> CX-7 > Interior / Exterior Appearance Mods
 Old 11-10-2015, 11:40 AM   #1
bzwyatt's Avatar
Posts: 543   (View Stats)
bzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the world
Groaned at 35 Times in 14 Posts
Default brake light melted
Changing bulbs on brake lights in my '08 CX-7, I pulled the bulb out and it had some dark red goo on it, something had melted and dried onto the bulb.
Couldn't see what it was, noticed that the top part of the brake lights were not as red as the rest, and after some research, found out/realized that the bulbs get too hot, melt a hole in the inside of the brake light housing/lens area, the red plastic drips onto the bulb as it melts, and there is a nickel-sized hole above each brake light bulb on the inside of my brake lights.
I'd noticed that there was some dirt/smoking and wasn't sure if it was getting faded, or something else, maybe a bug got in there. Now I realize it is from the smoke of the plastic burning onto the bulbs.
Have you heard of this anybody?
I'm thinking of getting some LED bulbs to replace the standard ones. I also want clean brake lenses again. I don't know about good options for replacing them without spending probably several hundred if I wanted Mazda ones.
Any input?
bzwyatt is offline   Reply With Quote
e-brake light, abs light, dsc light, and traction control light DarrenMon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-27-2016 08:44 PM
Third brake light sk8bdr81 MazdaSpeed 3/6 - Appearance 5 03-14-2012 05:26 PM
Smoked 3rd Brake Light boost2dms6 MazdaSpeed 3/6 - Appearance 12 05-11-2011 10:04 AM
abs,tcs,brake light on after brake job sytntyt MazdaSpeed 3/6 - Suspension & Brakes 6 11-29-2010 02:33 PM
Parking brake light? blaggah MazdaSpeed 3/6 - Suspension & Brakes 7 08-05-2009 02:07 PM
Page generated in 0.22200 seconds with 20 queries
