 Old 01-30-2020, 06:02 PM   #1
StopaOcean's Avatar
Posts: 14   (View Stats)
StopaOcean is on a distinguished road
Default What else to replace when doing shocks?
I'm going to be replacing my front struts with Koni Yellows. I'm a little unfamiliar with everything needed with this. After doing some research on the forums I saw that I should probably replace with the:
End links (Moog?)
Strut Mount (with this?)
Strut Bearing (with this?)
Bump Stop (OEM?)
I'll continue to do more research but does that sound correct? Should I replace anything else? Any recommendations for what to replace them with?
Thank you!
StopaOcean is offline   Reply With Quote
The Following User Says NO Thank You to StopaOcean For This Un-useful Post:
Db09ms3 (01-30-2020)
Putting in new rear shocks - replace mounts too? Roman-dude MazdaSpeed 3/6 - Suspension & Brakes 6 06-26-2016 04:42 PM
To replace or not to replace the throwout bearing that is the question? stockms3 MazdaSpeed 3 - Engine, Transmission & Driveline 4 06-30-2014 07:29 AM
RX8 shocks dimka505 MazdaSpeed 3/6 - Suspension & Brakes 2 08-24-2012 09:59 AM
New shocks for 07 MS3 Peterspeed3 MazdaSpeed 3/6 - Suspension & Brakes 6 08-20-2012 01:41 PM
Page generated in 0.26578 seconds with 22 queries
