soon enough
I am new to the forums and just thought I would let everyone know that I ordered and installed a set of Fortune Auto 500 series coilovers for the MS6. So far, I really like them. Just FYI.
[IMG][/IMG]
denvemolorado is offline   Reply With Quote
 Old 03-07-2012, 09:21 PM   #33
Mizzle's Avatar
Groans: 324
If I had a company and I had developed a product, I'd answer all the stupid questions. Customer service isn't what it used to be.
 Old 03-15-2012, 07:14 PM   #34
dooood.. nice update to the thread!!!
glad to see Air.REX on the thread... there stuff is so sexy..
but i priced them out w/ memory fab.. damn..
 Old 03-21-2012, 09:23 PM   #35
Importfan12's Avatar
Posts: 171   (View Stats)
Importfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond repute
I have the Ksport kontrol pro Coilovers and they are awesome. Really like that the height and dampening dont effect eachother. I had mine really low to start and soft it was great but I raised it and stiffened it due to a lot of speed bumps at my house.
Importfan12 is offline   Reply With Quote
 Old 04-15-2012, 11:58 AM   #36
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
*damping
This is not the forum to be herrafrush
^voice of reason.
Those monotube BC's w/ the externals for under 2k... hmmm.. I hate that the 6 doesn't have that great of options but they could be decent.
We should cover all the supporting mods that need to be done to run a lower ride height to maintain effective suspension geometry.
Past Mazdas & Speeds
dot584 (04-18-2012), Gitcherex (12-18-2015)
 Old 03-21-2012, 09:50 PM   #37
JMEngineer's Avatar
@RhoadBlock - remove the Fortune coilovers from the list... They wouldn't even make them for me as a custom set for more $$$
Also, I think Bilstein will do custom valve stacks to match the springs and weight of the speed 6 for a small fee but you have to go through a distributor - any distributor from this list should be able to handle it: Online Dealers & International Referrals
If you give them some basic information (the increase in spring rates vs. the normal 6 (25% front, 37% rear), the car weight, and the F/R weight distribution) the guys at Bilstein should be able to put together a well matched valve stack for you.
The Following 4 Users Say Thank You to JMEngineer For This Useful Post:
BrianB6 (04-15-2012), Nliiitend1 (03-21-2012), RhoadBlock (03-26-2012), triplejumper18 (03-21-2012)
 Old 03-26-2012, 10:45 AM   #38
RhoadBlock's Avatar
Fortune Auto removed
The Following 2 Users Say Thank You to RhoadBlock For This Useful Post:
:: Gusto :: (05-07-2012), Nliiitend1 (03-26-2012)
 Old 04-09-2012, 12:32 PM   #39
ppe4life's Avatar
Posts: 106   (View Stats)
ppe4life has a reputation beyond reputeppe4life has a reputation beyond reputeppe4life has a reputation beyond reputeppe4life has a reputation beyond reputeppe4life has a reputation beyond reputeppe4life has a reputation beyond reputeppe4life has a reputation beyond reputeppe4life has a reputation beyond reputeppe4life has a reputation beyond reputeppe4life has a reputation beyond reputeppe4life has a reputation beyond repute
does anyone know if the D2 Racing coilovers work with our cars?
seeing how Bilstein & Koni are actually made on mazda 6 platform, could it be B2 would work also? i called D2 and they said they are not made for the speed 6, but just in case, throwing it out there.
ppe4life is offline   Reply With Quote
 Old 04-09-2012, 05:53 PM   #40
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
D2 = Taiwanese cookie-cutter junk
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Micha (02-21-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/official-mazdaspeed-6-suspension-thread-99915/
Foro Club Mazda España ? Ver Tema - amortiuadores Mps This thread Refback 02-28-2015 12:57 AM
Mazda MPS Owners Club • View topic - So.. i finally placed an order for these.. This thread Refback 05-01-2012 12:06 PM
The Official MS3 Suspension Thread RhoadBlock MazdaSpeed 3/6 - Suspension & Brakes 199 07-02-2018 11:27 AM
Official: Mercedes-Benz offers new Ride Control suspension on SLS AMG Haltech Automotive News 1 04-13-2012 09:28 PM
Another.. is my suspension shot thread amc5 MazdaSpeed 3/6 - Suspension & Brakes 14 01-20-2012 08:16 AM
Another suspension noise/sound thread-Strut Bearing? Raider MazdaSpeed 3/6 - Suspension & Brakes 8 12-07-2011 09:57 PM
Page generated in 0.79610 seconds with 41 queries
