 Old 02-27-2020, 09:59 PM   #1
onesheisty's Avatar
Posts: 6   (View Stats)
onesheisty has a little shameless behaviour in the past
Default Weird issue with Steering Wheel
So. 07 Gen 1. I'm trying to sort out this odd thing with my steering. It's hard to describe. It's like all of a sudden when I turn the wheel it feels "loose". Not loose like the actual steering wheel is loose. But it's like I have to turn the wheel further to get the same amount of turn? Or when I come out of a turn, the steering wheel is still turned a bit, but the wheels are straight?
No power steering pump whine. No, it's not hard to turn the wheel. The rack & pinion has not been touched. The only thing that's been done is I had the OEM shocks / struts replaced with Koni Reds and I left the stock springs. New end links and bushing in the rear. New Moog Sway bar links in the front. Other than that, stock down to the wheels. But all that was done last summer. This is a new issue.
I had a mechanic put it up on a lift to check it out. He saw nothing. He told me I needed an alignment. The same ish is happening after it was aligned. Nothing visibly broken, that I can see with it on the ground. I do have the front end clunk though. Front sway bar bushings going in soon. What else am I missing?
onesheisty is offline   Reply With Quote
Steering wheel leather worn out, anyone got a new wheel? spinfly Interior 39 08-03-2018 03:15 AM
Plastidip - Steering Wheel + Steering command Atomic41 Mazdaspeed3/6 General Discussion 2 04-19-2015 04:35 PM
Weird Issue razor3232 2010 MS3 - Wheels & Tires 6 04-25-2013 07:42 AM
Tilt & telescopic steering wheel Issue derek0609 2010 MS3 - Troubleshoot/Diagnostics 10 06-03-2011 09:32 PM
Steering Wheel issue. Demi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 11-25-2008 10:33 AM
Page generated in 0.22961 seconds with 20 queries
