![]() Join Date: Mar 2016 Location: 921 Cadillac Ct, Milpitas 95035
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hello everyone, I'm looking for a headlamp to replace the burned out one on my 2008 MS3. I looked around the forum, and found many guys talk about HIDs. My quetions is does anyone used or using a OEM HID headlamp on 2008 MS3? How about it? I dont want waste too many time but got a trash.thank you. ![]() ill back tomorrow, good night. Last edited by Brett V; 03-08-2016 at 12:21 AM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score I'm not sure what you're asking. Many have used aftermarket HID kits in OEM projector housings. The Sport trim came with halogen projector headlights. The GT trim came with HID headlights from the factory, and have a better lens than the Sport ones. You can swap in GT headlights into a Sport.
__________________ |
(Thread Starter) | Not Ranked : 0 score Sorry, I thought that i just need to change one bulb, but now I know I need two, both head beams all need to be replaced. Projector housings kit usually perfect, but this time I dont need, just bulbs would be fine. I driving on country road every day, so I want the bulbs brightness enough, I think at latest 5000K, and lighting can throw out long distance, any suggestion will be appreciated |
![]() Join Date: Mar 2010 Location: San Francisco, CA
Rep Power: 295 ![]() Thanks: 14
| Not Ranked : 0 score I don't really know what you're asking for either. But I'll try to help, go here for your HID related needs: https://www.theretrofitsource.com/ |
| If brightness is all you want, mount a 13,000 lumens light bar, that'll sure brighten it up. And it'll cost you less than half that. sent from my Nexus 6P
| Question regarding malfunctioning Xenon Headlamp | listrats | Mazdaspeed3/6 General Discussion | 13 | 02-26-2015 10:12 PM |
| Headlamp Issues | JuSteve | MazdaSpeed 3/6 - Appearance | 1 | 07-28-2013 11:59 AM |
| Headlamp buying issue | Alex023 | Mazdaspeed3/6 General Discussion | 6 | 04-01-2012 12:12 PM |
| Headlamp care | 86AmishMs3 | Car Detailing | 12 | 02-24-2012 01:35 PM |
