Like Tree13Likes
 Old 03-17-2015, 05:30 PM   #1
license2ill's Avatar
Posts: 313   (View Stats)
license2ill is infamous around these partslicense2ill is infamous around these parts
Groans: 30
Groaned at 132 Times in 57 Posts
Uh... well if stock is 479lbs/in as I've heard stated.
Then ours is 546 lbs/in.
I don't have the number written for sure.
Thanks, but isn't that just 14% stiffer? I don't expect the dimensions to add double the stiffness, but comparing bars and numbers with adjustment options is a cluster of confusion with nothing straightforward. What I really don't understand is the Hotchkis numbers if the JBR numbers are correct., and back to a similar, but narrower CS bar.
license2ill is offline   Reply With Quote
 Old 03-17-2015, 08:11 PM   #2
aackthpt's Avatar
Posts: 1,450   (View Stats)
Then ours is 546 lbs/in. I don't have the number written for sure.
Exactly what I was going to say. Corksport website says "Two endlink attachment points to change the stiffness between 114% stiffer than stock, or 180% stiffer. " The numbers you just gave @Spencer@CorkSport; would indicate it is either 14% (or 80%) stiffer, or to put it another way 114/180% of the stock stiffness.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/official-suspension-bars-braces-thread-185726/
Bars, but not the thirst-quenching kind This thread Refback 06-29-2015 09:58 AM
The Official MS6 Suspension Thread RhoadBlock MazdaSpeed 3/6 - Suspension & Brakes 182 07-24-2018 11:38 AM
Official Suspension Bars and Braces Thread Inquisitive MSF KB - Mazdaspeed 3/6 - Suspension & Brakes 71 03-24-2015 06:10 AM
The Official MS6 Suspension Thread RhoadBlock MSF KB - Mazdaspeed 3/6 - Suspension & Brakes 1 09-19-2012 01:36 PM
Strut tower braces or f/r sway bars? dMuze 2010 MS3 - Suspension & Brakes 4 12-14-2011 10:26 PM
MS6 Aftermarket Suspension Braces Worth It? Alpha MazdaSpeed 3/6 - Suspension & Brakes 8 07-12-2011 08:22 AM
Page generated in 0.30603 seconds with 23 queries
