What else to replace when doing shocks? I'm going to be replacing my front struts with Koni Yellows. I'm a little unfamiliar with everything needed with this. After doing some research on the forums I saw that I should probably replace with the: End links (Moog?) Strut Mount (with this?) Strut Bearing (with this?) Bump Stop (OEM?) I'll continue to do more research but does that sound correct? Should I replace anything else? Any recommendations for what to replace them with? Thank you! |
might as well do sway bar bushings and lube the brake guide pins. |
Quote:
I'm not sure if the moog endlinks have been fixed yet but, FYI on their front endlinks http://www.mazdaspeedforum.org/forum/foru...750073-197007/ |
Quote:
Your mods are pretty much exactly what I want to do with my car. Do you daily it? |
Ya I do daily it. Is there anything you want to know? |
| All times are GMT -7. The time now is 06:17 AM. |
