| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Jun 2019
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score End links (Moog?) Strut Mount (with this?) Strut Bearing (with this?) Bump Stop (OEM?) I'll continue to do more research but does that sound correct? Should I replace anything else? Any recommendations for what to replace them with? Thank you! |
| The Following User Says NO Thank You to StopaOcean For This Un-useful Post: | Db09ms3 (01-30-2020) |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score might as well do sway bar bushings and lube the brake guide pins.
__________________ 94 M MS6 IS350 |
![]() Join Date: Dec 2017 Location: Chico CA for school. Originally From the Bay Area
Rep Power: 27 ![]() Thanks: 15
| Not Ranked : 0 score I'm not sure if the moog endlinks have been fixed yet but, FYI on their front endlinks New Redesigned Moog front endlinks (K750073)
__________________ 2009 CWP GT MS3 Damond Motorsports RMM PMM and TMM Autotech HPFP Cobb SF Intake Cobb AP Autotech HPFP Corksport RSB+FSB Corksport Adjustable Short Throw Corksport Metal Skid Plate Koni FSD |
![]() Your mods are pretty much exactly what I want to do with my car. Do you daily it? | |
| Not Ranked : 0 score Ya I do daily it. Is there anything you want to know?
| Display Modes | |
| Putting in new rear shocks - replace mounts too? | Roman-dude | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 06-26-2016 04:42 PM |
| To replace or not to replace the throwout bearing that is the question? | stockms3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 06-30-2014 07:29 AM |
| RX8 shocks | dimka505 | MazdaSpeed 3/6 - Suspension & Brakes | 2 | 08-24-2012 09:59 AM |
| New shocks for 07 MS3 | Peterspeed3 | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 08-20-2012 01:41 PM |
