> CX-7 > Interior / Exterior Appearance Mods
 Old 12-16-2014, 10:22 AM   #1
jasonb0816's Avatar
Posts: 15   (View Stats)
jasonb0816 is an unknown quantity at this point
Default cx-7 cluster swap
One on the digital displays for the mileage went out so I bought a replacement cluster.
Once plugged in the new cluster will not let me start the car. I tried removing the negative terminal on the battery to reset the computer but the cluster still will not let me start the car. Everything else works just fine.
Any ideas?
Thanks
jasonb0816 is offline   Reply With Quote
 Old 12-16-2014, 10:37 AM   #2
torquemaniac's Avatar
Posts: 733   (View Stats)
You may find your answer here is the workshop manual (post#13) : CX-7 FAQ Thread
I find it odd that a simple cluster would prevent the car form starting...did you try to start the car with the cluster unpluged?
Maybe you accidently damaged some important wires or blew a fuse...
2011 CX-7 AWD 2.3 turbo
 Old 01-02-2015, 06:02 PM   #3
jasonb0816's Avatar
It seems like the cluster is programmed to the key. Car does not start with out the original cluster installed. Talked to the dealer and its needs to be programmed in order to work. I tried everything including the Open the Door 3 times program procedure but no dice. Dealer wants $125 to reprogram
Mold in PG cluster. Demi MazdaSpeed 3 - How-To's 13 04-21-2013 07:29 PM
MAZDASPEED3 Cluster swap Atomic41 Mazdaspeed3/6 General Discussion 18 05-02-2012 07:05 AM
Page generated in 0.26512 seconds with 21 queries
