 Old 06-24-2016, 08:20 PM   #1
Roman-dude's Avatar
Posts: 56   (View Stats)
Roman-dude will become famous soon enoughRoman-dude will become famous soon enough
Default Putting in new rear shocks - replace mounts too?
Hey guys, so don't know if the mounts are still good (car has 87k on it), but thinking of replacing them since will be replacing the shocks anyway. Thoughts? thanks
Roman-dude is offline   Reply With Quote
 Old 06-24-2016, 09:49 PM   #2
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
Most guys replace the top mounts while they're in there, but it's also possible to rebuild/repack the bearings if you'd rather go that route. There's a how-to on the forum that you can find; I followed it when I replaced my shocks earlier this year and haven't noticed any issues thus far. Takes lotsa grease but isn't a difficult process.
 Old 06-24-2016, 10:35 PM   #3
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
I think he's talking about rear shocks no bearings there. And you can get top hats/bearing for $25 from ford with a better design than our OEM.
For rear mount you will most likely need new bump stops but I don't see how that rear mount could fail other than the bump stops. Sachs makes a kit for like $35 and they come with boots too.
 Old 06-24-2016, 10:53 PM   #4
Groans: 126
Derp, you sure are correct; apparently I didn't fully read the thread title!
Rear bumps hold up much better than front and may be reusable if you're on a tight budget; mine were still okay after 80k even though the fronts were like dry, crumbling toast. The rear mounts themselves shouldn't have any problems unless you somehow managed to crack one or something.
 Old 06-26-2016, 11:17 AM   #5
Roman-dude's Avatar
Thanks, I glanced and only saw the whole mounts, not just the bumps. What are the ford ones and do they fit in MS3 mounts? If it's not a direct fit I might just swing for the entire mounts. thx
 Old 06-26-2016, 11:32 AM   #6
Groans: 126
I think the popular choice is to just get new OEM bump stops in the rear, although the front bumps are known to be garbage and should be replaced with a set from Ground Control.
 Old 06-26-2016, 04:42 PM   #7
Jega's Avatar
Posts: 118   (View Stats)
Jega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud of
Groaned at 39 Times in 10 Posts
I just replaced my suspension and with over 100k miles the rear mounts and bump stops were fine and completely reusable. Fronts, not so much.
2007 Mazdaspeed3
Jega is offline   Reply With Quote
putting air bags in rear for track? Sal's_MS6 MazdaSpeed 3/6 - Suspension & Brakes 47 04-19-2013 11:27 AM
Page generated in 0.27071 seconds with 23 queries
