  • 1 Post By Clintb3astwood
 Old 08-30-2016, 01:29 PM   #1
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
Default Rear Control Arm
Need some help, advise, etc. So long story short, was changing rear sway bar endlinks, bushings, and the rear springs. Everything went well, though the outer bolt on the lower control arm is seized with the bushing and I cannot take it out. Also, the bushing itself is "gone" so it def needs a replacement. So, any idea where I can find a cheap control arm or bushing (the whitelines a bit expensive at $71). Any ideas how to remove the bolt without cutting are appreciated too.
P.s. Rockauto has one control arm for $35, under speed3:
More Information for MEVOTECH CMS76155
Under regular 3, they have more options, including MOOG, though I am not sure if it is going to fit the speed3:
More Information for MOOG RK641468
dead-zone is offline   Reply With Quote
 Old 09-06-2016, 11:07 PM   #2
dead-zone's Avatar
FYI, the MEVOTECH rear LCA listed for mazdaspeed 3 did fit.
The Following User Says Thank You to dead-zone For This Useful Post:
Mauro_Penguin (09-07-2016)
 Old 09-07-2016, 09:40 PM   #3
Smus's Avatar
Posts: 35   (View Stats)
Smus has a spectacular aura aboutSmus has a spectacular aura about
If you run into any more problems with seized bolts, bar none, the best penetrating fluid is Seafoam's Deep Creep. Runs about $10/can but I'd trust that stuff to break loose a rusted engine. Just be sure to give it enough time.
Smus is offline   Reply With Quote
 Old 02-23-2019, 11:38 PM   #4
Roman-dude's Avatar
Posts: 56   (View Stats)
Roman-dude will become famous soon enoughRoman-dude will become famous soon enough
thanks for updating your original post. How has it been holding up? thx
Roman-dude is offline   Reply With Quote
 Old 09-17-2019, 08:23 AM   #5
Clintb3astwood's Avatar
Posts: 45   (View Stats)
Clintb3astwood is a glorious beacon of lightClintb3astwood is a glorious beacon of lightClintb3astwood is a glorious beacon of lightClintb3astwood is a glorious beacon of lightClintb3astwood is a glorious beacon of light
Bump any word on the mevotech lower arms?
Anyone else know if the moog lower arms will fit the speed 3?
Clintb3astwood is offline   Reply With Quote
The Following User Says NO Thank You to Clintb3astwood For This Un-useful Post:
Db09ms3 (09-17-2019)
 Old 09-17-2019, 10:36 AM   #6
Db09ms3's Avatar
Posts: 536   (View Stats)
They just confirmed they work.
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
Clintb3astwood (09-17-2019)
 Old 09-17-2019, 10:38 AM   #7
The Moogs?
Sweet ill place an order. Are the side specific or no?
 Old 09-17-2019, 10:51 AM   #8
Db09ms3's Avatar
Report back when you get them and be the guinea pig.
Stockish
 Old 09-17-2019, 11:00 AM   #9
Db09ms3 likes this.
 Old 09-17-2019, 12:00 PM   #10
Just received confirmation that it works!
The Following 2 Users Say Thank You to Clintb3astwood For This Useful Post:
Db09ms3 (09-17-2019), whatsabrooklyn (09-18-2019)
Rear suspension lower control arm Dasleeper MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 08-09-2014 03:07 PM
Adjustable Rear Lower Control Arms? redboat MazdaSpeed 3/6 - Suspension & Brakes 4 12-25-2013 10:03 AM
Pass rear lower control arm mikelevi MazdaSpeed 3/6 - Suspension & Brakes 3 09-06-2013 06:19 PM
Page generated in 0.28674 seconds with 24 queries
