 Old 04-13-2013, 11:31 AM   #1
MARKSPEED3's Avatar
Posts: 43   (View Stats)
MARKSPEED3 is a splendid one to beholdMARKSPEED3 is a splendid one to beholdMARKSPEED3 is a splendid one to beholdMARKSPEED3 is a splendid one to beholdMARKSPEED3 is a splendid one to beholdMARKSPEED3 is a splendid one to beholdMARKSPEED3 is a splendid one to beholdMARKSPEED3 is a splendid one to behold
Default Is it possible to replace strut mounts without completely removing the strut (bottom) from car?
It seems my strut mounts are making a creaking noise while steering. Planning to replace next weekend.
To save time and trouble, is it possible to keep the strut attached at the bottom, and compress spring while on the car to replace the mount on top, or is it necessary to completely remove the strut?
When I attempted to change the front struts a year ago, I couldn't get it free at the bottom, had to take to a shop.
Any advise appreciated, thanks!
2008 MAZDASPEED3
Bilstein Sport Shocks - Cobb Springs - JBR RSB - JBR 70 RMM
MARKSPEED3 is offline   Reply With Quote
 Old 04-13-2013, 11:36 AM   #2
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Probably, but could be tricky
it's fun to do bad things
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
MARKSPEED3 (04-15-2013), Raider (04-15-2013)
 Old 04-15-2013, 09:37 AM   #3
asrautox's Avatar
Posts: 196   (View Stats)
asrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the world
Technically you can remove the entire lower arm and drop the spindle out, but to get it out enough to work on you'd also have to remove the brakes. Not worth it IMO.
There are a number of threads on removing the struts. I bought an 1/8" thick steel chisel and used the bolt trick to spread it open. Came out super easy.
2011 PB EVOX GSR | FBO + E85
(Sold) 2008 Black Mica MS3 | Cobb AP | UR DP+TP | HTP 3" | CS TMIC | CS BPV | Autotech HPFP | CPE RMM | JBR SSP | Koni Yellows | Cobb RSB | SPC Camber Arms | E40 Self Tune - 295whp/327wtq Uncorrected @ 5600' ASL
2014 Triumph Street Triple R
asrautox is offline   Reply With Quote
The Following 2 Users Say Thank You to asrautox For This Useful Post:
MARKSPEED3 (04-15-2013), SLOWHATCH (04-15-2013)
 Old 04-15-2013, 09:41 AM   #4
MARKSPEED3's Avatar
Thanks for your input. I'll count on removing them completely. Should be easier this time around knowing the tricks.
2008 MAZDASPEED3
 Old 04-15-2013, 09:42 AM   #5
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Not much room up there. Plus you will need to make sure the top hat is properly positioned before you tighten it down.
The Following User Says Thank You to SLOWHATCH For This Useful Post:
 Old 04-15-2013, 09:59 AM   #6
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
It's very easy with the reverse bolt trick and a bit of WD-40. Once you crank open the arms, just squirt a bit of WD40 down between the arm and shock body on all sides. With a little bit of downward pressure, the shock will pop right out.
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline   Reply With Quote
 Old 04-15-2013, 10:22 AM   #7
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
I dont like lubing the shocks it helps them hold better
 Old 04-15-2013, 11:00 AM   #8
Or just remove the strut from the base by using the emergency jack to pop it out. Works every time for me.
dh5077 (04-23-2016), jack_hammer (04-15-2013)
 Old 04-15-2013, 11:11 AM   #9
Groans: 549
Just watch the speed sensor if you use the jack. Our even remove it. If you f it up, though, i have one for sale.
MidwestSpeed3 (04-18-2013)
Strut Mounts Front + Rear (?) jjm MazdaSpeed 3/6 - Suspension & Brakes 6 04-09-2013 11:13 AM
? on bolt at bottom of strut. iammike 2010 MS3 - Suspension & Brakes 27 01-26-2013 10:03 AM
Page generated in 0.29751 seconds with 26 queries
