 Old 12-14-2009, 10:48 AM   #1
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
Default posi-quiet pads for ms3
FYI the posi-quiet pads p/n 104.09152 may be too thick.
these are semi-metallic pads for the front brakes on the ms3.
i purchased / installed them and they had to be sanded to fit. i tried to do the install, and, when i had issues, i had a dealer do it. they also found the pads to be too thick.
it may be an isolated issue, or it may be the wrong part altogether. i purchased them from r1 concepts.
the next time around i will most likely purchase pads from SU or PG. i deviated from my trusted mazda vendors and got burned as a result
08_ms3_gt is offline   Reply With Quote
The Following User Says Thank You to 08_ms3_gt For This Useful Post:
rodrigo (12-14-2009)
 Old 12-14-2009, 10:49 AM   #2
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
thanks for giving us a heads up about this product
 Old 12-29-2009, 11:42 AM   #3
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
I have these pads on my MS3, they installed perfectly, perform great, have less dust and are completely quiet.
no offense to the OP but I hate it when a product gets a bad rap based on ONE review (like hawk HPS).
so for the record, these pads worked great for me--- OP check the box and the pad to make sure you got the right part number.
2007 Mazdaspeed3 Sport, True Red
ElBartoRex is offline   Reply With Quote
 Old 12-29-2009, 12:26 PM   #4
aspiring turbo guru
08_ms3_gt's Avatar
After the install headaches, I have been happy with the pads. They perform well.
I did verify the part number with 2 vendors, r1 and tri-point.
I'm not trying to prevent ppl from buying these, but I think it's fair to communicate that I had an issue and did everything I could before realizing that the idiot working at posi quiet one day screwed up my pads. It's just a fair warning, or at least if someone else has this problem they'll know to request a new set.
ElBartoRex (12-29-2009)
 Old 12-29-2009, 12:34 PM   #5
memin's Avatar
Posts: 994   (View Stats)
thanks for the info
 Old 01-13-2010, 12:18 PM   #6
LiamT's Avatar
Posts: 62   (View Stats)
LiamT is a splendid one to beholdLiamT is a splendid one to beholdLiamT is a splendid one to beholdLiamT is a splendid one to beholdLiamT is a splendid one to beholdLiamT is a splendid one to behold
I can vouch for the OP that the pads were too thick. They sent me another set. Same problem. I had to sand about 2-3 mm off each side to get it to fit. Before you ask, the piston was compressed all the way.
I'm glad that you like the pads but I hated them. Their stopping power was pathetic compare to OEM. On the good side that are almost dustless.
LiamT is offline   Reply With Quote
The Following User Says Thank You to LiamT For This Useful Post:
08_ms3_gt (01-13-2010)
quiet exhaust? Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 7 09-10-2009 07:55 PM
Do you run on 17's and is it more quiet and the ride smoother? lengbros MazdaSpeed 3/6 - Wheels & Tires 6 04-13-2009 04:49 PM
Quiet BOV? Ftaz1 MazdaSpeed 3/6 - Turbo Induction 13 12-22-2008 03:44 PM
Mitsubishi union keeps strike vote quiet Haltech Automotive News 0 08-04-2008 03:20 PM
NHTSA vows research on quiet-car threat Haltech Automotive News 0 06-23-2008 03:00 PM
Page generated in 0.26901 seconds with 24 queries
